As of v1.1.10 the seekbar (both vanilla and waveseek) seems to jerk back and forth a bit. A few things exacerbates this.
1: I both run foobar2000 off my NAS from iscsi (portable install), and all my music is streamed via samba. If i put any load on the network foobars autoscroll elements become jerky. This wasn't an issue prior to v1.1.10, as far as i remember.
2: The XQEQ 3rd party plugin causes this as well.
Now when placing load on the network, i can occasionally get audio cutouts along with the jerky seekbar. This has never happened before in any version of foobar as far as i remember. When using XQEQ audio never cuts out, but UI is still jerky.
I have tried vanilla foobar2000, and this issue is still present with network load.
Thank you in advance for any help!!!
*EDIT* My DSP stack is:
Resampler (PPHS) at 96khz Ultra
XQEQ
the main foobar thread (foobar2000.exe+0x13ad1b):
user32.dll+0x19bef
wow64cpu.dll!TurboDispatchJumpAddressEnd+0x6c0
wow64cpu.dll!TurboDispatchJumpAddressEnd+0x2ac
wow64.dll!Wow64SystemServiceEx+0x1ce
wow64.dll!Wow64LdrpInitialize+0x429
ntdll.dll!RtlIsDosDeviceName_U+0x24c87
ntdll.dll!LdrInitializeThunk+0xe
ntdll.dll!ZwWriteFile+0x15
kernel32.dll!WriteFile+0x4a
foo_out_asio.dll+0x1be0
foo_out_asio.dll+0x2544
foo_out_asio.dll+0x9a5d
foo_out_asio.dll+0x959f
foobar2000.exe+0x9cf92
foobar2000.exe+0x9f14c
foobar2000.exe+0x9e9a5
foobar2000.exe+0x9e943
foobar2000.exe+0x9e887
foobar2000.exe+0x13acf5
foobar2000.exe+0x13ad7f
kernel32.dll!BaseThreadInitThunk+0x12
ntdll.dll!RtlInitializeExceptionChain+0x63
ntdll.dll!RtlInitializeExceptionChain+0x36
My Current Components:
Core (2011-12-02 15:07:36 UTC)
foobar2000 core 1.1.10
foo_albumlist.dll (2011-12-02 15:06:12 UTC)
Album List 4.5
foo_amipwrapper.dll (2010-01-29 21:32:26 UTC)
AMIP Wrapper 1.01
foo_audioscrobbler.dll (2011-11-22 23:09:52 UTC)
Audioscrobbler 1.4.7
foo_cdda.dll (2011-12-02 15:06:00 UTC)
CD Audio Decoder 3.0
foo_converter.dll (2011-12-02 15:05:44 UTC)
Converter 1.5
foo_dsp_effect.dll (2011-10-02 01:06:09 UTC)
Effect DSP 0.9.2
foo_dsp_resampler.dll (2011-10-02 19:13:40 UTC)
SoX Resampler 0.7.0
foo_dsp_srcresample.dll (2011-10-02 19:13:40 UTC)
Secret Rabbit Code Resampler 0.1
foo_dsp_std.dll (2011-12-02 15:06:12 UTC)
Standard DSP Array 1.0
foo_dsp_xgeq.dll (2012-01-05 21:33:58 UTC)
Graphic Equalizer 0.2.1
foo_facets.dll (2011-10-02 19:13:40 UTC)
Facets 1.0
foo_fileops.dll (2011-12-02 15:05:08 UTC)
File Operations 2.1.3
foo_freedb2.dll (2011-12-02 15:05:08 UTC)
freedb Tagger 0.6.4
foo_input_monkey.dll (2011-10-02 01:06:09 UTC)
Monkey's Audio Decoder 2.1.5
foo_input_std.dll (2011-12-02 15:05:54 UTC)
Standard Input Array 1.0
foo_jesus.dll (2011-10-02 01:06:09 UTC)
Autosave & Autobackup 10
foo_out_asio.dll (2012-01-02 18:47:40 UTC)
ASIO support 2.1
foo_out_ks.dll (2011-10-02 01:06:09 UTC)
Kernel Streaming Output 1.2.2
foo_out_wasapi.dll (2011-10-02 01:06:09 UTC)
WASAPI output support 2.1
foo_playcount.dll (2011-10-02 19:05:40 UTC)
Playback Statistics 3.0.2
foo_rgscan.dll (2011-12-02 15:05:48 UTC)
ReplayGain Scanner 2.1.2
foo_tagbox.dll (2011-10-02 19:13:40 UTC)
TagBox 0.212
foo_ui_columns.dll (2011-10-02 01:26:39 UTC)
Columns UI 0.3.8.8
foo_ui_std.dll (2011-12-02 15:06:24 UTC)
Default User Interface 0.9.5
foo_uie_biography.dll (2011-10-02 19:13:40 UTC)
Biography View 0.4.2.4
foo_uie_console.dll (2011-10-02 19:54:59 UTC)
Console panel 0.4
foo_uie_elplaylist.dll (2011-10-02 19:13:40 UTC)
ELPlaylist 0.6.9.1.2(beta)
foo_uie_esplaylist.dll (2011-10-02 19:13:40 UTC)
EsPlaylist 0.1.3.9
foo_uie_library_tree.dll (2011-10-02 19:13:40 UTC)
Library Tree 0.3.4.6.1
foo_uie_panel_splitter.dll (2011-10-02 19:13:41 UTC)
Panel Stack Splitter 0.3.8.3(alpha)
foo_uie_typefind.dll (2011-10-02 19:54:59 UTC)
Typefind 0.2 beta 2
foo_unpack.dll (2011-12-02 15:05:24 UTC)
ZIP/GZIP/RAR Reader 1.6
foo_unpack_7z.dll (2011-10-02 01:06:09 UTC)
7-Zip reader 1.8
foo_verifier.dll (2011-11-25 14:22:11 UTC)
File Integrity Verifier 1.1
foo_vst.dll (2012-01-05 21:33:30 UTC)
VST 2.4 adapter 0.9.0.3
foo_wave_seekbar.dll (2011-12-14 23:55:36 UTC)
Waveform seekbar 0.2.14.2
And a DxDiag if that helps at all:
System Information
Time of this report: 1/5/2012, 17:13:18
Machine name: G1
Operating System: Windows 7 Ultimate 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.110622-1506)
Language: English (Regional Setting: English)
System Manufacturer: Gigabyte Tecohnology Co., Ltd.
