Re: Now that you found your lowest transparent setting...
Reply #95 – 2017-10-25 11:11:57
@halb27 Well, a few years ago I checked AAC quaility using Apple and Winamp FhG. My ears are anything but golden which means for instance usually Lame 3.99.5 -V5 mp3 is absolutely fine to me. But I'm pretty sensitive to certain tonal problems which can be present with practical listening. As for that I realized that FhG AAC (Winamp version) was a little bit (not much) better than Apple AAC at that time. It took a ~170 kbps setting to make the hard tracks become transparent. But I admit that the differences were very small, and for a bitrate like 96 kbps on average things may be different. If the differences were very small (like you talking 5kbps-ish or less?) would that mean it's possible for another person to feel differently? ; like that 'too close to call' sorta thing from a quality standpoint. like where IgorC's claim of "No AAC encoder is better than Apple AAC @ 96kbps and higher" is still correct (especially for an average) even though what you said is not wrong either as your talking more of a specific thing (and you even said it was 'very small') where as i imagine IgorC when he made that claim is looking at the wide data available. just some random thoughts on this little thing. also, it appears the Winamp FhG encoder has not been updated in a while (the files needed to encode FhG in Foobar2000 are dated Dec 2013) and i would imagine Apple AAC has not been updated, in terms of sound quality adjustments, in years either(?). so assuming that's correct things likely have not changed since you last tested. also, i see your 170kbps setting for AAC recommended for basically all music being transparent outside of killer samples. but... at least in Foobar2000, with the Apple AAC encoder there is no strict 170kbps setting as it goes from 160kbps to 196kbps. basically when you start from 64kbps it increases by 16 in each quality setting (i.e. 64/80/96/112 etc) with the slider all the way up to 160kbps and after that it jumps by 32kbps with each raise in quality with the quality adjustment slider til it hits the max setting which is 320kbps. so with that said... would the 160kbps setting qualify for 170kbps in AAC(Apple etc) and similar to LAME v2 (190kbps) comparing to his 200kbps suggestion? ; because correct me if i am wrong, but when your setting is only 8-10kbps away from what he mentioned it seems like the encoder, on more complex music, will likely shoot up the average bit rates to those 170kbps for AAC and 200kbps for MP3 when needed. hence, i can use the 160kbps(Apple AAC) and 190kbps(MP3) settings and would be within his general settings. as for your general guideline that you got from a Opus developer with the A/B/C stuff... it appears Apple AAC 96kbps is better than LAME v5 according to this listening test from July 2014... http://listening-test.coresv.net/results.htm ; but i get the general point in that 96kbps Apple AAC and LAME v5 is close enough in quality and he used those settings for THE minimum for quality sound on a lot of music. but anyways, with the whole A/B/C stuff... to comment more specifically on your B and C general guidelines, i can't really fault that as it appears with 'B' the Opus dev was selecting THE lowest setting where a lot of music is transparent or close to it and with 'C' he more or less found a MINIMUM setting for the more paranoid types of people. sorta like sweet spots you could say for two groups of people. but it makes me wonder... if Apple AAC @ 96kbps scored that well (i.e. 4.40 average (and only three samples went below a 4.00)) in those July 2014 listening tests, how much better would Apple AAC @ 128kbps be? ; because unless there is barely any difference it seems like you would be not too far from perfection(since i imagine that 4.40 average of AAC 96kbps would shoot up a fair amount with Apple AAC 128kbps), outside of some killer samples, in which case 170kbps range would be mostly a waste of bitrate unless your more of the paranoid type(?). but, since i already mentioned, that Opus dev seems to have made his choices around THE minimum quality setting for more of the common person (option B) and then the more paranoid type (option C) then i can't really fault it. so given that info... that's kinda why i suggested the 128kbps setting as the sweet spot for Apple AAC in general as it gives a minimal file size, while not as minimal as the 96kbps setting, might clean up the sound a bit better (like raise that 4.40 average score a fair amount) without spending all that much more bit rate and in the big picture 128kbps is still a pretty small file size as i don't know exactly where people draw the line of what's considered 'high' or 'low' bit rates, but, as a ball park figure, lets say 128kbps qualifies as either the lowest point of a high bit rate or the highest point of a low bit rate (even if opinions vary i got to be close) and that just shows you it's still a pretty minimal file size and considering it's sound quality/file size i feel it's difficult to justify using higher bit rates, especially outside of the occasional problem sample or those more golden ear-ish types of people. NOTE: i believe read around here not long ago that some Opus dev (it may have been someone else) considered 128kbps 'a high bit rate'(but they might have been referring to Opus specifically as i can't recall off the top of my head right now), but it's probably not surprising since that encoder tends to focus more in "lower bit rates" and has already achieved quality sound at 96kbps(if not 80kbps like you and the Opus dev you mentioned suggests). also, it makes me wonder how Opus @ 80kbps compares to LAME v5? ; would it be fair to say, given what i can tell in that July 2014 listening test, that Opus @ 80kbps/Apple AAC @ 96kbps/LAME @ 130kbps(v5) are about the same in sound quality? but with all of that said... i imagine he (the Opus dev you mentioned) formed his opinion on those core things based on what he observed with people in general out there? ; like with more of the common-ish type of person vs the more 'golden ear'-ish/paranoid type of person. ------------------------------------------@includemeout It's just my two cents, @ThaCrip , but do all your replies have to be so lecture-like, given their sheer size? I don't know, I guess it's just sorta the way i talk on certain subjects etc. I don't mean anything by it. you can just skip reading most of my post if you want to, no offense or anything. like just skimming through my post above will give you the gist of my thoughts. NOTE: I actually read this entire topic before I made a post as it's kinda cool just to see what others do and how they approach things etc
For music on-the-go I suggest... -Opus @ 96kbps (or... 64kbps minimum, 128kbps maximum). *preferred choice* -AAC(Apple) @ 96kbps (q45 TVBR (or CVBR)) (or 128kbps (q64 TVBR) maximum). *secondary choice* -MP3 @ v5 (130kbps) (or v2 (190kbps) as a alternative/maximum). *third choice*
