Topic: Columns UI (Read 4619773 times) previous topic - next topic
Columns UI
Reply #3975
I download the new columns UI recently, the NG playlist is so good. However, it doesn't have horizontal scrollbar, please add a option to display the scrollbar.
It is implemented for next version
Here's a few other feature requests.
1) In the Filter panel (with autosend disabled) there's no visual indication for middle-clicking. Maybe the clicked item should blink or become selected.
2) Scroll to the items added to the NG Playlist from the Filter on "Add to active playlist" action.
3) Support for mouse wheel scrolling when the items are dragged in NG Playlist.
1. I guess it makes sense that it should be selected. I do wonder if anyone uses the middle click to avoid the selection being changed though. I made a note of it anyway I'll look into it a bit more.
2. Yes I think some behaviours there should be changed I'll fix that.
3. I don't believe I am doing anything specifically to disable that so it may not be possible. I'll check this.
Hmm.  Can anyone else reproduce this?  Create a simple layout with a vertical split containing an autohiding toolbar (can be menu, buttons, whatever) and one of the two standard playlist views (hide captions for both).
Then mouse over the toolbar to make it show, and while it's showing, drag the minimize, maximize, or close buttons downward.  As in, click and hold on them and move the mouse down.
Does your mouse freeze up like mine does (until you alt+tab or hit the windows key or do anything to remove focus from the window)?
Weird. o_O
Sounds strange. I'll try and check it anyway.
Weird behaviour.
Selecting several styles from Filter panel results in playlist for repeated entries for tracks that have multiple selected styles tagged.
Indeed, I've known about this, but thanks for the reminder. I'll probably fix it for next version.
Columns UI
Reply #3976
Is there any way to style Filter panels, i.e. change background and text color?
Columns UI
Reply #3977
I'd like to know if it's possible to have the same playlist colors than in default ui? I mean, for each odd row, you have a light grayed background.
That could be a good thing, that: to select the fore/background color for rows, with  a repetition (eg: you set N colors, and the M rows get the M%N color).
Columns UI
Reply #3978
hey music music, I am getting impatient again  how long until your next release please... any idea when 0.9.5 sdk comes out either... is there much in there that could be of benefit to your work?
hope all is well and happy new years!!!
Columns UI
Reply #3979
Not currently, it is just using system settings.
It is configured like that by default.
I am just finishing some stuff up. It should be released sometime this week.
No idea.
Yes, forgetting about other-UIE API from what I've seen in Default UI I believe there are some new APIs that would be useful. I'm not sure though, it depends on how exactly some stuff was implemented.
Yep, happy new year!
Columns UI
Reply #3980
well thats good to see some positives come out for 0.9.5  for columns UI... I was worried that its niche would become limited with the new functionality put into 0.9.5.
looking forward to be able to sort my colums in NG playlist.. this is the only thing preventing me from using colums ui all the time at the moment...
I will not wait patiently until the next release  woohoo
Columns UI
Reply #3981
I have noticed the latest version of your component uses a ridiculous amount of CPU when using NG playlist that is over 10% some times on my Core 2 E4300. DSP is only Advanced Limiter and the config is simple only NG playlist, playlist switcher and album art. The weird thing is this only happens when playing songs (they're oggs and mp3).
Columns UI
Reply #3982
How did you come to the conclusion that it was NG Playlist? The only background stuff that NG Playlist really does currently is update the currently playing item. That doesn't cause any problems here, but just scrolling the playing item off the visible items should prevent that updating if you wish to check. The slowness of that should mostly depend on your formatting strings.
Are you sure it is not visualisation related? I mean, there were some actual changes to the spectrum analyser in last release (though still I didn't observe any significant CPU usage increase).
Columns UI
Reply #3983
Because it does not happen with Default UI and normal Column Playlist. And yes, as you said moving the playing item off screen doesn't exhibit the problem. My setup is nothing complex I think, it's pretty simple and no visualisation over here. Here's my config:
Normally it's hovering around 2-5% then sometimes goes over 10% weird.
The code for Title Column is
$if2($meta(title),$rgb(255,0,0)%filename%) $meta(title kanji)
$if($and($meta_test(album artist),$not($strcmp($meta(album artist),$meta(artist)))),' // '$meta(artist))
$tab()$rgb()
$if(%cwb_queueindex%,
$ifgreater(%cwb_queuelength%,1,
'['%cwb_queueindexes%/%cwb_queuelength%']',
'['%cwb_queueindex%']'))
$if(%isplaying%,%playback_time%/)
%length%
And the code for Type column is
$replace($lower(%codec%),
musepack,mpc,
vorbis,oggV,
flac,flac,
monkey''s audio,ape,
true audio,tta,
wavpack,wv
$tab()
$info(bitrate)
The other columns are just simple line of codes so I don't think those causing this problem.
Columns UI
Reply #3984
I also have this problem. CPU spikes every now and then up to 30% on my old athlon xp 2400+. Windows XP Pro, SP2, all latest patches. columns ui v 0.2.
Columns UI
Reply #3985
OK I found the problem, thanks for the report. It should be fixed for next build.
Does not sound like same problem. No NG Playlist in Columns UI 0.2.
Columns UI
Reply #3987
Alpha 10 now released. Now all the 'Playlist view' options should apply to NG Playlist, unless stated otherwise.