System Model: G1.Assassin2
BIOS: BIOS Date: 12/26/11 20:04:25 Ver: 04.06.04
Processor: Intel® Core i7-3930K CPU @ 3.20GHz (12 CPUs), ~3.2GHz
Memory: 16384MB RAM
Available OS Memory: 16336MB RAM
Page File: 4751MB used, 27919MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Display Tab 2: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Sound Tab 3: No problems found.
Sound Tab 4: No problems found.
Sound Tab 5: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: ATI Radeon HD 5800 Series
Manufacturer: Advanced Micro Devices, Inc.
Chip type: ATI display adapter (0x6898)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_6898&SUBSYS_032E1043&REV_00
Display Memory: 722 MB
Dedicated Memory: 1002 MB
Shared Memory: 3816 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: ASUS VH236H
Monitor Id: ACI23F2
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: DVI
Driver Name: aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64.dll,atidxx64.dll,atidxx64
.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll
Driver File Version: 8.17.0010.1114 (English)
Driver Version: 8.930.10.0
DDI Version: 11
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 12/8/2011 16:53:52, 933888 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
Device Identifier: {D7B71EE2-2BD8-11CF-A977-2423BEC2C535}
Vendor ID: 0x1002
Device ID: 0x6898
SubSys ID: 0x032E1043
Revision ID: 0x0000
Driver Strong Name: oem18.inf:ATI.Mfg.NTamd64.6.1:ati2mtag_Evergreen:8.930.10.0:pci\ven_1002&dev_6898
Rank Of Driver: 00E62001
Video Accel: ModeMPEG2_A ModeMPEG2_C
Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
D3D9 Overlay: Not Supported
DXVA-HD: Not Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Monitor Id: ACI23F2
Output Type: DVI
DDI Version: 11
WHQL Logo'd: n/a
Vendor ID: 0x1002
Device ID: 0x6898
Revision ID: 0x0000
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description: Speakers (Creative SB X-Fi)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_1102&DEV_000B&SUBSYS_A0161458&REV_03
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: ctaud2k.sys
Driver Version: 6.00.0001.1327 (English)
WHQL Logo'd: n/a
Date and Size: 12/1/2010 07:54:50, 699608 bytes
Other Files:
Driver Provider: Creative
HW Accel Level: Basic
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX 2.0 Listen/Src: No, No
I3DL2 Listen/Src: No, No
Sensaura ZoomFX: No
Description: Speakers (ASUS Xonar Essence STX Audio Device)
Default Sound Playback: No
Default Voice Playback: No
Hardware ID: PCI\VEN_13F6&DEV_8788&SUBSYS_835C1043&REV_00
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: cmudaxp.sys
Driver Version: 5.12.0001.0008 (English)
WHQL Logo'd: n/a
Date and Size: 3/10/2011 15:44:18, 2725376 bytes
Other Files:
Driver Provider: ASUSTeK
Cap Flags: 0x0
HW Memory: 0
Sensaura ZoomFX: No
Description: S/PDIF Pass-through Device (ASUS Xonar Essence STX Audio Device)
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: n/a
Other Files:
Cap Flags: 0x0
HW Memory: 0
Sensaura ZoomFX: No
Description: HDMI Out (Creative SB X-Fi)
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: n/a
Other Files:
Cap Flags: 0x0
HW Memory: 0
Sensaura ZoomFX: No
Description: SPDIF Out (Creative SB X-Fi)
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: n/a
Other Files:
Cap Flags: 0x0
HW Memory: 0
Sensaura ZoomFX: No
Sound Capture Devices
Description: Microphone (Orbit/Sphere AF)
Default Sound Capture: Yes
Default Voice Capture: Yes
Driver Name: USBAUDIO.sys
Driver Version: 6.01.7601.17514 (English)
Date and Size: 11/20/2010 22:23:47, 109696 bytes
Cap Flags: 0x0
Format Flags: 0x0
Description: "What U Hear" (Creative SB X-Fi)
Default Sound Capture: No
Default Voice Capture: No
Cap Flags: 0x0
Format Flags: 0x0
Description: Wave (ASUS Xonar Essence STX Audio Device)
Cap Flags: 0x0
Format Flags: 0x0
Description: Line In (ASUS Xonar Essence STX Audio Device)
Cap Flags: 0x0
Format Flags: 0x0
Description: Aux (ASUS Xonar Essence STX Audio Device)
Cap Flags: 0x0
Format Flags: 0x0
Description: Microphone FP (Creative SB X-Fi)
Cap Flags: 0x0
Format Flags: 0x0
Description: Microphone (ASUS Xonar Essence STX Audio Device)
Cap Flags: 0x0
Format Flags: 0x0
Description: Stereo Mix (ASUS Xonar Essence STX Audio Device)
