Topic: Columns UI (Read 4617461 times) previous topic - next topic
Re: Columns UI
Reply #7950
Sorry I forgot to write, Windows 10 ver.1909.
Re: Columns UI
Reply #7951
Because Columns UI relies on functionality added to the OS in version 2004.
Re: Columns UI
Reply #7952
I understood it well. Thanks for your reply.
Re: Columns UI
Reply #7953
Message for music music:
I have detected an error in Album list panel in the case of having "Show root node" enabled.
For example:
   - I type Shakira, it responds correctly lighting in album list panel "Shakira" and loading all her albums in the playlist view.
   - Then I type an artist starting with A, for example "Abbey" and it lights up the first artist starting with B, in my case B.B.King. It is evident that what happens is that first it processes the A and it goes to process "All Music" and it spends a good time and when it finishes it goes to the first artist that begins by B.
A long time ago I commented that the "All Music" option did not work well and I suggested, if possible, to precede "All Music" with a symbol such as # so that it would be something like this: "#All Music" so that when writing an artist that begins with A it would not process the whole half library.
Re: Columns UI
Reply #7954
Yes, this has been discussed before. One suggestion was delaying the playlist update after each key press, to avoid delays while you're still typing. And yes, the other was to add a character such as a zero-width space to the start of the name.
How big is your library and what CPU do you have?
Re: Columns UI
Reply #7955
Library 6 TB
Intel i7-7567U
Re: Columns UI
Reply #7956
How can i set bold for now playing track on playlist?
Re: Columns UI
Reply #7957
You cannot use more than one font for the playlist columns.
You can only change the color and intensity of each column when the track is playing.
Re: Columns UI
Reply #7958
Can u help me please and fix my cfg? I want to do similar like you but use blue color. Like at my volume control button.
Re: Columns UI
Reply #7959
I'm sorry I can't help you because I have used global variables (Preferences/Columns UI/Playlist View/Globals) and they are quite complicated to handle and have many variants. You have to make the calls to the global variables from the script of each of the columns.
There is a simpler solution that you can do yourself and that consists of placing in the script of each column at the beginning of your current script the following code:
$if(%_isplaying%,$rgb(255,80,0))
This code paints each column blue only when the track is playing and when it is not playing it will be painted with the color you have already defined in colours & fonts
Re: Columns UI
Reply #7960
Thank you it works. But i cant get the same blue, I used color picker and it's rgb(13,124,205). But volume and progress blue looks different. Why?
Re: Columns UI
Reply #7961
Try turning it upside down:
$rgb(205,124,13)
Re: Columns UI
Reply #7962
The seekbar blue in your screenshot is rgb(0, 120, 212). But that's only a small difference. If the text looks darker, it's probably related to subpixel rendering (ClearType). You could try the ClearType tuner in Windows, but you may just have to adjust the text colour until you're happy with it (unless someone else has another suggestion...)
Re: Columns UI
Reply #7963
When i use 0 120 212 it's orange. :D
Re: Columns UI
Reply #7967
still orange
1. When i open new album its blue.
2. When i cllose foobar and run it again and press play its orange.
3. when i open new album/files its blue again
i dont understand whats going on
Re: Columns UI
Reply #7969
Removed. Now playing item is now white. in colours and fonts which item i shoud change to blue?
Re: Columns UI
Reply #7972
I was wrong, sorry. You can't change color of playing item in Colors & Fonts.
The solution is:
$if(%isplaying%,$rgb(0,120,212,0,120,212),)%title%
in display script
$if(%isplaying%,$rgb(r1,g1,b1,r2,g2,b2),) where r1,g1,b1 is the color of the now playing text normally, and r2,g2,b2 is the color of the text when selected
Re: Columns UI
Reply #7973
I have written this script to create a column in Re-Facets that lists the tracks that contain in the title the string " with " (in lower case)
$if($strstr(%title%,' with '),%title%,)
I need to write a similar script to use in the filter search box that is case sensitive.
I have used the following script: title HAS " with "
It lists the tracks whose title contains " with " but it is not case sensitive.
