Topic: Large library causing errors (Read 4325 times) previous topic - next topic
I have a 5000 album CD collection built using EAC with the files encoded as FLAC. No embedded pictures, cover art or anything fancy. Foobar has been working great up until about 2 weeks ago. I now get an error status under the Preferences / Media Library / Music Folders list widget. When I restart Foobar the status changes back to monitoring but at some point the error returns. Is the size of my library an issue? Are there any optimization I can make? Not sure if this issue is version specific but I am running the latest 1.2.2.
Could you have a look in the console (click View, Console) and see if it reports any problems.
Watching: E:\Music
Album List refreshed in: 0:01.177797
Startup time : 0:02.896620
Properties dialog refresh: 0:00.000197
Properties dialog display refresh: 0:00.001839
Folder watching failure: Invalid parameters
Watching: E:\Music
Watching: E:\Music
Watching: E:\Music
Watching: E:\Music
Watching: E:\Music
Watching: E:\Music
Watching: E:\Music
Watching: E:\Music
Watching: E:\Music
Watching: E:\Music
Watching: E:\Music
Watching: E:\Music
Watching: E:\Music
Watching: E:\Music
Watching: E:\Music
Watching: E:\Music
Properties dialog refresh: 0:00.000519
Properties dialog display refresh: 0:00.002154
Properties dialog refresh: 0:00.000494
Properties dialog display refresh: 0:00.002313
Properties dialog refresh: 0:00.000458
Properties dialog display refresh: 0:00.002266
Properties dialog refresh: 0:00.000049
Properties dialog display refresh: 0:00.001748
Properties dialog refresh: 0:00.000039
Properties dialog display refresh: 0:00.001726
Watching: E:\Music
Watching: E:\Music
Watching: E:\Music
Watching: E:\Music
Watching: E:\Music
Watching: E:\Music
Watching: E:\Music
Watching: E:\Music
Watching: E:\Music
Watching: E:\Music
Watching: E:\Music
Watching: E:\Music
Watching: E:\Music
Watching: E:\Music
Album List refreshed in: 0:00.611868
Opening track for playback: "E:\Music\Foundation\Putumayo Presents- The Best Of World Music - Reggae\01 If They Could They Would.flac"
Album List refreshed in: 0:00.663102
For me, it's enough to rename several tracks (in a watch folder) using "File Operations" menu.
(if this matters: I have 2 watch folder on 2 disks.)
Sometimes I have "Folder watching failure: Invalid parameters" message after this, but sometimes there's only "Watching: Z:\Music" message. And the folder status is still "Error!".
I am having an issue with Foobar2000 1.2.1 and 1.2.2 updating my library. During the time that the console log was running for 1.2.2 I added 4 new albums to my network share, which were listed immediately when I looked in Windows Explorer,  but were not updating in the library. I also have a file that is missing from my Black Label Society album, even though it is listed in Explorer, Foobar2000 can't seem to recognize it. This is while running Columns UI, and the AceBar theme. So I am not sure what all I need to do to fix this. For the location not parsible info, this is because they are symbolic folders where the originating contents  no longer exist, so I am not worried about those.
If I switch to Default UI, I can browse to the folders fine.
Operating System - Windows 7 X64
Foobar Version 1.2.2
Foobar2000 1.2.1 console log:
Watching: C:\Users\andrew\Music
Watching: C:\Users\Public\Music
Watching: \\server\music
Columns UI/Tab stack: Warning: Playlist Organizer panel was visible on creation! This usually indicates a bug in this panel.