Cap Flags: 0x0
Format Flags: 0x0
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: XBOX 360 For Windows (Controller)
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x045E, 0x028E
FF Driver: n/a
Device Name: G500
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC068
FF Driver: n/a
Device Name: G500
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: G500
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: Razer BlackWidow Ultimate
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x1532, 0x010D
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x1D2D
| Matching Device ID: usb\root_hub20
| Service: usbhub
+-+ Generic USB Hub
| | Vendor/Product ID: 0x8087, 0x0024
| | Matching Device ID: usb\class_09
| | Service: usbhub
Gameport Devices
PS/2 Devices
+ HID Keyboard Device
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
+ Razer BlackWidow Ultimate
| Matching Device ID: hid\vid_1532&pid_010d&mi_00
| Upper Filters: RzSynapse
| Service: kbdhid
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
+ Logitech HID-compliant G500 Gaming Mouse
| Matching Device ID: hid\vid_046d&pid_c068&mi_00
| Upper Filters: LMouFilt
| Lower Filters: LHidFilt
| Service: mouhid
| Matching Device ID: hid\vid_1532&pid_010d&mi_02
| Service: mouhid
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 186.1 GB
Total Space: 244.1 GB
File System: NTFS
Model: SAMSUNG SSD 830 Series ATA Device
Drive: D:
Free Space: 57.1 GB
Total Space: 572.3 GB
File System: NTFS
Model: WDC WD6000HLHX-01JJPV0 ATA Device
Drive: F:
Free Space: 88.5 GB
Total Space: 102.4 GB
File System: NTFS
Model: SYNOLOGY iSCSI Storage SCSI Disk Device
Drive: G:
Free Space: 1146.6 GB
Total Space: 1907.7 GB
File System: NTFS
Model: ST320005 42AS USB Device
Drive: H:
Free Space: 1736.9 GB
Total Space: 2861.6 GB
File System: NTFS
Model: Seagate FA GoFlex Desk USB Device
Drive: E:
Model: HL-DT-ST BDDVDRW CH08LS10 ATA Device
Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7601.17514 (English), , 0 bytes
Drive: J:
Model: MVEH 2301URG SCSI CdRom Device
System Devices
Name: Intel® Xeon® Processor E5 Product Family/Core i7 IIO PCI Express Root Port 1a - 3C02
Device ID: PCI\VEN_8086&DEV_3C02&SUBSYS_50001458&REV_06\3&11583659&0&08
Driver: n/a
Name: Intel® Xeon® Processor E5 Product Family/Core i7 Ring to QuickPath Interconnect Link 1 Performance Monitor - 3C45
Device ID: PCI\VEN_8086&DEV_3C45&SUBSYS_3C451458&REV_06\3&4F11E61&0&9E
Driver: n/a
Name: Intel® C600/X79 series chipset PCI Express Root Port 2 - 1D12
Device ID: PCI\VEN_8086&DEV_1D12&SUBSYS_50011458&REV_B5\3&11583659&0&E1
Driver: n/a
Name: Intel® Xeon® Processor E5 Product Family/Core i7 Integrated Memory Controller System Address Decoder 1 - 3CF5
Device ID: PCI\VEN_8086&DEV_3CF5&SUBSYS_3CE81458&REV_06\3&4F11E61&0&6E
Driver: n/a
Name: Standard AHCI 1.0 Serial ATA Controller
Device ID: PCI\VEN_1B4B&DEV_9172&SUBSYS_B0001458&REV_11\4&EA338CD&0&00E3
Driver: n/a
Name: Intel® Xeon® Processor E5 Product Family/Core i7 QPI Link Reut 1 - 3C94
Device ID: PCI\VEN_8086&DEV_3C94&SUBSYS_3C941458&REV_06\3&4F11E61&0&4C
Driver: n/a
Name: ATI Radeon HD 5800 Series
Device ID: PCI\VEN_1002&DEV_6898&SUBSYS_032E1043&REV_00\4&1CA8CB7D&0&0010
Driver: n/a
Name: Intel® Xeon® Processor E5 Product Family/Core i7 Integrated Memory Controller Channel 0-3 Thermal Control 0 - 3CB0
Device ID: PCI\VEN_8086&DEV_3CB0&SUBSYS_3CB01458&REV_06\3&4F11E61&0&80
Driver: n/a
Name: Intel® Xeon® Processor E5 Product Family/Core i7 Integrated Memory Controller ERROR Registers 3 - 3CB7
Device ID: PCI\VEN_8086&DEV_3CB7&SUBSYS_3CB71458&REV_06\3&4F11E61&0&87
Driver: n/a
Name: Intel® Xeon® Processor E5 Product Family/Core i7 R2PCIe - 3CE4
Device ID: PCI\VEN_8086&DEV_3CE4&SUBSYS_3CE41458&REV_06\3&4F11E61&0&98
Driver: n/a
Name: Intel® Xeon® Processor E5 Product Family/Core i7 Ring to QuickPath Interconnect Link 0 Performance Monitor - 3C44
Device ID: PCI\VEN_8086&DEV_3C44&SUBSYS_3C441458&REV_06\3&4F11E61&0&9D
Driver: n/a
Name: Intel® Xeon® Processor E5 Product Family/Core i7 DMI2 - 3C00
Device ID: PCI\VEN_8086&DEV_3C00&SUBSYS_50001458&REV_06\3&11583659&0&00
Driver: n/a
Name: Intel® C600/X79 series chipset SMBus Host Controller - 1D22
Device ID: PCI\VEN_8086&DEV_1D22&SUBSYS_50011458&REV_05\3&11583659&0&FB