Columns UI
Reply #3988
NG Playlist scrolls very sluggishly in the new version.
The CPU usage when foobar is not minimized became very high, too (~15-30%).
Playlist settings are at their default values here, except for the grouping and some disabled columns.
Columns UI
Reply #3989
Hmm yeah seems your right (about CPU usage), I was on a playlist without any groups were it seems less pronounced. I'll check this, thanks for reporting.
What method are you using to scroll were you see that problem?
Columns UI
Reply #3990
Take two: alpha 10 v2 released. Optimised/fixed the suboptimal rendering which was causing the extra CPU usage in NG Playlist.
Columns UI
Reply #3992
The new version crashed Foobar and now it can no longer even initialize columnsui...
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 0409E546h
Access violation, operation: read, address: 0004000Eh
Call path:
entry=>user_interface::init
Code bytes (0409E546h):
0409E506h:  8B FB E8 73 D3 FC FF 5F 5E 5D 5B 83 C4 0C C2 04
0409E516h:  00 CC CC CC CC CC CC CC CC CC 8B 00 85 C0 74 0A
0409E526h:  8B 50 08 8D 48 08 8B 02 FF E0 C3 CC CC CC CC CC
0409E536h:  CC CC CC CC CC CC CC CC CC CC C7 06 00 00 00 00
0409E546h:  8B 00 89 06 85 C0 74 0A 83 C0 04 50 FF 15 E0 00
0409E556h:  12 04 8B C6 C3 CC CC CC CC CC 6A FF 68 EB 16 11
0409E566h:  04 64 A1 00 00 00 00 50 51 56 57 A1 A0 E0 13 04
0409E576h:  33 C4 50 8D 44 24 10 64 A3 00 00 00 00 C7 44 24
Stack (0013F56Ch):
0013F54Ch:  8A1AACE0 00000000 00000000 B4DD59CC
0013F55Ch:  80535540 B4DD59F8 7FFDE700 00000000
0013F56Ch:  041020DD 311F54F7 0417A388 00000000
0013F57Ch:  00000014 0110007B 00000292 00000000
0013F58Ch:  00000001 0417A388 0A010BA9 00F00021
0013F59Ch:  0013F5B0 7FFDE000 00000000 7E41C257
0013F5ACh:  000908AC 00000000 00000000 00000014
0013F5BCh:  00000010 0110007B 0013F654 773F605E
0013F5CCh:  0A010BA9 0013F614 00000001 00000000
0013F5DCh:  001C5328 0A010BA9 77F161A2 00000000
0013F5ECh:  00FFFFFF 7E423DCE 00000000 0013F614
0013F5FCh:  77F161C8 00000000 00FFFFFF 00000000
0013F60Ch:  00000000 000801C4 00000000 00000000
0013F61Ch:  00000014 00000010 7E4188D1 0013F65C
0013F62Ch:  0041C487 FFFFFFFF 000908D0 FFFFFFFF
0013F63Ch:  010908A2 00000000 7E41B6A3 0013F984
0013F64Ch:  FFFFFC18 FFFFFFB3 00000000 00000003
0013F65Ch:  00000000 00000000 00000107 00000293
0013F66Ch:  0013F9F0 0410F3C4 FFFFFFFF 0013F9FC
0013F67Ch:  04109A28 850116C6 0013F9E0 00000107
Registers:
EAX: 0004000E, EBX: 00000000, ECX: 0004000E, EDX: 00000000
ESI: 0013F5F4, EDI: 000908D0, EBP: 0013F678, ESP: 0013F56C
Crash location: "foo_ui_columns", loaded at 04060000h - 04160000h
Loaded modules:
foobar2000   loaded at 00400000h - 0051E000h
ntdll loaded at 7C900000h - 7C9B0000h
kernel32 loaded at 7C800000h - 7C8F5000h
COMCTL32 loaded at 773D0000h - 774D3000h
msvcrt   loaded at 77C10000h - 77C68000h
ADVAPI32 loaded at 77DD0000h - 77E6B000h
RPCRT4   loaded at 77E70000h - 77F02000h
Secur32   loaded at 77FE0000h - 77FF1000h
GDI32 loaded at 77F10000h - 77F57000h
USER32   loaded at 7E410000h - 7E4A0000h
SHLWAPI   loaded at 77F60000h - 77FD6000h
SHELL32   loaded at 7C9C0000h - 7D1D7000h
ole32 loaded at 774E0000h - 7761D000h
shared   loaded at 10000000h - 1002A000h
COMDLG32 loaded at 763B0000h - 763F9000h
IMM32 loaded at 76390000h - 763AD000h
LPK   loaded at 629C0000h - 629C9000h
USP10 loaded at 74D90000h - 74DFB000h
uxtheme   loaded at 5AD70000h - 5ADA8000h
CopHookInst   loaded at 00A80000h - 00A8B000h
MSCTF loaded at 74720000h - 7476B000h
RTSUltraMonHook   loaded at 18800000h - 18836000h
apphelp   loaded at 77B40000h - 77B62000h
msctfime loaded at 755C0000h - 755EE000h
CLBCATQ   loaded at 76FD0000h - 7704F000h
COMRes   loaded at 77050000h - 77115000h
OLEAUT32 loaded at 77120000h - 771AB000h
VERSION   loaded at 77C00000h - 77C08000h
imjp81   loaded at 3A700000h - 3A756000h
imjp81k   loaded at 3A600000h - 3A6D0000h
foo_albumlist loaded at 00CC0000h - 00D25000h
foo_cdda loaded at 00D50000h - 00D85000h
foo_converter loaded at 00DB0000h - 00E15000h
foo_dsp_crossfader   loaded at 00E40000h - 00E9E000h
libmmd   loaded at 00EB0000h - 0115F000h
MSVCR80   loaded at 78130000h - 781CB000h
foo_dsp_std   loaded at 01180000h - 011C7000h
foo_fileops   loaded at 011F0000h - 01237000h
foo_freedb2   loaded at 01260000h - 012A1000h
foo_gep   loaded at 012D0000h - 0136C000h
MSIMG32   loaded at 76380000h - 76385000h
foo_input_monkey loaded at 01390000h - 013D9000h
foo_input_std loaded at 01400000h - 01525000h
foo_lock_ex   loaded at 01550000h - 01569000h
foo_midi loaded at 01580000h - 0162A000h
foo_oddcastv3 loaded at 01650000h - 0171F000h
WINMM loaded at 76B40000h - 76B6D000h
BASS loaded at 01730000h - 01770000h
MSACM32   loaded at 77BE0000h - 77BF5000h
WINSPOOL loaded at 73000000h - 73026000h
WININET   loaded at 771B0000h - 7725A000h
CRYPT32   loaded at 77A80000h - 77B14000h
MSASN1   loaded at 77B20000h - 77B32000h
WS2_32   loaded at 71AB0000h - 71AC7000h
WS2HELP   loaded at 71AA0000h - 71AA8000h
vorbis   loaded at 01770000h - 0187F000h
ogg   loaded at 01880000h - 01888000h
libFLAC   loaded at 01890000h - 018B3000h
