Topic: FLAC-git Releases (Code Base v1.4.x) (Read 36058 times) previous topic - next topic
Re: FLAC-git Releases (Code Base v1.4.x)
I've lifted some restrictions on channel mask recently, these changes are in this compile. Channel masks that are non-standard in FLAC should now be accepted properly, without having to resort to --channel-map=none. However, I don't have much files to test, so if anyone with such files could give it a try, that would be much appreciated.
Tested 4.1 and FL-FR-FC-BC. Files are accepted and compressed without problems.
Hope it's not faux pas to drop MSVC builds in here, didn't seem worth making my own thread for builds that might be slower or worse since I've no idea what I'm doing anyways.
Same commit as NetRanger's previous post, built with MSVC 2022 and copious "lemme flip some of these optimization switches and see what happens"
x64 - AVX
20230211-git-3f1f82c8-x64-AVX - flac.exe and metaflac.exe only
20230211-git-3f1f82c8-x64-Shared-AVX - what you want if you just want libFLAC.dll for something else (rename it if you need to)
x86/32 - SSE2 - 20230211-git-3f1f82c8-x86-Shared-SSE2 - because I still need a 32-bit libFLAC.dll to let eac3to use...
I forgot CXX and UTILS enabled in CMake when I switched to shared builds, so both also come with FLAC++.dll, flacdiff.exe, and flactimer.exe
FLAC git-771eb050 20230217
Built on February 18, 2023, GCC 12.2.0
This build has much improved foreign metadata handling. When decoding with --keep-foreign-metadata, the right format will be picked automatically instead of default to WAV (which only works for WAV). Also, decoding to AIFF-C sowt and WAVE_FORMAT_EXTENSIBLE is now possible. Finally, a bunch of warnings is added when on restoration of foreign metadata inconsistencies are found, for example when the length of the file has changed.
Took some files from the upper section of https://www.mmsp.ece.mcgill.ca/Documents/AudioFormats/AIFF/Samples.html - the 8, 8C, 16, 16C, 16s (that is sowt), 24, 24C, 32, 32C and ran them through --keep-foreign-metadata-if-present with or without entering a tag field first. Decoded with --keep-foreign-metadata-if-present and let a file deduplicator check that they were bit-exactly the same as the original.
All of them did come out bit-identical. But, if fb2k is likely to only make "pretty standard" tags, it might not have been the hardest of tests.
Edit: tried afterwards an 8-bit sowt file, same (good) result. Why try? Just out of the knowledge that some players have rejected those (after all, who would make a fuss out of endianness on 8-bit? But it is a subformat of AIFC, so it is legit).
Obligatory suggestions coming up - after all, you didn't do all this hard work for users to turn grateful and stop being pain-in-the-ass about features they don't use themselves eh?   ;D
* When re-encoding flac to flac, it is reasonable to let --no-keep-foreign-metadata kill foreign metadata. (Is there any such provision in metaflac?)
Or if one is reluctant to making a change that will actually start killing data when the previous version did not: a --remove-foreign-metadata
* I think a "-k" for --keep-foreign-metadata-if-present should be on the table pretty soon.
* One will always think twice before changing behaviour and thrice before changing default behaviour, but it isn't unfair to assume that a user that encodes with foreign metadata intends them to be kept? That suggests that decoding by default employs --keep-foreign-metadata-if-present. But, but, but ... you might not want all the WTFs from users who don't understand why their pyr8ed downloads (hm, to be fair it could be purchases too) decode to .aiff.
(Once alternative behaviour deviates enough from 2007-era "-d", one can of course take note that -D is not taken ...)
Reply #32
I'm not sure that would be very useful. We don't have a --no-transfer-vorbis-comment option either. One can remove the RIFF and AIFF data with metaflac --remove --block-type=APPLICATION:riff,APPLICATION:aiff.
I don't think keeping them by default is a good idea. I've seen an AIFF file come out a DAW with an empty AIFF chunk of 15MB for some reason. The user asked why FLAC didn't compress such a block. The answer is because FLAC compresses audio, not metadata.
I agree, and that was not my suggestion either.
What I was suggesting - or at least suggesting to consider - was behaviour upon decoding. I argue that if there is foreign metadata in the .flac file, it reflects an intention to keep foreign metadata.
And even more so when the default encoding behaviour is to discard them. Then foreign metadata in the .flac must have been due to an active choice.
(Aside: I have no idea whether any of the wavefile compressors - WavPack, TAK, ALS, (La) and the two animals - do compress the foreign metadata, foreseeing DAWs misbehaving big this way.)
Reply #34
Thank you for this, the —keep-foreign-metadata command is an important one for me!
Reply #39
flac-1.4.2-4d21da1-20230227
Built on February 28, 2023, Intel compiles. win32-XP is Intel 19.0, others are Intel 19.2.
(Code Base : 1.4.2)
https://www.rarewares.org/files/lossless/flac-1.4.2-4d21da1-20230227-win32-nonXP.zip
https://www.rarewares.org/files/lossless/flac-1.4.2-4d21da1-20230227-win32-XP.zip
https://www.rarewares.org/files/lossless/flac-1.4.2-4d21da1-20230227-x64-AVX2.zip
The targets are self-explanatory.  :)
Reply #40
I've had a report of possible issues with these compiles so please only use them for testing and not for archival. The particular problem was with '-8', but it could affect other settings also.
Reply #42
I can confirm the problem with the Intel compiles which I will look into. Having just built a GCC version, I can confirm that it works as expected. So, go for NetRanger's build. ;)
Reply #43
This is something true for all these git compiles. I usually don't leave git in a state with known bugs, but a release is usually preceded by a few weeks without adding new features, to find bugs.
Still, I'm always curious about bugs that do not surface on GCC but do on other compilers. @john33, do you usually run the test suite on builds like these? Can you check whether the test suite fails on these builds?
Reply #44
It turns out that the 'bug' was being caused by using the '/Qipo' Intel Procedural Optimization switch in the compilations.
I have recompiled without this option and the compiles perform as expected. They are on the same links as above.
@ktf, no, I don't normally run the test suite. I have a bunch of files I've used over the years that I test against. I recall having an issue with '/Qipo' on the odd occasion in the past but this is the first time I've encountered it for some years. I'm not sure that it makes a whole bunch of difference in respect of speed, so probably not worth bothering with. Ignoring the XP build, I've tried using the latest Intel oneAPI compiler - based on Clang 16. It works quite well for the 64bit build but will not compile for 32bit. The Intel Classic Compiler - 19.2 - will be removed later this year from the Intel downloads.
Reply #45
Is it a bug in IPO or is it a bug in FLAC being triggered by IPO? Do you have some more details, I'm certainly curious.
Reply #46
I understand your interest, but I suspect the answer is way above my level of understanding!! If anything occurs to me, or comes to light, I'll certainly let you know.
Reply #47
Could you perhaps disclose some more details, if necessary via PM, so I can look into this when I have the time?
Compiler bugs are pretty rare, and I find it especially interesting as you say you've run into this previously.
Reply #49
flac-git-07471c89-20230306
Built on March 6, 2023, GCC 12.2.0
(Code Base : 1.4.2)
Win32 generic: https://www.rarewares.org/files/lossless/flac-1.4.2-07471c89-20230306-x86.zip (Not XP friendly)
x64 generic: https://www.rarewares.org/files/lossless/flac-1.4.2-07471c89-20230306-x64.zip
x64 AVX2 optimised: https://www.rarewares.org/files/lossless/flac-1.4.2-07471c89-20230306-AVX2.zip