Driver: n/a
Name: Intel® C600/X79 series chipset PCI Express Root Port 1 - 1D10
Device ID: PCI\VEN_8086&DEV_1D10&SUBSYS_50011458&REV_B5\3&11583659&0&E0
Driver: n/a
Name: Intel® Xeon® Processor E5 Product Family/Core i7 Integrated Memory Controller System Address Decoder 0 - 3CF4
Device ID: PCI\VEN_8086&DEV_3CF4&SUBSYS_3CE81458&REV_06\3&4F11E61&0&66
Driver: n/a
Name: Intel® Xeon® Processor E5 Product Family/Core i7 QPI Link Reut 1 - 3C93
Device ID: PCI\VEN_8086&DEV_3C93&SUBSYS_3C931458&REV_06\3&4F11E61&0&4B
Driver: n/a
Device ID: PCI\VEN_1B4B&DEV_9172&SUBSYS_B0001458&REV_11\4&2D0CB998&0&00E0
Driver: n/a
Name: Intel® Xeon® Processor E5 Product Family/Core i7 Integrated Memory Controller Target Address Decoder 4 - 3CAE
Device ID: PCI\VEN_8086&DEV_3CAE&SUBSYS_3CAE1458&REV_06\3&4F11E61&0&7E
Driver: n/a
Name: Intel® Xeon® Processor E5 Product Family/Core i7 Semaphore and Scratchpad Configuration Registers - 3CE3
Device ID: PCI\VEN_8086&DEV_3CE3&SUBSYS_3CE31458&REV_06\3&4F11E61&0&5B
Driver: n/a
Name: Intel® Xeon® Processor E5 Product Family/Core i7 Ring to PCI Express Performance Monitor - 3C43
Device ID: PCI\VEN_8086&DEV_3C43&SUBSYS_3C431458&REV_06\3&4F11E61&0&99
Driver: n/a
Name: Intel® 82801 PCI Bridge - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_50011458&REV_A5\3&11583659&0&F0
Driver: n/a
Name: Intel® C600/X79 series chipset PCI Express Root Port 8 - 1D1E
Device ID: PCI\VEN_8086&DEV_1D1E&SUBSYS_50011458&REV_B5\3&11583659&0&E7
Driver: n/a
Name: Intel® Xeon® Processor E5 Product Family/Core i7 Unicast Register 0 - 3CE8
Device ID: PCI\VEN_8086&DEV_3CE8&SUBSYS_3CE81458&REV_06\3&4F11E61&0&6A
Driver: n/a
Name: Intel® Xeon® Processor E5 Product Family/Core i7 QPI Link 1 - 3C90
Device ID: PCI\VEN_8086&DEV_3C90&SUBSYS_3C901458&REV_06\3&4F11E61&0&48
Driver: n/a
Name: Bigfoot Networks Killer Gaming Adapter
Device ID: PCI\VEN_1957&DEV_C006&SUBSYS_12011A56&REV_10\4&2EF508BE&0&00E4
Driver: n/a
Name: Intel® Xeon® Processor E5 Product Family/Core i7 Integrated Memory Controller Target Address Decoder 3 - 3CAD
Device ID: PCI\VEN_8086&DEV_3CAD&SUBSYS_3CAD1458&REV_06\3&4F11E61&0&7D
Driver: n/a
Name: Intel® Xeon® Processor E5 Product Family/Core i7 Integrated Memory Controller ERROR Registers 2 - 3CB6
Device ID: PCI\VEN_8086&DEV_3CB6&SUBSYS_3CB61458&REV_06\3&4F11E61&0&86
Driver: n/a
Name: Intel® Xeon® Processor E5 Product Family/Core i7 Interrupt Control Registers - 3CE0
Device ID: PCI\VEN_8086&DEV_3CE0&SUBSYS_3CE01458&REV_06\3&4F11E61&0&58
Driver: n/a
Name: Intel® Xeon® Processor E5 Product Family/Core i7 I/O APIC - 3C2C
Device ID: PCI\VEN_8086&DEV_3C2C&SUBSYS_50001458&REV_06\3&11583659&0&2C
Driver: n/a
Name: Intel® C600/X79 series chipset LPC Controller - 1D41
Device ID: PCI\VEN_8086&DEV_1D41&SUBSYS_50011458&REV_05\3&11583659&0&F8
Driver: n/a
Name: Intel® C600/X79 series chipset PCI Express Root Port 7 - 1D1C
Device ID: PCI\VEN_8086&DEV_1D1C&SUBSYS_50011458&REV_B5\3&11583659&0&E6
Driver: n/a
Device ID: PCI\VEN_8086&DEV_3CE8&SUBSYS_3CE81458&REV_06\3&4F11E61&0&69
Driver: n/a
Name: Intel® C600/X79 series chipset 6-Port SATA AHCI Controller - 1D02
Device ID: PCI\VEN_8086&DEV_1D02&SUBSYS_B0021458&REV_05\3&11583659&0&FA
Driver: n/a
Name: Intel® Xeon® Processor E5 Product Family/Core i7 QPI Link Reut 0 - 3C84
Device ID: PCI\VEN_8086&DEV_3C84&SUBSYS_3C841458&REV_06\3&4F11E61&0&44
Driver: n/a
Name: ASUS Xonar Essence STX Audio Device
Device ID: PCI\VEN_13F6&DEV_8788&SUBSYS_835C1043&REV_00\5&C9C9E99&0&2000E1
Driver: n/a
Name: Intel® Xeon® Processor E5 Product Family/Core i7 Integrated Memory Controller Target Address Decoder 2 - 3CAC
Device ID: PCI\VEN_8086&DEV_3CAC&SUBSYS_3CAC1458&REV_06\3&4F11E61&0&7C
Driver: n/a
Name: Intel® Xeon® Processor E5 Product Family/Core i7 Integrated Memory Controller Channel 0-3 Thermal Control 3 - 3CB5
Device ID: PCI\VEN_8086&DEV_3CB5&SUBSYS_3CB51458&REV_06\3&4F11E61&0&85
Driver: n/a
Name: Intel® Xeon® Processor E5 Product Family/Core i7 Power Control Unit 3 - 3CD0
Device ID: PCI\VEN_8086&DEV_3CD0&SUBSYS_3CD01458&REV_06\3&4F11E61&0&53
Driver: n/a
Name: Intel® Xeon® Processor E5 Product Family/Core i7 Control Status and Global Errors - 3C2A
Device ID: PCI\VEN_8086&DEV_3C2A&SUBSYS_50001458&REV_06\3&11583659&0&2A