Custom Database: Initialize
Custom Database: table quicktag already exists (1)
Custom Database: table database_version already exists (1)
Custom Database: index url_idx already exists (1)
Custom Database: Completed
WSH Panel Mod (Last.fm Playcount Sync by marc2003): Parsing file "C:\Users\andrew\AppData\Roaming\foobar2000\marc2003\common4.js"
WSH Panel Mod (Last.fm Playcount Sync by marc2003): Parsing file "C:\Users\andrew\AppData\Roaming\foobar2000\marc2003\tooltip_buttons.js"
WSH Panel Mod (Last.fm Playcount Sync by marc2003): initialized in 59 ms
WSH Panel Mod ({218C5EF4-75BD-4BFA-8CFE-F55A0B8AE805}): initialized in 1 ms
WSH Panel Mod ({E30B1BD2-91F4-44AA-AADC-C5B5415E1EAD}): initialized in 1 ms
WSH Panel Mod (Selection Statistics by Elevory): initialized in 246 ms
WSH Panel Mod (Playback Buttons by marc2003): Parsing file "C:\Users\andrew\AppData\Roaming\foobar2000\marc2003\common4.js"
WSH Panel Mod (Playback Buttons by marc2003): Parsing file "C:\Users\andrew\AppData\Roaming\foobar2000\marc2003\tooltip_buttons.js"
WSH Panel Mod (Playback Buttons by marc2003): initialized in 5 ms
WSH Panel Mod (Generic Divider by Elevory): initialized in 1 ms
Seekbar: taking Direct3D9 path.
Seekbar: Frontend initialized.
Startup time : 0:02.031179
Location not parsable: "\\server\music\Inner Party Systems", reason: Access denied
Location not parsable: "\\server\music\Jay-Z\Jay-Z - The Blueprint 3 [2009-Vinyl-MP3-V0(VBR)]", reason: Access denied
Location not parsable: "\\server\music\Just Blaze", reason: Access denied
Location not parsable: "\\server\music\Justice\Justice - Audio, Video, Disco 3202", reason: Access denied
Location not parsable: "\\server\music\Justice\†", reason: Access denied
Opening track for playback: "\\server\music\Battles\Battles - Mirrored\05 - Leyendecker.mp3"
Location not parsable: "\\server\music\Memphis May Fire\Memphis May Fire", reason: Access denied
Location not parsable: "\\server\music\Memphis May Fire\Memphis May Fire - Between The Lies (V0)", reason: Access denied
Location not parsable: "\\server\music\Memphis May Fire\Memphis May Fire - Sleepwalking - 2009 (MP3-320-Log-Cue-CD)", reason: Access denied
Location not parsable: "\\server\music\Memphis May Fire\Memphis May Fire - The Sinner [SINGLE] [2011] (V0)", reason: Access denied
Audioscrobbler: Handshake successful.
Wave cache: finished analysis of "\\server\music\Battles\Battles - Mirrored\05 - Leyendecker.mp3"
Location not parsable: "\\server\music\Audio Test\2L-050_tr01_multi_DXD.zip", reason: bad allocation
Location not parsable: "\\server\music\The Presidents of the United States of America\The Presidents of the United States of America - The Presidents of the United States of America (V0)\The Presidents Of The United States Of America - The Presidents Of The United States Of America.m3u", reason: Object not found
Opening track for playback: "\\server\music\Black Label Society\Black Label Society - Mafia\04 - Forever Down.mp3"
Unable to open item for playback (Object not found):
Opening track for playback: "\\server\music\Black Label Society\Black Label Society - Mafia\07 - Death March.mp3"
Opening track for playback: "\\server\music\Black Label Society\Black Label Society - Mafia\13 - Been A Long Time.mp3"
Wave cache: could not open/find "\\server\music\Black Label Society\Black Label Society - Mafia\13 - Been A Long Time.mp3"
Opening track for playback: "\\server\music\Black Label Society\Black Label Society - Mafia\02 - What's In You.mp3"
Opening track for playback: "\\server\music\Black Label Society\Black Label Society - Mafia\09 - Say What You Will.mp3"
Opening track for playback: "\\server\music\Black Label Society\Black Label Society - Mafia\10 - Too Tough To Die.mp3"
Opening track for playback: "\\server\music\Black Label Society\Black Label Society - Mafia\08 - Dr.Octavia.mp3"
