Topic: foo_midi (Read 21074 times) previous topic - next topic
foo_midi
The .syx file must continue to exist on disk after you have added it. It merely adds the file's path as a reference to the tag database for those MIDI files.
foo_midi
Yes, both files (.mid and .syx) exist on disk in the same directory but I get the error anyway.
foo_midi
Ok, seems like I found the problem. When both files (.mid and .syx) are in the same directory, the plugin does not store the complete path to the .syx in the <MIDI_SYSEX_DUMPS> tag, it just stores the name of the file, and can't find the sysex file on playback. However, if I put the sysex in a different directory than where the midi file is, it does store the complete path and finds it on playback.
foo_midi
Thanks for your research, algernon64, but in my case to be able to play midi files with assigned sysex dumps I had to use .syx file copied to different disk. It seems that foo_midi stores relative paths to .syx files, and while playing it expects full path instead.
Thus "..\..\..\foo.syx" leads to error, and "c:\foo.syx" works fine.
So I'd like to kindly ask kode54 to implement it right.
Thanks for your time!
foo_midi
And huge thanks to kode54, with recent fix midi files with assigned .SYX play juuuust fine!
foo_midi
Wrong thread sorry, (comes as first result for foo_midi on Google)