Driver: n/a
Name: Intel® C600/X79 series chipset PCI Express Virtual Root Port - 1D3E
Device ID: PCI\VEN_8086&DEV_1D3E&SUBSYS_50001458&REV_05\3&11583659&0&88
Driver: n/a
Device ID: PCI\VEN_8086&DEV_3CE8&SUBSYS_3CE81458&REV_06\3&4F11E61&0&68
Driver: n/a
Name: Intel® C600/X79 series chipset PCI Express Root Port 6 - 1D1A
Device ID: PCI\VEN_8086&DEV_1D1A&SUBSYS_50011458&REV_B5\3&11583659&0&E5
Driver: n/a
Name: Fresco Logic xHCI (USB3) Controller FL1009 Series
Device ID: PCI\VEN_1B73&DEV_1009&SUBSYS_50071458&REV_02\4&35DF6229&0&00E6
Driver: n/a
Name: Intel® Xeon® Processor E5 Product Family/Core i7 QPI Link Reut 0 - 3C83
Device ID: PCI\VEN_8086&DEV_3C83&SUBSYS_3C831458&REV_06\3&4F11E61&0&43
Driver: n/a
Name: AF5LSNA6 IDE Controller
Device ID: PCI\VEN_1103&DEV_3410&SUBSYS_06C244EF&REV_01\4&5D18F2DF&0
Driver: n/a
Name: Intel® Xeon® Processor E5 Product Family/Core i7 Integrated Memory Controller Target Address Decoder 1 - 3CAB
Device ID: PCI\VEN_8086&DEV_3CAB&SUBSYS_3CAB1458&REV_06\3&4F11E61&0&7B
Driver: n/a
Name: Intel® Xeon® Processor E5 Product Family/Core i7 Integrated Memory Controller Channel 0-3 Thermal Control 2 - 3CB4
Device ID: PCI\VEN_8086&DEV_3CB4&SUBSYS_3CB41458&REV_06\3&4F11E61&0&84
Driver: n/a
Name: Intel® Xeon® Processor E5 Product Family/Core i7 Power Control Unit 2 - 3CC2
Device ID: PCI\VEN_8086&DEV_3CC2&SUBSYS_3CC21458&REV_06\3&4F11E61&0&52
Driver: n/a
Name: Intel® Xeon® Processor E5 Product Family/Core i7 Address Map, VTd_Misc, System Management - 3C28
Device ID: PCI\VEN_8086&DEV_3C28&SUBSYS_50001458&REV_06\3&11583659&0&28
Driver: n/a
Device ID: PCI\VEN_8086&DEV_3CE8&SUBSYS_3CE81458&REV_06\3&4F11E61&0&62
Driver: n/a
Name: Intel® 6 Series/C200 Series Management Engine Interface - 1D3A
Device ID: PCI\VEN_8086&DEV_1D3A&SUBSYS_1C3A1458&REV_05\3&11583659&0&B0
Driver: n/a
Name: Intel® C600/X79 series chipset PCI Express Root Port 5 - 1D18
Device ID: PCI\VEN_8086&DEV_1D18&SUBSYS_50011458&REV_B5\3&11583659&0&E4
Driver: n/a
Name: Intel® Xeon® Processor E5 Product Family/Core i7 QPI Link 0 - 3C80
Device ID: PCI\VEN_8086&DEV_3C80&SUBSYS_3C801458&REV_06\3&4F11E61&0&40
Driver: n/a
Device ID: PCI\VEN_1B73&DEV_1009&SUBSYS_50071458&REV_02\4&264801C9&0&00E5
Driver: n/a
Name: Creative SB X-Fi
Device ID: PCI\VEN_1102&DEV_000B&SUBSYS_A0161458&REV_03\FFFFFFFFFFFFFFFF00
Driver: n/a
Name: Intel® Xeon® Processor E5 Product Family/Core i7 Integrated Memory Controller Target Address Decoder 0 - 3CAA
Device ID: PCI\VEN_8086&DEV_3CAA&SUBSYS_3CAA1458&REV_06\3&4F11E61&0&7A
Driver: n/a
Name: Intel® Xeon® Processor E5 Product Family/Core i7 Integrated Memory Controller ERROR Registers 1 - 3CB3
Device ID: PCI\VEN_8086&DEV_3CB3&SUBSYS_3CB31458&REV_06\3&4F11E61&0&83
Driver: n/a
Name: Intel® Xeon® Processor E5 Product Family/Core i7 Power Control Unit 1 - 3CC1
Device ID: PCI\VEN_8086&DEV_3CC1&SUBSYS_3CC11458&REV_06\3&4F11E61&0&51
Driver: n/a
Device ID: PCI\VEN_8086&DEV_3CE8&SUBSYS_3CE81458&REV_06\3&4F11E61&0&61
Driver: n/a
Name: Intel® Xeon® Processor E5 Product Family/Core i7 IIO PCI Express Root Port 3a in PCI Express Mode - 3C08
Device ID: PCI\VEN_8086&DEV_3C08&SUBSYS_50001458&REV_06\3&11583659&0&18
Driver: n/a
Name: Intel® C600/X79 series chipset USB2 Enhanced Host Controller #2 - 1D2D
Device ID: PCI\VEN_8086&DEV_1D2D&SUBSYS_50061458&REV_05\3&11583659&0&D0
Driver: n/a
Name: Intel® C600/X79 series chipset PCI Express Root Port 4 - 1D16
Device ID: PCI\VEN_8086&DEV_1D16&SUBSYS_50011458&REV_B5\3&11583659&0&E3
Driver: n/a
Name: Intel® Xeon® Processor E5 Product Family/Core i7 Integrated Memory Controller RAS Registers - 3C71
Device ID: PCI\VEN_8086&DEV_3C71&SUBSYS_3C711458&REV_06\3&4F11E61&0&79
Driver: n/a
Name: Intel® Xeon® Processor E5 Product Family/Core i7 Integrated Memory Controller Registers - 3CA8
Device ID: PCI\VEN_8086&DEV_3CA8&SUBSYS_3CA81458&REV_06\3&4F11E61&0&78
Driver: n/a
Name: PCI standard PCI Express to PCI/PCI-X Bridge
Device ID: PCI\VEN_10B5&DEV_8112&SUBSYS_00000000&REV_AA\4&108B87F3&0&00E1
Driver: n/a
Name: Intel® Xeon® Processor E5 Product Family/Core i7 Integrated Memory Controller ERROR Registers 0 - 3CB2
Device ID: PCI\VEN_8086&DEV_3CB2&SUBSYS_3CB21458&REV_06\3&4F11E61&0&82
Driver: n/a
Name: Intel® Xeon® Processor E5 Product Family/Core i7 Power Control Unit 0 - 3CC0