Opening track for playback: "\\server\music\Black Label Society\Black Label Society - Mafia\06 - You Must Be Blind.mp3"
Opening track for playback: "\\server\music\Black Label Society\Black Label Society - Mafia\12 - Spread Your Wings.mp3"
Opening track for playback: "\\server\music\Black Label Society\Black Label Society - Mafia\03 - Suicide Messiah.mp3"
Opening track for playback: "\\server\music\Black Label Society\Black Label Society - Mafia\05 - In This River.mp3"
Opening track for playback: "\\server\music\Black Label Society\Black Label Society - Mafia\11 - Electric Hellfire.mp3"
Autobackup: Backed up 47 items to autobackup.20130121-161900.zip
Opening track for playback: "\\server\music\Black Label Society\Black Label Society - Mafia\14 - Dirt On The Grave.mp3"
Watching: Y:\
Location not parsable: "Y:\Inner Party Systems", reason: Access denied
Location not parsable: "Y:\Jay-Z\Jay-Z - The Blueprint 3 [2009-Vinyl-MP3-V0(VBR)]", reason: Access denied
Location not parsable: "Y:\Just Blaze", reason: Access denied
Location not parsable: "Y:\Justice\Justice - Audio, Video, Disco 3202", reason: Access denied
Location not parsable: "Y:\Justice\†", reason: Access denied
Location not parsable: "Y:\Memphis May Fire\Memphis May Fire", reason: Access denied
Location not parsable: "Y:\Memphis May Fire\Memphis May Fire - Between The Lies (V0)", reason: Access denied
Location not parsable: "Y:\Memphis May Fire\Memphis May Fire - Sleepwalking - 2009 (MP3-320-Log-Cue-CD)", reason: Access denied
Location not parsable: "Y:\Memphis May Fire\Memphis May Fire - The Sinner [SINGLE] [2011] (V0)", reason: Access denied
Location not parsable: "Y:\Audio Test\2L-050_tr01_multi_DXD.zip", reason: bad allocation
Multiple ID3v2 tags encountered
[long list of these]
Location not parsable: "Y:\Kanye West\Kanye West - Power (feat. Jay-Z & Swizz Beatz) [Remix].mp3", reason: Unsupported format or corrupted file
[list]
Autosaving... (I)
Autobackup: Backed up 48 items to autobackup.20130121-162410.zip
Location not parsable: "Y:\Street Lurkin\Night By Night (Street Lurkin Remix).mp3", reason: Unsupported format or corrupted file
[list]
Location not parsable: "Y:\Tiesto\Tiesto- Knock You Out (Omega Remix).mp3", reason: Unsupported format or corrupted file
[list]
Watching: Y:\
Opening track for playback: "\\server\music\Angelfish\Angelfish - Angelfish (1994) - [MP3-320]\08 Mummy Can't Drive.mp3"
Wave cache: finished analysis of "\\server\music\Angelfish\Angelfish - Angelfish (1994) - [MP3-320]\08 Mummy Can't Drive.mp3"
Last.fm Playcount Sync: Contacting Last.fm....
Last.fm Playcount Sync: Last.fm responded 'OK'
Foobar 1.2.2
Autobackup: Backed up 47 items to autobackup.20130121-163903.zip
Opening track for playback: "\\server\music\J Dilla\J Dilla - Ruff Draft 2CD (V0)\Disc 2\09 J Dilla - Take Notice (Instrumental).mp3"
Wave cache: finished analysis of "\\server\music\J Dilla\J Dilla - Ruff Draft 2CD (V0)\Disc 2\09 J Dilla - Take Notice (Instrumental).mp3"
Opening track for playback: "\\server\music\The Cramps\The Cramps - Off the Bone\15 New Kind of Kick.mp3"
Audioscrobbler: Submitting 4 cached tracks...
Audioscrobbler: Submission succeeded.
Wave cache: finished analysis of "\\server\music\The Cramps\The Cramps - Off the Bone\15 New Kind of Kick.mp3"
Opening track for playback: "\\server\music\Daft Punk\Tron Legacy (Amazon MP3 Exclusive Version) [+digital booklet]\15 - Solar Sailer.mp3"
Audioscrobbler: Submitting track...
Wave cache: finished analysis of "\\server\music\Daft Punk\Tron Legacy (Amazon MP3 Exclusive Version) [+digital booklet]\15 - Solar Sailer.mp3"
Opening track for playback: "\\server\music\The Cab\The Cab - Whisper War\10 Vegas Skies.mp3"
Wave cache: finished analysis of "\\server\music\The Cab\The Cab - Whisper War\10 Vegas Skies.mp3"
Shutting down...
