Topic: Which drives are caching audio data? (Read 57366 times) previous topic - next topic
No, the audio cache can be smaller than the data cache.
[a href="index.php?act=findpost&pid=249580"][{POST_SNAPBACK}][/a]
How can I determine how much audio does my drive cache (if it does)?
[a href="index.php?act=findpost&pid=249618"][{POST_SNAPBACK}][/a]
Feurio does detect that after a bit time consuming testing. I do not know how reliable it is though. Still it is a good idea to use Feurio to double check EAC.
Triza
If there is a 100% reliable method to determine how much audio the drive caches, then if it caches more than 62KB, that would be a perfect method to determine if the drive caches audio (no red bars on damaged discs) ...from the other side, determining how much the drive caches = determining if the drive caches