Device ID: PCI\VEN_8086&DEV_3CC0&SUBSYS_3CC01458&REV_06\3&4F11E61&0&50
Driver: n/a
Device ID: PCI\VEN_8086&DEV_3CE8&SUBSYS_3CE81458&REV_06\3&4F11E61&0&60
Driver: n/a
Name: Intel® Xeon® Processor E5 Product Family/Core i7 IIO PCI Express Root Port 2a - 3C04
Device ID: PCI\VEN_8086&DEV_3C04&SUBSYS_50001458&REV_06\3&11583659&0&10
Driver: n/a
Name: Intel® C600/X79 series chipset USB2 Enhanced Host Controller #1 - 1D26
Device ID: PCI\VEN_8086&DEV_1D26&SUBSYS_50061458&REV_05\3&11583659&0&E8
Driver: n/a
Name: Intel® Xeon® Processor E5 Product Family/Core i7 Processor Home Agent Performance Monitoring - 3C46
Device ID: PCI\VEN_8086&DEV_3C46&SUBSYS_3C461458&REV_06\3&4F11E61&0&71
Driver: n/a
Name: Intel® C600/X79 series chipset PCI Express Root Port 3 - 1D14
Device ID: PCI\VEN_8086&DEV_1D14&SUBSYS_50011458&REV_B5\3&11583659&0&E2
Driver: n/a
Name: Intel® Xeon® Processor E5 Product Family/Core i7 System Address Decoder - 3CF6
Device ID: PCI\VEN_8086&DEV_3CF6&SUBSYS_3CE81458&REV_06\3&4F11E61&0&67
Driver: n/a
Name: Intel® Xeon® Processor E5 Product Family/Core i7 Processor Home Agent - 3CA0
Device ID: PCI\VEN_8086&DEV_3CA0&SUBSYS_3CA01458&REV_06\3&4F11E61&0&70
Driver: n/a
Name: High Definition Audio Controller
Device ID: PCI\VEN_1002&DEV_AA50&SUBSYS_AA501043&REV_00\4&1CA8CB7D&0&0110
Driver: n/a
Name: Intel® Xeon® Processor E5 Product Family/Core i7 Integrated Memory Controller Channel 0-3 Thermal Control 1 - 3CB1
Device ID: PCI\VEN_8086&DEV_3CB1&SUBSYS_3CB11458&REV_06\3&4F11E61&0&81
Driver: n/a
Name: Intel® Xeon® Processor E5 Product Family/Core i7 DDRIO - 3CB8
Device ID: PCI\VEN_8086&DEV_3CB8&SUBSYS_3CB81458&REV_06\3&4F11E61&0&88
Driver: n/a
Name: Intel® Xeon® Processor E5 Product Family/Core i7 QuickPath Interconnect Agent Ring Registers - 3CE6
Device ID: PCI\VEN_8086&DEV_3CE6&SUBSYS_3CE61458&REV_06\3&4F11E61&0&9C
Driver: n/a
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7601.17514
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7601.17514
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7601.17514
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7601.17514
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7601.17514
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
Xiph.Org Theora Decoder,0x00600000,1,1,dsfTheoraDecoder.dll,
Xiph.Org Vorbis Decoder,0x00600000,1,1,dsfVorbisDecoder.dll,
CoreAVC Video Decoder,0x00800200,1,1,CoreAVCDecoder.ax,3.00.0001.0000
ATI Ticker,0x00200000,0,1,Ticker.ax,
DV Muxer,0x00400000,0,0,qdv.dll,6.06.7601.17514
Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7601.17514
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7601.17514
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7601.17514
AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7601.17514
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7601.17514
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7601.17528
Xiph.Org Ogg Muxer,0x00200000,1,0,dsfOggMux.dll,
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7140.0000
Creative Recording Wav_Asio Filter,0x00400000,0,1,AudioRec.ax,1.00.0002.0000
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
MainConcept MPEG Encoder,0x00200000,2,1,mcesmpeg.ax,1.02.7984.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7601.17528
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17514
VHMixerSource,0x00200000,0,1,VHMediaCOM.dll,2.00.0000.0086
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7601.17514
Xiph.Org FLAC Decoder,0x00600000,1,1,dsfFLACDecoder.dll,
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7601.17514
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7601.17514
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7601.17528
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7601.17514
SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17514
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7601.17514
MMACE ProcAmp,0x00200000,0,2,MMACEFilters.dll,
ACDFX Filter,0x00200000,1,1,ACDFX.ax,2.00.0013.0002
DV Splitter,0x00600000,1,2,qdv.dll,6.06.7601.17514
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7601.17514
Haali Media Splitter,0x00800001,0,1,splitter.ax,1.11.0288.0000