Components installed:
Core (2013-01-18 15:31:20 UTC)
    foobar2000 core 1.2.2
foo_albumlist.dll (2013-01-18 15:30:04 UTC)
    Album List 4.5
foo_audioscrobbler.dll (2013-01-21 02:30:13 UTC)
    Audioscrobbler 1.4.7
foo_cdda.dll (2013-01-18 15:29:30 UTC)
    CD Audio Decoder 3.0
foo_converter.dll (2013-01-18 15:29:34 UTC)
    Converter 1.5
foo_customdb.dll (2013-01-21 02:30:13 UTC)
    Custom Database 0.1.0_beta1
foo_dsp_eq.dll (2013-01-18 15:30:04 UTC)
    Equalizer 1.0
foo_dsp_std.dll (2013-01-18 15:29:58 UTC)
    Standard DSP Array 1.2
foo_fileops.dll (2013-01-18 15:28:32 UTC)
    File Operations 2.2
foo_freedb2.dll (2013-01-18 15:28:12 UTC)
    Online Tagger 0.7
foo_input_std.dll (2013-01-18 15:29:10 UTC)
    Standard Input Array 1.0
foo_jesus.dll (2013-01-21 02:30:13 UTC)
    Autosave & Autobackup 10
foo_lnk.dll (2013-01-21 02:30:13 UTC)
    Shell Link Resolver 1.3.1
foo_midi.dll (2013-01-21 21:16:10 UTC)
    MIDI synthesizer host 1.195
foo_osd.dll (2013-01-21 21:16:10 UTC)
    On-Screen Display 1.73
foo_out_upnp.dll (2013-01-21 04:58:04 UTC)
    UPnP MediaRenderer Output 1.0 beta 3
foo_playcount.dll (2013-01-21 02:30:14 UTC)
    Playback Statistics 3.0.2
foo_plorg.dll (2013-01-21 02:30:14 UTC)
    Playlist Organizer 2.4
foo_rgscan.dll (2013-01-18 15:29:44 UTC)
    ReplayGain Scanner 2.1.2
foo_softplaylists.dll (2013-01-21 02:30:14 UTC)
    Soft Playlists 2011-02-05
foo_ui_columns.dll (2013-01-21 02:30:15 UTC)
    Columns UI 0.3.8.8
foo_ui_panels.dll
foo_ui_std.dll (2013-01-18 15:29:12 UTC)
    Default User Interface 0.9.5
foo_uie_albumlist.dll (2013-01-21 02:30:14 UTC)
    Album list panel 0.3.5
foo_uie_biography.dll (2013-01-21 02:30:14 UTC)
    Biography View 0.4.2.4
foo_uie_lyrics3.dll (2013-01-21 02:30:14 UTC)
    Lyric Show Panel 3 0.3.5.2
foo_uie_panel_splitter.dll (2013-01-21 02:30:14 UTC)
    Panel Stack Splitter 0.3.8.3(alpha)
foo_uie_quicksearch.dll (2013-01-21 02:30:14 UTC)
    Quick Search Toolbar 2.8l
foo_uie_wsh_panel_mod.dll (2013-01-21 02:30:14 UTC)
    WSH Panel Mod 1.5.6
foo_unpack.dll (2013-01-18 15:29:52 UTC)
    ZIP/GZIP/RAR Reader 1.6
foo_wave_seekbar.dll (2013-01-21 21:16:10 UTC)
    Waveform seekbar 0.2.29
I'm seeing lots of file-related components there that I don't have, and I have no problems on Win8x64.
If the others can post their component lists, we can cross-reference.
Exact same issue here. Starting with 1.2.2, doing any file operations (such as renaming) cause a large delay before the file shows back in the library (up to 20 seconds). Prior versions showed the file with the new file name almost instantly. When I went to investigate I noticed I had the 'Invalid parameters' error, too. However, since I saw it the first time I have yet to see it again, so who knows if it's related..
Just wanted to bump this again.
I got an Error! again today, when using DefaultUI. The next thing I am going to try is completely removing Foobar from my system, and deleting all traces from it. Then reinstalling and setting it up from scratch again.
You can try install it as portable, which are not shared with any installed versions.
Advanced mode: Spoiler (click to show/hide)
Hello Friends,
      I have quite similar problems and I posted a bug report a few days ago.
Peter replied me informing that the bug will be fixed in the next release 1.2.3
Regards, Andrea.
Thanks for the update.
