Topic: foo_youtube (Read 684891 times) previous topic - next topic
Youtube Source - streaming Live channels, not working
Reply #1625
Hello
The Youtube Source component stopped streaming live channels. It used to work fine, I believe the problem started with the latest version 3.9.6.
When I add a live youtube link, it tries to open the link and after a minute or so it gives the error
Unable to open item for playback (Youtube Source: foo_youtube: Stream not found | ffmpeg: Stream not found | foobar2000: Unsupported file format):
"https://www.youtube.com/watch?v=jfKfPfyJRdk"
Re: foo_youtube
Reply #1626
hi all! i from russia
in my country blocked youtube
how i can play video file from local hard disk in foo_youtube?
please i am waiting answer
Re: foo_youtube
Reply #1627
the description of the component says that it can play Dailymotion. I can paste the url to the "add location" but is it possible to search via "view/youtube source/search on site" just like from Youtube? When I tried that way it did not find anything from Dailymotion.
foo_youtube_3.9.6 - Server returned 403 Forbidden (access denied)
Reply #1628
For the past few days, I've been getting the following message when I try to download a file from YouTube with foo_youtube_3.9.6
Source: "www.youtube.com/watch?v=3mg0wKRmtgs"
  Unable to open source file: Youtube Source: foo_youtube: server error (403) from rr2---sn-cp1oxu-q2ns.googlevideo.com | ffmpeg: Server returned 403 Forbidden (access denied) | foobar2000: Forbidden (403)
  Conversion failed: Youtube Source: foo_youtube: server error (403) from rr2---sn-cp1oxu-q2ns.googlevideo.com | ffmpeg: Server returned 403 Forbidden (access denied) | foobar2000: Forbidden (403)
Is anyone experiencing the same problem?
Thank you :-)
Re: foo_youtube
Reply #1629
I can confirm. Some of the videos from which I download the audio give this error. I just updated to foo_youtube_3.9.6 but I have also seen this before off late. I have been mostly away from my PC for the last 1,5 weeks and I cannot be more specific.
Edit. In case developer is following this thread I can post links that will work normally and links that get the 403.
Re: foo_youtube
Reply #1631
Thank you. I tried the nightly but no dice. I went back to the stable version of yt-dlp to find that one video that I knew to be working is no longer working.
Re: foo_youtube
Reply #1632
Weird. Still works here with yt-dlp 2025.01.15.
Re: foo_youtube
Reply #1633
Can't play here either, same error. I came here because I tried all other fixes I could come up with first - addding new cookies, checked different dercoding methods but the error suggests its not even getting to the decoding and testing internal and external yt-dl.exe and since I saw above, I also got yt-dlp.exe and enabled it in maintenance but it is definitely not working, error details are below
Unable to open item for playback (Youtube Source: foo_youtube: server error (403) from rr1---sn-u5a3u5a3-h5oes.googlevideo.com | ffmpeg: Server returned 403 Forbidden (access denied) | foobar2000: Forbidden (403)):
"www.youtube.com/watch?v=sdDVMCbG0FM"
one other thing, it does actually work with this video https://www.youtube.com/watch?v=x8A9Y1Dq_cQ yet not others, I tried about 15 in total and couldn't find another that works.
thanks for any help
Re: foo_youtube
Reply #1634
Same error here:
Unable to open item for playback (Youtube Source: foo_youtube: server error (403) from rr3---sn-i5h7lnll.googlevideo.com | ffmpeg: Server returned 403 Forbidden (access denied) | foobar2000: Forbidden (403)):
"www.youtube.com/watch?v=dB_CuFcJyXI"
was working fine last month with the same version of this plugin.
After reading some of the previous posts I got it to work after
  • downloading yt-dlp.exe
    putting it in the folder C:\Users\me\AppData\Roaming\foobar2000-v2\foo_youtube
    and adding a path in the preferences dialog plus modifying some of the other settings - see screen shot
Re: foo_youtube
Reply #1635
Thank you. I played with the Prefer youtube=dl over internal analyzer setting. It stopped the 403 message but now songs simply stop after 3, 4, 5 or 6 seconds. This happens both with the stable version of yt-dl and the nightly. This behavior shows both on Windows 11 stable (22631.4751) and Windows 11 beta Insider (22635.4800)  Scratches head.
Re: foo_youtube
Reply #1636
I'm using yt-dlp instead of youtube-dl and it works for me on Windows 10.
https://github.com/yt-dlp/yt-dlp
Re: foo_youtube
Reply #1637
I am also using yt-dl. Youtube-dl was discontinued in 2021.