pthreadVSE   loaded at 018C0000h - 018CD000h
WSOCK32   loaded at 71AD0000h - 71AD9000h
foo_playcount loaded at 019C0000h - 019E5000h
foo_prettypop loaded at 01A20000h - 01A6D000h
mscoree   loaded at 79000000h - 79045000h
msvcm80   loaded at 7C4C0000h - 7C53D000h
mscorwks loaded at 79E70000h - 7A3D6000h
mscorlib.ni   loaded at 790C0000h - 79B90000h
mscorjit loaded at 79060000h - 790B3000h
rsaenh   loaded at 0FFD0000h - 0FFF8000h
foo_rgscan   loaded at 03FC0000h - 04010000h
foo_uie_quicksearch   loaded at 04010000h - 04056000h
foo_ui_columns   loaded at 04060000h - 04160000h
foo_ui_std   loaded at 04180000h - 04233000h
gdiplus   loaded at 4EC50000h - 4EDF3000h
foo_unpack   loaded at 04270000h - 0429D000h
foo_vis_projectM loaded at 042C0000h - 04331000h
OPENGL32 loaded at 5ED00000h - 5EDCC000h
GLU32 loaded at 68B20000h - 68B40000h
DDRAW loaded at 73760000h - 737A9000h
DCIMAN32 loaded at 73BC0000h - 73BC6000h
IMJPCD   loaded at 3B100000h - 3B11B000h
imagehlp loaded at 76C90000h - 76CB8000h
DBGHELP   loaded at 59A60000h - 59B01000h
Stack dump analysis:
Address: 041020DDh, location: "foo_ui_columns", loaded at 04060000h - 04160000h
Address: 0110007Bh, location: "libmmd", loaded at 00EB0000h - 0115F000h
Symbol: "_csqrtq_f90" (+0024D73Fh)
Address: 00F00021h, location: "libmmd", loaded at 00EB0000h - 0115F000h
Symbol: "_csqrtq_f90" (+0004D6E5h)
Address: 7E41C257h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "FillRect" (+00000000h)
Address: 773F605Eh, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal384" (+0000A1BEh)
Address: 77F161A2h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "CreateCompatibleDC" (+000001B2h)
Address: 00FFFFFFh, location: "libmmd", loaded at 00EB0000h - 0115F000h
Symbol: "_csqrtq_f90" (+0014D6C3h)
Address: 7E423DCEh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetDlgItem" (+00000000h)
Address: 77F161C8h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "CreateSolidBrush" (+00000013h)
Address: 7E4188D1h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetWindowLongW" (+0000002Bh)
Address: 0041C487h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 010908A2h, location: "libmmd", loaded at 00EB0000h - 0115F000h
Symbol: "_csqrtq_f90" (+001DDF66h)
Address: 7E41B6A3h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "OffsetRect" (+00000072h)
Address: 0410F3C4h, location: "foo_ui_columns", loaded at 04060000h - 04160000h
Address: 04109A28h, location: "foo_ui_columns", loaded at 04060000h - 04160000h
Address: 773F65E1h, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal384" (+0000A741h)
Address: 7E418734h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetDC" (+0000006Dh)
Address: 7E418BD9h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetWindowThreadProcessId" (+00000159h)
Address: 7E41885Ah, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetDC" (+00000193h)
Address: 7E41882Ah, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetDC" (+00000163h)
Address: 7E440457h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DeregisterShellHookWindow" (+000001CFh)
Address: 7E418830h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetDC" (+00000169h)
Address: 7E41C63Fh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "IsWindowUnicode" (+000000A1h)
Address: 0401B380h, location: "foo_uie_quicksearch", loaded at 04010000h - 04056000h
Address: 7E41C665h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "CallWindowProcW" (+0000001Bh)
Address: 0401B3B8h, location: "foo_uie_quicksearch", loaded at 04010000h - 04056000h
Address: 7E4194BEh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetWindowLongA" (+00000061h)
Address: 7E41B42Dh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DefWindowProcW" (+000000F1h)
Address: 7E41B3F9h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DefWindowProcW" (+000000BDh)
Address: 7E470088h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E41B3CCh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DefWindowProcW" (+00000090h)
Address: 7E41B3A7h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DefWindowProcW" (+0000006Bh)
Address: 7E41B3B0h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DefWindowProcW" (+00000074h)
Address: 0409001Fh, location: "foo_ui_columns", loaded at 04060000h - 04160000h
Address: 04098E6Ah, location: "foo_ui_columns", loaded at 04060000h - 04160000h
Address: 773E1ED7h, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "RemoveWindowSubclass" (+000001ABh)
Address: 773E206Ch, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "DefSubclassProc" (+00000046h)
Address: 7744E0C2h, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal389" (+000028DFh)
Address: 7E41F896h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "CallNextHookEx" (+0000003Bh)
Address: 0185000Fh, location: "vorbis", loaded at 01770000h - 0187F000h
Address: 018A0021h, location: "libFLAC", loaded at 01890000h - 018B3000h
Symbol: "FLAC__stream_decoder_seek_absolute" (+000027B1h)
Address: 0410FA78h, location: "foo_ui_columns", loaded at 04060000h - 04160000h
Address: 040DDD35h, location: "foo_ui_columns", loaded at 04060000h - 04160000h
