Topic: FLAC (subset) file that ffmpeg (7.0, Windows) cannot decode (Read 605 times) previous topic - next topic
sox -b 24 -c 6 -r 96000 -n whitenoise.wav synth 1 whitenoise
flac whitenoise.wav --channel-map=none -b16384
ffmpeg version 7.0-essentials_build-www.gyan.dev Copyright (c) 2000-2024 the FFmpeg developers
  built with gcc 13.2.0 (Rev5, Built by MSYS2 project)
  configuration: --enable-gpl --enable-version3 --enable-static --disable-w32threads --disable-autodetect --enable-fontconfig --enable-iconv --enable-gnutls --enable-libxml2 --enable-gmp --enable-bzlib --enable-lzma --enable-zlib --enable-libsrt --enable-libssh --enable-libzmq --enable-avisynth --enable-sdl2 --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxvid --enable-libaom --enable-libopenjpeg --enable-libvpx --enable-mediafoundation --enable-libass --enable-libfreetype --enable-libfribidi --enable-libharfbuzz --enable-libvidstab --enable-libvmaf --enable-libzimg --enable-amf --enable-cuda-llvm --enable-cuvid --enable-dxva2 --enable-d3d11va --enable-d3d12va --enable-ffnvcodec --enable-libvpl --enable-nvdec --enable-nvenc --enable-vaapi --enable-libgme --enable-libopenmpt --enable-libopencore-amrwb --enable-libmp3lame --enable-libtheora --enable-libvo-amrwbenc --enable-libgsm --enable-libopencore-amrnb --enable-libopus --enable-libspeex --enable-libvorbis --enable-librubberband
  libavutil      59.  8.100 / 59.  8.100
  libavcodec     61.  3.100 / 61.  3.100
  libavformat    61.  1.100 / 61.  1.100
  libavdevice    61.  1.100 / 61.  1.100
  libavfilter    10.  1.100 / 10.  1.100
  libswscale      8.  1.100 /  8.  1.100
  libswresample   5.  1.100 /  5.  1.100
  libpostproc    58.  1.100 / 58.  1.100
Input #0, flac, from 'whitenoise.flac':
  Duration: 00:00:01.00, bitrate: 13891 kb/s
  Stream #0:0: Audio: flac, 96000 Hz, 5.1, s32 (24 bit)
Stream mapping:
  Stream #0:0 -> #0:0 (flac (native) -> pcm_s16le (native))
Press [q] to stop, [?] for help
[aost#0:0/pcm_s16le @ 00000209af0e2c80] No filtered frames for output stream, trying to initialize anyway.
Output #0, wav, to 'out.wav':
  Metadata:
    ISFT            : Lavf61.1.100
  Stream #0:0: Audio: pcm_s16le ([1][0][0][0] / 0x0001), 96000 Hz, 5.1, s16, 9216 kb/s
      Metadata:
        encoder         : Lavc61.3.100 pcm_s16le
[out#0/wav @ 00000209af0e8e40] video:0KiB audio:0KiB subtitle:0KiB other streams:0KiB global headers:0KiB muxing overhead: unknown
[out#0/wav @ 00000209af0e8e40] Output file is empty, nothing was encoded(check -ss / -t / -frames parameters if used)
size=       0KiB time=N/A bitrate=N/A speed=N/A
Re: FLAC (subset) file that ffmpeg (7.0, Windows) cannot decode
Use ffmpeg bug tracker, if they ever bother to look at this bug.
Please remove my account from this forum.
Fixed in librempeg, there is still bug somewhere where small files are not properly flushed inside parser.
