Topic: mplayer: "invalid sync code" (Read 3227 times) previous topic - next topic
I got this errors when playing flac (encoded with flac - Command-line FLAC encoder/decoder version 1.2.1)
Is there someting wrong with that or is a mplayer issue?
Opening audio decoder: [ffmpeg] FFmpeg/libavcodec audio decoders
AUDIO: 44100 Hz, 2 ch, s16le, 806.0 kbit/57.12% (ratio: 100752->176400)
Selected audio codec: [ffflac] afm: ffmpeg (FFmpeg FLAC audio)
AO: [dsound] 44100Hz 2ch s16le (2 bytes per sample)
Video: no video
Starting playback...
[flac @ 012968e0]invalid sync code
[flac @ 012968e0]invalid frame header
[flac @ 012968e0]decode_frame() failed
Have you tried running the file through a FLAC tester?
Yes I did. It says no errors found.
I guess it's a mplayer issue then.
