Topic: 1-100 rating system (Read 1906 times) previous topic - next topic
1-100 rating system
Hi everyone. I wonder if there is a possibility of having a 1-100 rating system in foobar? (Sorry if this has been asked before but I couldn't find it)
1-100 rating system
you can do anything you like with your file tags. you can manipulate pretty much anything within foobar to display it via title formatting. but a quick way to set the values would require a bit more effort on your part.
1-100 rating system
Well I'm up for it. I found this guide: 'Step By Step Guide To Use Ratings with Foobar v 9.5 beta 4' (http://www.hydrogenaudio.org/forums/index.php?showtopic=59187) and followed the steps, but can't find a way to change the scale of rating.
1-100 rating system
that all would work apart from step 4 really. you want to bind shortcuts to setting every value. it's possible but not practical.
and rather than display stars, you could either display a | in the $repeat function or simply display the numerical value.
1-100 rating system
Oh, when I see this - I can't believe that you really need such criteria for rating system.
For example, you can do this with Quicktagger and Rating tag and bind only one shortcut to "more" function, and when you press it - you will be asked for value.
1-100 rating system
clearly Pitchfork fanboy...
I want to see it implemented with 100 star system
1-100 rating system
Then just change 5 to 100 in the Pattern-code from the guide.