Address: 040DDBA0h, location: "foo_ui_columns", loaded at 04060000h - 04160000h
Address: 7E41B51Ch, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DefWindowProcW" (+000001E0h)
Address: 7E418816h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetDC" (+0000014Fh)
Address: 7E41B4C0h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DefWindowProcW" (+00000184h)
Address: 7E41D8A4h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "ShowWindow" (+00000000h)
Address: 7E41B4D0h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DefWindowProcW" (+00000194h)
Address: 7E41B50Ch, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DefWindowProcW" (+000001D0h)
Address: 7C90EAE3h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "KiUserCallbackDispatcher" (+00000013h)
Address: 7E41B473h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DefWindowProcW" (+00000137h)
Address: 7E41BF78h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "RedrawWindow" (+0000000Ch)
Address: 040A28B5h, location: "foo_ui_columns", loaded at 04060000h - 04160000h
Address: 004EEFC8h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0413FEF4h, location: "foo_ui_columns", loaded at 04060000h - 04160000h
Address: 004EAF74h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 040A0580h, location: "foo_ui_columns", loaded at 04060000h - 04160000h
Address: 04060000h, location: "foo_ui_columns", loaded at 04060000h - 04160000h
Address: 04125278h, location: "foo_ui_columns", loaded at 04060000h - 04160000h
Address: 1000263Ah, location: "shared", loaded at 10000000h - 1002A000h
Symbol: "uPrintCrashInfo_SetDumpPath" (+000000CAh)
Address: 04118A61h, location: "foo_ui_columns", loaded at 04060000h - 04160000h
Address: 004CD528h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 00468132h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0042B9F9h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004C2C47h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0042C416h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 00468039h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004AE3CFh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0042CBE2h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004D0F34h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 00400000h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 7C90EE18h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "strchr" (+00000117h)
Address: 004A08F3h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0049AF90h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0049ED48h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004C8258h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004B4775h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0042CF49h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0049BFCEh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004993B1h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004993ABh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004BAF9Ch, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004B9600h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004993BFh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004B4B5Fh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0049AD3Fh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 7C816FD7h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "RegisterWaitForInputIdle" (+00000049h)
Address: 7C839AA8h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "ValidateLocale" (+000002B0h)
Address: 7C816FE0h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "RegisterWaitForInputIdle" (+00000052h)
Address: 0049ADAAh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004E0049h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004B0063h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 00500069h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 00410072h, location: "foobar2000", loaded at 00400000h - 0051E000h
Version info:
foobar2000 v0.9.5
UNICODE
Windows 5.1
Additional info:
ReplayGain Scanner 2.0.2  (foo_rgscan)
RAR reader 1.1  (foo_unpack)
Game Emu Player 1.5  (foo_gep)
Album List 4.1  (foo_albumlist)
freedb Tagger 0.5.2.1  (foo_freedb2)
CD Audio Decoder 2.1.2  (foo_cdda)
projectM visualization 1.97.6.2  (foo_vis_projectM)
Playback Statistics 2.0  (foo_playcount)
Converter 1.0.2  (foo_converter)
foobar2000 core 0.9.5  (Core)
Standard DSP Array 1.0  (foo_dsp_std)
Pause on Lock (extended) 1.0  (foo_lock_ex)
File Operations 2.0  (foo_fileops)
OddcastV3 3.x  (foo_oddcastv3)
Pretty Popup 1.2.3  (foo_prettypop)
MIDI synthesizer host 1.7  (foo_midi)
Gapless Crossfader 0.3.3.4 (Intel SSE)  (foo_dsp_crossfader)
Default User Interface 0.9.5  (foo_ui_std)
Columns UI 0.2.1 alpha 10 v2  (foo_ui_columns)
Monkey's Audio decoder 2.1.1  (foo_input_monkey)
ZIP/GZIP reader 1.0  (foo_unpack)
Quick Search Toolbar 2.8l  (foo_uie_quicksearch)
(edit: codebox'd. thanks 4nt1)
Columns UI
Reply #3993
I too have recieved an error
foobar crashes then i restart and it works for the time being...
