Topic: Merge FLAC files limited to max 2.00GB? (Read 36019 times) previous topic - next topic
I could dublicate SoleBastard's issue immediately with 24 bit source files and went digging into FLAC's WAV reader. It was designed to only handle 4 GB source files. Attached version no longer has that limit.
[attachment=6130:flac_1.2.1_mod4.zip]
Thank you, Case. And nice to see an old name around here too!
Looks like I spoke too soon - this doesn't work in foobar2000, I suspect because metaflac hasn't been updated too. The files are written, but the tag writing fails.
Do you have an updated metaflac too, please?
foobar2000 writes all tags itself and tagging works here (I use fb2k 1.1.2).
Wow thanks. You solved a bug I tried to find a solution for days (no knowing it was a flac.exe bug, thought my input WAV files were corrupted).
Thank you !!
