Topic: Wine 2.14 - Could not enumerate tracks (Object not found) (Read 585 times) previous topic - next topic
Hey everyone,
I've installed F2K on my Linux machine and encountered the same issue when installing from AUR or manually.
Folder monitoring works great, new playlists save and load just fine, but when I try to load my old playlists from windows (.m3u8 format, definitely not corrupt, file paths correct) they refuse to load, giving me the "Could not enumerate tracks (Object not found)" error in console. The path to each file that the error specifies is also correct, but I noticed that in the progress bar during playlist recovery the file path shows up like this
Any ideas how to fix this? Also sorry if this has been posted, as I haven't been able to find any other posts mentioning this issue specifically
Update: Just to clarify, this happens to all older playlists, not just m3u8 ones