all i was doing was managing some playlists
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 048C590Ch
Access violation, operation: read, address: FFFFFFFCh
Call path:
entry=>app_mainloop=>on_items_removed
Code bytes (048C590Ch):
048C58CCh:  00 50 C6 84 24 FC 01 00 00 07 E8 35 05 00 00 C7
048C58DCh:  84 24 F8 01 00 00 06 00 00 00 F6 44 24 14 02 74
048C58ECh:  0F 83 64 24 14 FD 8D 4C 24 34 51 E8 D4 99 FF FF
048C58FCh:  8B B4 24 A8 00 00 00 8B 54 24 20 8B 42 18 2B F7
048C590Ch:  8B 74 B0 FC 83 C6 1C 56 8D 84 24 04 01 00 00 E8
048C591Ch:  F0 9B 00 00 47 83 C4 04 3B 7C 24 28 0F 82 42 FE
048C592Ch:  FF FF 89 5C 24 28 39 5C 24 30 0F 86 54 04 00 00
048C593Ch:  89 5C 24 20 89 5C 24 24 38 5C 24 19 74 71 8D 8C
Stack (0012E484h):
0012E464h:  88EDA2A4 BF827A00 B59C35B0 B59C35B0
0012E474h:  BF800B2B 88AFB020 BF827B3A BC88B730
0012E484h:  BE3C79DC 049CB860 00000000 00000000
0012E494h:  530114A1 00000000 00010000 049CB860
0012E4A4h:  0934CAC0 7E41B3E9 00000001 00000000
0012E4B4h:  00000008 0012EA64 00000000 7E418BC9
0012E4C4h:  7E471088 00000000 0012E508 7E41B3BC
0012E4D4h:  7E41B397 008D074A 049CB860 0012EA64
0012E4E4h:  00000000 00000001 00000000 0012E4D8
0012E4F4h:  00000014 0012E884 7E440477 7E41B3A0
0012E504h:  FFFFFFFF 049731EC 0012E530 00000000
0012E514h:  0497301C 09304B20 00000000 00000040
0012E524h:  00000000 00000001 00000000 049731CC
0012E534h:  0012E53C DCBAAB00 04973038 00000000
0012E544h:  00000000 00000000 00000014 00000000
0012E554h:  00000000 7E41884A 00000000 00000000
0012E564h:  00000000 00000000 0497301C 09525F00
0012E574h:  00000015 00000020 00000004 0934CACC
0012E584h:  FF000000 FBFBFFFF 8DA4C2FB D5000000
0012E594h:  0000E1DE 00000000 00000000 00300000
Registers:
EAX: 00000000, EBX: 00000000, ECX: 0000D5DE, EDX: 0934CAC0
ESI: 00000000, EDI: 00000000, EBP: 0012E680, ESP: 0012E484
Crash location: "foo_ui_columns", loaded at 048B0000h - 049B0000h
Loaded modules:
RPCRT4                          loaded at 77E70000h - 77F01000h
USER32                          loaded at 7E410000h - 7E4A1000h
RocketDock                      loaded at 003D0000h - 003E2000h
PSAPI                            loaded at 76BF0000h - 76BFB000h
MSCTF                            loaded at 74720000h - 7476C000h
foo_abx                          loaded at 00AC0000h - 00AF3000h
foo_albumlist                    loaded at 00B20000h - 00B85000h
foo_audioscrobbler              loaded at 00BB0000h - 00BE0000h
foo_burninate                    loaded at 00C40000h - 00C77000h
foo_cdda                        loaded at 00CA0000h - 00CD5000h
foo_converter                    loaded at 00D00000h - 00D65000h
foo_cwbowron                    loaded at 00D90000h - 00DB8000h
foo_cwb_hooks                    loaded at 00DF0000h - 00E3C000h
foo_dbsearch                    loaded at 00E60000h - 00ED5000h
foo_dirwatch                    loaded at 00F00000h - 00F2E000h
foo_discogs                      loaded at 00F50000h - 00FF1000h
foo_dockable_panels              loaded at 01090000h - 010C4000h
foo_dop                          loaded at 010F0000h - 01186000h
SETUPAPI                        loaded at 77920000h - 77A13000h
foo_dsp_continuator              loaded at 011B0000h - 011DF000h
foo_dsp_std                      loaded at 011F0000h - 01237000h
foo_dsp_vlevel                  loaded at 01260000h - 01284000h
foo_facets                      loaded at 012B0000h - 01330000h
foo_fileops                      loaded at 01350000h - 01397000h
foo_freedb2                      loaded at 013C0000h - 01401000h
foo_g15lcd                      loaded at 01430000h - 01460000h
foo_input_shorten                loaded at 01480000h - 014AE000h
foo_input_std                    loaded at 014D0000h - 015F5000h
foo_lnk                          loaded at 01620000h - 01639000h
foo_masstag                      loaded at 01660000h - 016B0000h
foo_msnalt                      loaded at 016D0000h - 016E9000h
foo_navigator                    loaded at 01710000h - 01744000h
foo_out_asio                    loaded at 01770000h - 0179F000h
foo_out_ks                      loaded at 017C0000h - 017EA000h
foo_playcount                    loaded at 01810000h - 01835000h
foo_playlist_bind                loaded at 01860000h - 01885000h
foo_playlist_manager            loaded at 018A0000h - 018E6000h
foo_pqview                      loaded at 01910000h - 01938000h
foo_quicktag                    loaded at 01960000h - 0199E000h
foo_random                      loaded at 019C0000h - 019FF000h
foo_rgscan                      loaded at 01A20000h - 01A70000h
foo_run                          loaded at 01A90000h - 01ABB000h