Haali Media Splitter (AR),0x00400000,1,1,splitter.ax,1.11.0288.0000
Xiph.Org Theora Encoder,0x00200000,1,1,dsfTheoraEncoder.dll,
Xiph.Org Vorbis Encoder,0x00200000,1,1,dsfVorbisEncoder.dll,
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7601.17514
VHSplitProcSource,0x00200000,0,1,VHMediaCOM.dll,2.00.0000.0086
VHCropResize,0x00200000,1,1,VHMediaCOM.dll,2.00.0000.0086
ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7601.17514
Video Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17514
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7601.17528
Xiph.Org Native FLAC Decoder,0x00600000,0,1,dsfNativeFLACSource.dll,
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.06.7601.17514
Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7601.17514
Xiph.Org Speex Encoder,0x00200000,1,1,dsfSpeexEncoder.dll,
Video Renderer,0x00400000,1,0,quartz.dll,6.06.7601.17514
Xiph.Org Speex Decoder,0x00600000,1,1,dsfSpeexDecoder.dll,
Haali Video Renderer,0x00200000,1,0,dxr.dll,
Xiph.Org FLAC Encoder,0x00200000,1,1,dsfFLACEncoder.dll,
VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7601.17514
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7601.17514
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7601.17514
MMACE SoftEmu,0x00200000,0,2,MMACEFilters.dll,
File writer,0x00200000,1,0,qcap.dll,6.06.7601.17514
Haali Simple Media Splitter,0x00200000,0,1,splitter.ax,1.11.0288.0000
DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7601.17514
MMACE DeInterlace,0x00200000,0,2,MMACEFilters.dll,
Overlay Mixer2,0x00200000,1,1,qdvd.dll,6.06.7601.17514
Haali Matroska Muxer,0x00200000,1,0,splitter.ax,1.11.0288.0000
VHYV12Decoder,0x00200000,1,1,VHMediaCOM.dll,2.00.0000.0086
AVI Draw,0x00600064,9,1,quartz.dll,6.06.7601.17514
RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
VHMultiWriter,0x00200000,1,0,VHMediaCOM.dll,2.00.0000.0086
WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7601.17514
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
VHAudioGain,0x00200000,1,1,VHMediaCOM.dll,2.00.0000.0086
DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7601.17514
VHFrameRateConv,0x00200000,1,1,VHMediaCOM.dll,2.00.0000.0086
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7601.17514
Null Renderer,0x00200000,1,0,qedit.dll,6.06.7601.17514
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7601.17514
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7601.17514
Xiph.Org Ogg Demuxer,0x00600000,1,1,dsfOggDemux2.dll,
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7601.17528
Smart Tee,0x00200000,1,2,qcap.dll,6.06.7601.17514
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.06.7601.17514
AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17514
VHDeinterlace,0x00200000,1,1,VHMediaCOM.dll,2.00.0000.0086
VHYV12Encoder,0x00200000,1,1,VHMediaCOM.dll,2.00.0000.0086
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7601.17514
Wave Parser,0x00400000,1,1,quartz.dll,6.06.7601.17514
MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7601.17514
Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7601.17514
File stream renderer,0x00400000,1,1,quartz.dll,6.06.7601.17514
ACDEncodeQT,0x00200000,0,0,ACDEncodeQT.ax,1.00.0001.0001
VHMultiReader,0x00200000,0,1,VHMediaCOM.dll,2.00.0000.0086
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7601.17528
AVI Mux,0x00200000,1,0,qcap.dll,6.06.7601.17514
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7601.17514
File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7601.17514
File Source (URL),0x00400000,0,1,quartz.dll,6.06.7601.17514
WebM Muxer Filter,0x00200000,2,1,webmmux.dll,0.09.0012.0000
WebM VP8 Decoder Filter,0x00600000,1,1,vp8decoder.dll,0.09.0012.0000
WebM VP8 Encoder Filter,0x00200000,1,1,vp8encoder.dll,0.09.0012.0000
WebM Splitter Filter,0x00600000,1,1,webmsplit.dll,0.09.0012.0000
Haali Video Sink,0x00200000,1,0,splitter.ax,1.11.0288.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7601.17514
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7601.17514
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7601.17669
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7601.17514
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7601.17514
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7601.17514
