Topic: Continuous ERROR reported by Library Scan w/ ver 1.2.x (Read 1589 times) previous topic - next topic
Hello Folks,
I am running ver 1.2.2 and my library consists of 3 usb connected external HD (6 TB total).
Up to Foobar v 1.1.18 I never had problem with the Monitored HDs.
Instead, since I upgraded to v 1.2.1 I am getting a quasi-persistent "ERROR!" flag reported on any monitored HDs quite as soon as I do any folder renaming or adding/deleting.
Then I manually run a rescan and the ERROR quits, but it is annoiing and anyway not present with the older Foobar versions I used.
I suppose to be a bug or some bad interaction within the new v 1.2.x
Regards, Andrea
Thanks for the report. The problem will be fixed in the next update (1.2.3).
Thank you, Peter, for the prompt acknowledge and notice of fixing in the next release.
Kind regards,
Andrea
I confirm that the problem is solved in v 1.2.3 beta2
Mnay thanks
Andrea