foo_scrobblecharts              loaded at 01AE0000h - 01B13000h
WININET                          loaded at 42C10000h - 42CDF000h
Normaliz                        loaded at 01B30000h - 01B39000h
iertutil                        loaded at 42990000h - 429D5000h
foo_uie_albumart                loaded at 01D60000h - 01D9D000h
foo_uie_albumlist                loaded at 01DC0000h - 01E03000h
foo_uie_console                  loaded at 01E30000h - 01E4B000h
foo_uie_explorer                loaded at 01E70000h - 01EAD000h
foo_uie_peakmeter                loaded at 01ED0000h - 01F03000h
foo_uie_queuemanager            loaded at 01F30000h - 01F69000h
System.ni                        loaded at 7A440000h - 7AC06000h
System.Drawing.ni                loaded at 7ADE0000h - 7AF6C000h
foo_uie_quicksearch              loaded at 045C0000h - 04607000h
foo_uie_tabs                    loaded at 04740000h - 04766000h
foo_uie_typefind                loaded at 04780000h - 047B0000h
foo_uie_vis_channel_spectrum    loaded at 047D0000h - 047FB000h
foo_uie_vis_egoh                loaded at 04820000h - 0483D000h
foo_uie_wsh_panel                loaded at 04850000h - 04886000h
foo_ui_columns                  loaded at 048B0000h - 049B0000h
foo_ui_std                      loaded at 049D0000h - 04A83000h
foo_unpack                      loaded at 04AB0000h - 04ADD000h
foo_utils                        loaded at 04B00000h - 04B79000h
foo_vis_shpeck                  loaded at 04BA0000h - 04BE0000h
foo_whatsnew                    loaded at 04C00000h - 04C31000h
foo_winamp_spam                  loaded at 04C60000h - 04C7F000h
dciman32                        loaded at 73BC0000h - 73BC6000h
WINTRUST                        loaded at 76C30000h - 76C5E000h
IMAGEHLP                        loaded at 76C90000h - 76CB8000h
LgLcdApi                        loaded at 06D10000h - 06D25000h
netapi32                        loaded at 5B860000h - 5B8B5000h
appHelp                          loaded at 77B40000h - 77B62000h
ieframe                          loaded at 42EF0000h - 434BD000h
urlmon                          loaded at 42CF0000h - 42E17000h
mlang                            loaded at 75CF0000h - 75D81000h
Address: 7E41B3E9h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Address: 7E418BC9h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Address: 7E471088h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Address: 7E41B3BCh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Address: 7E41B397h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Address: 7E440477h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Address: 7E41B3A0h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Address: 049731ECh, location: "foo_ui_columns", loaded at 048B0000h - 049B0000h
Address: 0497301Ch, location: "foo_ui_columns", loaded at 048B0000h - 049B0000h
Address: 049731CCh, location: "foo_ui_columns", loaded at 048B0000h - 049B0000h
Address: 04973038h, location: "foo_ui_columns", loaded at 048B0000h - 049B0000h
Address: 7E41884Ah, location: "USER32", loaded at 7E410000h - 7E4A1000h
Address: 7E4188CAh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetWindowLongW" (+00000034h)
Address: 0495FA78h, location: "foo_ui_columns", loaded at 048B0000h - 049B0000h
Address: 0492DD35h, location: "foo_ui_columns", loaded at 048B0000h - 049B0000h
Address: 00411D91h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 00411D9Eh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004ABC49h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 048BC3BDh, location: "foo_ui_columns", loaded at 048B0000h - 049B0000h
Address: 0496726Ah, location: "foo_ui_columns", loaded at 048B0000h - 049B0000h
Address: 048CED29h, location: "foo_ui_columns", loaded at 048B0000h - 049B0000h
Address: 00450C74h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 049367D2h, location: "foo_ui_columns", loaded at 048B0000h - 049B0000h
Address: 04979720h, location: "foo_ui_columns", loaded at 048B0000h - 049B0000h
Address: 04972344h, location: "foo_ui_columns", loaded at 048B0000h - 049B0000h
Address: 048C6593h, location: "foo_ui_columns", loaded at 048B0000h - 049B0000h
Address: 04967A20h, location: "foo_ui_columns", loaded at 048B0000h - 049B0000h
Address: 04952387h, location: "foo_ui_columns", loaded at 048B0000h - 049B0000h
Address: 773EAFF1h, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal414" (+00000FB4h)
Address: 773EABE2h, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal414" (+00000BA5h)
Address: 7E41881Ah, location: "USER32", loaded at 7E410000h - 7E4A1000h