I tried the latest nightly build 2025.01.23.232810 but it does not make the problem go away.
Re: foo_youtube
Reply #1638
Damn... and I assume you have the API Key set and LAV filters installed... My YouTube Source page looks exactly like the one posted by minimaster. Try with a portable version in another windows 11 and 10 to discard is something internal to foobar2000.
Re: foo_youtube
Reply #1639
Excellent, I setup YTP-DL exactly as minimaster showed in his picture and it is working, it takes a few moments longer to open but still, as long as it does work then i'm very happy.
I didn't think to change the other options for location and the tick for prefer youtube-dl over internal analyzer and only changed the options on top of the right click box for "External".. thanks very, very much.
** Also using foo_youtube -only- as the decoder I have videos in sync, which I haven't had for ages so thats awesome as well. **
Re: foo_youtube
Reply #1641
Hey! Sorry for the off-topic question, but what theme are you using?
My own DarkOne v4.0 based skin :-)
Post is a year old, but you'll get a pretty good idea:
https://hydrogenaud.io/index.php/topic,125548.0.html
Some video's:
https://www.youtube.com/watch?v=BHZVmBdjpLw&list=PLxY2uaYZgJOCQ55S9XsxAzIVvdY2VhPOL
EDIT: If you want to know something about it, please post in the thread above or send a PM.
Re: foo_youtube
Reply #1642
If you still get the error, try the following:
Enter cmd in the address bar of the folder where yt-dlp.exe is located.
The command prompt will start. Enter (copy and paste) the following. The download will start. It will be downloaded into the same folder as yt-dlp.exe.
yt-dlp https://www.youtube.com/watch?v=dB_CuFcJyXI
If the download is successful, you can delete the video. Now try it on Youtube Source (foo_youtube).
SHURE SRH1840, SENNHEISER HD660S2, SENNHEISER HD620S, SENNHEISER HD 490 Pro Plus, beyerdynamic DT 1990 PRO, HiFiMAN Edition XS, HIFIMAN ANANDA, Bowers & Wilkins P7, FiiO FT5, FiiO FT1 Pro, 水月雨 (MOONDROP) 空鳴 - VOID, SONY WH1000XM5 (made a Upgrade/Balanced Cable by myself)
Re: foo_youtube
Reply #1643
https://mega.nz/file/MatHRRQb#wc8ceMHtrwuDV-zyF-_jxrxwAao96d0dKCGBaf6r63Y
yd folder
C:\yd
foo_youtube.dll.cfg: replace
\profile\configuration\foo_youtube.dll.cfg
Preferences > Tools > YouTube Source > Maintenance tab > YouTube API Key: input
Restart foobar
Re: foo_youtube
Reply #1644
I can also report experiencing 403 errors. I hope this component is updated shortly, historically whenever I've had problems like this with foo_youtube I've also noticed a component update was available that would immediately fix it.
Re: foo_youtube
Reply #1645
Wouldn't Reply #1642/1643 solve the problem?
This usually solves the problem.
Re: foo_youtube
Reply #1646
In the "Video" tab, I have the "Prevent display turn off while video is playing" option checked, but when playing a video, the screen still goes out after a while.
I would like the screen to stay on, when playing a video using foo_youtube, but turn off when playing regular audio files. Is this possible?
Re: foo_youtube
Reply #1647
@DVS
Preferences > Tools > Youtube Source > Video > Playback tab > Common
"Prevent display turn off while video is playing" It is checked by default.
It doesn't matter if it's ON or OFF, just change the Playlist and double-click the Track.
Is this not the problem?
Reply #1634: https://hydrogenaud.io/index.php/topic,104379.msg1058179.html#msg1058179
Are the settings the same?
Are you using an environment where YouTube videos can be played clearly with foobar2000?
Is it the latest one?
yt-dlp (yt-dlp.exe) 2025.01.26, LAV Filter 0.79.2
https://github.com/yt-dlp/yt-dlp/releases
https://github.com/Nevcairiel/LAVFilters/releases
Re: foo_youtube
Reply #1648
Yes, the problem is that when the option is enabled, the screen still turns off.
The settings are the same as in the link. Yt-dlp and LAV filter the latest and YouTube videos are played.
It's not entirely clear. Do I need to enable (or disable), then change the playlist and start any track? I did this, but the screen still turns off.
Re: foo_youtube
Reply #1649
No, I don't mess with standards.
Obviously, something is wrong.
Does watching YouTube for a long time affect the operation of your PC?
Other Panels (Visualization) that are displayed, etc.
What are the specifications of your PC?
Processor, RAM, GPU etc...