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.06.7601.17514
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
Microsoft RLE,0x00200000,1,1,qcap.dll,6.06.7601.17514
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.06.7601.17514
VMnc v2,0x00200000,1,1,qcap.dll,6.06.7601.17514
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17514
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17514
GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7601.17514
CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7601.17514
CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7601.17514
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7601.17514
Audio Capture Sources:
Microphone (Orbit/Sphere AF),0x00200000,0,0,qcap.dll,6.06.7601.17514
XSplitBroadcaster,0x00200000,0,1,VHMediaCOM.dll,2.00.0000.0086
"What U Hear" (Creative SB X-Fi,0x00200000,0,0,qcap.dll,6.06.7601.17514
Aux (ASUS Xonar Essence STX Aud,0x00200000,0,0,qcap.dll,6.06.7601.17514
Line In (ASUS Xonar Essence STX,0x00200000,0,0,qcap.dll,6.06.7601.17514
Microphone (ASUS Xonar Essence ,0x00200000,0,0,qcap.dll,6.06.7601.17514
Microphone FP (Creative SB X-Fi,0x00200000,0,0,qcap.dll,6.06.7601.17514
Stereo Mix (ASUS Xonar Essence ,0x00200000,0,0,qcap.dll,6.06.7601.17514
Wave (ASUS Xonar Essence STX Au,0x00200000,0,0,qcap.dll,6.06.7601.17514
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7601.17528
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7601.17514
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7601.17514
SB X-Fi Synth A [0001],0x00200000,1,0,quartz.dll,6.06.7601.17514
SB X-Fi Synth B [0001],0x00200000,1,0,quartz.dll,6.06.7601.17514
WDM Streaming Capture Devices:
,0x00000000,0,0,,
Microphone FP,0x00000000,0,0,,
Line-In,0x00000000,0,0,,
,0x00000000,0,0,,
SB X-Fi Audio [0001],0x00200000,1,1,ksproxy.ax,6.01.7601.17514
SB Live!2K Audio [0001],0x00000000,0,0,,
ASUS Xonar Essence STX Audio,0x00200000,2,2,ksproxy.ax,6.01.7601.17514
ASUS Xonar Essence STX Digital,0x00200000,2,2,ksproxy.ax,6.01.7601.17514
ASUS Xonar Essence STX Audio Wave In,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
QuickCam Orbit/Sphere AF,0x00200000,2,2,ksproxy.ax,6.01.7601.17514
Orbit/Sphere AF,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
WDM Streaming Rendering Devices:
HDMI Out,0x00000000,0,0,,
,0x00000000,0,0,,
,0x00000000,0,0,,
SB X-Fi SpdifOut [0001],0x00000000,0,0,,
SB X-Fi Synth A [0001],0x00200000,1,1,ksproxy.ax,6.01.7601.17514
SB X-Fi Synth B [0001],0x00200000,1,1,ksproxy.ax,6.01.7601.17514
,0x00000000,0,0,,
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7601.17514
Video Capture Sources:
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7601.17669
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7601.17514
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7601.17708
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7601.17708
PTFilter,0x00200000,0,0,EncDec.dll,6.06.7601.17708
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7601.17708
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (Creative SB X-Fi),0x00200000,1,0,quartz.dll,6.06.7601.17514
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7601.17514
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7601.17514
DirectSound: HDMI Out (Creative SB X-Fi),0x00200000,1,0,quartz.dll,6.06.7601.17514
DirectSound: S/PDIF Pass-through Device (ASUS Xonar Essence STX Audio Device),0x00200000,1,0,quartz.dll,6.06.7601.17514
DirectSound: SPDIF Out (Creative SB X-Fi),0x00200000,1,0,quartz.dll,6.06.7601.17514
DirectSound: Speakers (ASUS Xonar Essence STX Audio Device),0x00200000,1,0,quartz.dll,6.06.7601.17514
DirectSound: Speakers (Creative SB X-Fi),0x00200000,1,0,quartz.dll,6.06.7601.17514
S/PDIF Pass-through Device (ASU,0x00200000,1,0,quartz.dll,6.06.7601.17514
Speakers (ASUS Xonar Essence ST,0x00200000,1,0,quartz.dll,6.06.7601.17514
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
Quality Flags: 2576
Enabled:
Force throttling
Allow half deinterlace
Allow scaling
Decode Power Usage: 100
Balanced Flags: 1424
Enabled:
Force throttling
Allow batching
Force half deinterlace
Force scaling
Decode Power Usage: 50
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Decode Power Usage: 0
