Topic: WAV header (Read 3536 times) previous topic - next topic
WAV header
how is the wreserved field in set in the wav header while decoding .Flac files using flac 1.2.1 win32 exe  ?
ie If i decode a flac file using flac-1.2.1.exe few files have wreserved field to be 0x10 and few others 0x18 .. but http://msdn.microsoft.com/en-us/library/wi...1(v=vs.85).aspx says i need to make it 0 what exactly is happening ?
Thank you
WAV header
Samples field of WAVEFORMATEXTENSIBLE is a discriminated union, and only one of wValidBitsPerSample, wSamplesPerBlock, and wReserved are valid / used, depending on the context.
For detail, read http://msdn.microsoft.com/en-us/library/wi...e/gg463006.aspx
In your case, this field is used not as wReserved, but as wValidBitsPerSample. Therefore, 0x10 means bits per sample is 16, and 0x18 means 24.
WAV header
Thank you it was very helpful