Address: 77F15E39h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "SetBkColor" (+00000000h)
Address: 00460752h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0495F3C4h, location: "foo_ui_columns", loaded at 048B0000h - 049B0000h
Address: 04959A28h, location: "foo_ui_columns", loaded at 048B0000h - 049B0000h
Address: 7E418B16h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetWindowThreadProcessId" (+000000A6h)
Address: 0492DBA0h, location: "foo_ui_columns", loaded at 048B0000h - 049B0000h
Address: 7E4188C1h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Address: 77413784h, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal384" (+000278E4h)
Address: 774132F3h, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal384" (+00027453h)
Address: 7E41B8F3h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "SendMessageW" (+00000049h)
Address: 7E418724h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Address: 7E41B4C0h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Address: 7E418820h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Address: 7E41D167h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "EnumDisplayMonitors" (+0000021Ch)
Address: 7E41B923h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "IsWindow" (+00000000h)
Address: 5AD71AF6h, location: "uxtheme", loaded at 5AD70000h - 5ADA8000h
Address: 7E41949Ah, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetWindowLongA" (+0000004Dh)
Address: 7E418806h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Address: 7E41B4B0h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Address: 7E41B4BBh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "DefWindowProcW" (+0000018Fh)
Address: 7E41B4FCh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Address: 7E41B463h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Address: 7E41D827h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "UpdateWindow" (+00000046h)
Address: 7E41D812h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "UpdateWindow" (+00000031h)
Address: 04951555h, location: "foo_ui_columns", loaded at 048B0000h - 049B0000h
Address: 0112EE8Ch, location: "foo_dop", loaded at 010F0000h - 01186000h
Address: 0495FA00h, location: "foo_ui_columns", loaded at 048B0000h - 049B0000h
Address: 04959889h, location: "foo_ui_columns", loaded at 048B0000h - 049B0000h
Address: 77F53020h, location: "GDI32", loaded at 77F10000h - 77F57000h
Address: 77F17E31h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "GetTextMetricsW" (+00000068h)
Address: 77F17E41h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "GetTextMetricsW" (+00000078h)
Address: 77F17E58h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "GetTextMetricsW" (+0000008Fh)
Address: 77F18444h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "GetTextCharsetInfo" (+00000000h)
Address: 7E41EEC5h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "DrawTextExW" (+00000295h)
Address: 77F160ABh, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "CreateCompatibleDC" (+000000BBh)
Address: 77F17A89h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "ExtSelectClipRgn" (+00000205h)
Address: 77F17A98h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "ExtSelectClipRgn" (+00000214h)
Address: 5AD753A4h, location: "uxtheme", loaded at 5AD70000h - 5ADA8000h
Symbol: "Ordinal44" (+0000096Bh)
Address: 5AD753FCh, location: "uxtheme", loaded at 5AD70000h - 5ADA8000h
Symbol: "Ordinal44" (+000009C3h)
Address: 7E41DDE8h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "TrackMouseEvent" (+0000011Ah)
Address: 7E41EC4Eh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "DrawTextExW" (+0000001Eh)
Address: 5AD72E36h, location: "uxtheme", loaded at 5AD70000h - 5ADA8000h
Symbol: "DrawThemeBackground" (+00000247h)
Address: 7C809E21h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "IsBadReadPtr" (+00000000h)
Address: 5AD7153Dh, location: "uxtheme", loaded at 5AD70000h - 5ADA8000h
Address: 5AD7225Dh, location: "uxtheme", loaded at 5AD70000h - 5ADA8000h
Address: 5AD72271h, location: "uxtheme", loaded at 5AD70000h - 5ADA8000h
Address: 5AD7221Eh, location: "uxtheme", loaded at 5AD70000h - 5ADA8000h
Address: 5AD730A3h, location: "uxtheme", loaded at 5AD70000h - 5ADA8000h
Symbol: "DrawThemeText" (+000000ABh)
Address: 7741A901h, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal384" (+0002EA61h)
Address: 7E41DEE5h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetWindowInfo" (+00000069h)
Address: 7E41DF49h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetWindowInfo" (+000000CDh)
Address: 7E41C2A7h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "IsZoomed" (+0000000Dh)
Address: 5AD75185h, location: "uxtheme", loaded at 5AD70000h - 5ADA8000h
Symbol: "Ordinal44" (+0000074Ch)
Address: 5AD752D7h, location: "uxtheme", loaded at 5AD70000h - 5ADA8000h
Symbol: "Ordinal44" (+0000089Eh)
Address: 5AD75302h, location: "uxtheme", loaded at 5AD70000h - 5ADA8000h
Symbol: "Ordinal44" (+000008C9h)
Address: 5AD8CC7Bh, location: "uxtheme", loaded at 5AD70000h - 5ADA8000h
Symbol: "GetThemeSysColor" (+000000F9h)
Address: 7E41B3C2h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "DefWindowProcW" (+00000096h)
Address: 5AD71B3Dh, location: "uxtheme", loaded at 5AD70000h - 5ADA8000h
Address: 5AD765ACh, location: "uxtheme", loaded at 5AD70000h - 5ADA8000h
Symbol: "DrawThemeBackgroundEx" (+00001154h)
Address: 7E41BAFDh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetPropW" (+0000003Ah)
Address: 0495B730h, location: "foo_ui_columns", loaded at 048B0000h - 049B0000h
Address: 0495B747h, location: "foo_ui_columns", loaded at 048B0000h - 049B0000h
Address: 5AD72CABh, location: "uxtheme", loaded at 5AD70000h - 5ADA8000h
Symbol: "DrawThemeBackground" (+000000BCh)
Address: 7C910738h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+00000164h)
Address: 7C910732h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+0000015Eh)
Address: 7C9106ABh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+000000D7h)
Address: 7C9106EBh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+00000117h)
Version info:
foobar2000 v0.9.5
UNICODE
Windows 5.1
Additional info:
iPod manager 0.5.3 TEST  (foo_dop)
Logitech G15 LCD Display 0.3a  (foo_g15lcd)
ASIO support 1.2.5  (foo_out_asio)
MSN Now Playing (alt) 2.4  (foo_msnalt)
Discogs Tagger 1.12  (foo_discogs)
Continuator 0.4.1  (foo_dsp_continuator)
Tagger Panel Window 1.0.6 [Jan  2 2008 - 15:50:49]  (foo_cwb_hooks)
Directory watcher 0.2 beta 3  (foo_dirwatch)
Album Art Panel 0.2.7  (foo_uie_albumart)
Shell link resolver 1.1  (foo_lnk)
Run services 0.3.2  (foo_run)
Album list panel 0.2.3 beta  (foo_uie_albumlist)
Playlist Tools 0.6.2 beta 3  (foo_utils)
Winamp API Emulator 0.90  (foo_winamp_spam)
Shpeck - Winamp vis plugins wrapper 0.1.1  (foo_vis_shpeck)
Kernel Streaming Output 1.2.2  (foo_out_ks)
Console panel 0.2.1  (foo_uie_console)
Facets 2008-01-04  (foo_facets)
Peakmeter Panel 0.0.4.1 alpha  (foo_uie_peakmeter)
Channel Spectrum panel 0.12  (foo_uie_vis_channel_spectrum)
Egoh Spectrum analyser (uie) 1.1.2  (foo_uie_vis_egoh)
Audio CD Writer 2.0.1  (foo_burninate)
Last.fm Chart Player 0.2.3  (foo_scrobblecharts)
Audioscrobbler 2.2  (foo_audioscrobbler)
cwbowron's title format hooks 1.2.6 [Jan  2 2008 - 15:50:05]  (foo_cwb_hooks)
Album Art Browser 0.0.5 [Jul 13 2007 - 10:15:45]  (foo_cwbowron)
Explorer Tree 1.04.6a  (foo_uie_explorer)
Quick Search Toolbar 2.8j  (foo_uie_quicksearch)
Shorten decoder 0.4.2a  (foo_input_shorten)
Navigator 0.63  (foo_navigator)
WSH Panel (uie) 0.7.1  (foo_uie_wsh_panel)
Randomized playlist entry 1.2.3  (foo_random)
ABX Comparator 1.3.1  (foo_abx)
Typefind 0.2 beta 2  (foo_uie_typefind)
Database Search 1.4 beta 4  (foo_dbsearch)
Playlist Bind 2.2  (foo_playlist_bind)
Tabbed panel modifyed 0.2.1  (foo_uie_tabs)
VLevel 20060324.0  (foo_dsp_vlevel)
Quick Tagger 1.0  (foo_quicktag)
Playlist Manager 1.0  (foo_playlist_manager)
Dockable Panels 1.0.5 [Dec  4 2006 - 09:04:00]  (foo_dockable_panels)
Feature Watcher 1.0.4  (foo_whatsnew)
Masstagger 1.6  (foo_masstag)
Queue manager panel 0.2.3  (foo_uie_queuemanager)
if you use '[code box]' and '[/code box]' remove the spaces between words
Columns UI
Reply #3994
Yeah, that's the first error I got (I used foo_uie_quicksearch to search for something).  I was able to restart it, crashed it with foo_uie_quicksearch again, and then it stopped loading.  Removing quicksearch doesn't fix anything, so I assume it was playlist handling code...
Columns UI
Reply #3995
Stupid question (I don't feel like reading the whole thread): What are the advantages of NG Playlist?
Columns UI
Reply #3996
Ooops. Crashing on empty playlist (introduced with v2) should be rectified in v3.
Columns UI
Reply #3998
Thank you. The CPU usage problem is fixed. It still has 2 usage problems for me though:
1. Remember playlist positions across different playlist when changing between them. As of now NGPL just forgets the positions if I keep changing around.
2. Change the color of the horizontal line in the grouping part. (Maybe it's somewhere but I don't know, have just switched back lol).
Columns UI
Reply #3999
thanks musicmusic your too fast will test when i get home, can't wait
