Topic: EAC says last track’s quality=100%, but AccurateRip couldn’t verify it (Read 3502 times) previous topic - next topic
Hey there,
I was using my Plextor external USB drive to rip "Classical Hits" with EAC yesterday when something weird happened.  The rip seemed to go fine (just like most of my rips do), but when I checked the log for AccurateRip I noticed that the last track couldn't be verified as accurate.  What was strange was the track quality was 100% and test / copy CRCs matched.  Another thing: if you notice, it's AR v2 and not AR v1 like the rest of the CD.  Any ideas why this could have happened?  Thanks in advance.
Exact Audio Copy V1.0 beta 3 from 29. August 2011
EAC extraction logfile from 14. January 2013, 23:40
Various Artists / Classical Hits
Used drive  : PLEXTOR DVDR  PX-708A  Adapter: 1  ID: 0
Read mode              : Secure
Utilize accurate stream : Yes
Defeat audio cache      : Yes
Make use of C2 pointers : No
Read offset correction                      : 30
Overread into Lead-In and Lead-Out          : Yes
Delete leading and trailing silent blocks  : No
Null samples used in CRC calculations      : Yes
Used interface                              : Native Win32 interface for Win NT & 2000
Gap handling                                : Appended to previous track
Used output format              : User Defined Encoder
Selected bitrate                : 224 kBit/s
Quality                        : High
Add ID3 tag                    : No
Command line compressor        : C:\lame3.99.5\lame.exe
Additional command line options : -V2 --add-id3v2 --tt "%title%" --ta "%artist%" --tl "%albumtitle%" --ty "%year%" --tn "%tracknr%" --tg "%genre%" %source% %dest%
TOC of the extracted CD
    Track |  Start  |  Length  | Start sector | End sector
        1  |  0:00.00 |  3:27.15 |        0    |    15539
        2  |  3:27.15 |  4:43.47 |    15540    |    36811
        3  |  8:10.62 |  4:16.38 |    36812    |    56049
        4  | 12:27.25 |  3:33.70 |    56050    |    72094
        5  | 16:01.20 |  2:57.10 |    72095    |    85379
        6  | 18:58.30 |  4:31.10 |    85380    |  105714
        7  | 23:29.40 |  5:09.32 |    105715    |  128921
        8  | 28:38.72 |  2:53.65 |    128922    |  141961
        9  | 31:32.62 |  2:46.23 |    141962    |  154434
      10  | 34:19.10 |  2:33.20 |    154435    |  165929
      11  | 36:52.30 |  3:46.50 |    165930    |  182929
      12  | 40:39.05 |  3:44.15 |    182930    |  199744
      13  | 44:23.20 |  4:22.07 |    199745    |  219401
      14  | 48:45.27 |  3:01.13 |    219402    |  232989
      15  | 51:46.40 |  2:39.30 |    232990    |  244944
      16  | 54:25.70 |  2:53.72 |    244945    |  257991
      17  | 57:19.67 |  2:55.13 |    257992    |  271129
      18  | 60:15.05 |  3:14.27 |    271130    |  285706
      19  | 63:29.32 |  5:50.60 |    285707    |  312016
      20  | 69:20.17 |  2:56.63 |    312017    |  325279
Track  1
    Filename C:\Rips\Various Artists\Classical Hits\01 Pie Jesu.wav
    Pre-gap length  0:00:02.00
    Peak level 42.3 %
    Extraction speed 4.0 X
    Track quality 100.0 %
    Test CRC C8A71C74
    Copy CRC C8A71C74
    Accurately ripped (confidence 3)  [96317B69]  (AR v1)
    Copy OK
Track  2
    Filename C:\Rips\Various Artists\Classical Hits\02 Victory.wav
    Pre-gap length  0:00:01.70
    Peak level 39.4 %
    Extraction speed 4.6 X
    Test CRC 2840931A
    Copy CRC 2840931A
    Accurately ripped (confidence 3)  [B6BAAF6E]  (AR v1)
    Copy OK
Track  3
    Filename C:\Rips\Various Artists\Classical Hits\03 Duel of the Fates (From Star Wars Episode 1- The Phantom Menace).wav
    Pre-gap length  0:00:03.27
    Peak level 99.9 %
    Extraction speed 5.0 X
    Test CRC 2AF4245F
    Copy CRC 2AF4245F
    Accurately ripped (confidence 3)  [AF9DDA43]  (AR v1)
    Copy OK
Track  4
    Filename C:\Rips\Various Artists\Classical Hits\04 Wishing You Were Somehow Here Again (From Phantom of the Opera).wav
    Pre-gap length  0:00:02.45
    Peak level 67.8 %
    Extraction speed 5.2 X
    Test CRC DB3080B8
    Copy CRC DB3080B8
    Accurately ripped (confidence 3)  [A63DDA60]  (AR v1)
    Copy OK
Track  5
    Filename C:\Rips\Various Artists\Classical Hits\05 Rose (From Titanic).wav
    Pre-gap length  0:00:04.10
    Peak level 36.9 %
    Test CRC D7E04F23
    Copy CRC D7E04F23
    Accurately ripped (confidence 3)  [7C998CEC]  (AR v1)
    Copy OK
Track  6
    Filename C:\Rips\Various Artists\Classical Hits\06 Nella fantasia.wav
    Pre-gap length  0:00:04.73
    Peak level 38.2 %
    Extraction speed 5.9 X
    Test CRC EAD4ADCC
    Copy CRC EAD4ADCC
    Accurately ripped (confidence 3)  [F25141CA]  (AR v1)
    Copy OK
Track  7
    Filename C:\Rips\Various Artists\Classical Hits\07 Pavane.wav
    Pre-gap length  0:00:03.68
    Peak level 63.7 %
    Extraction speed 5.4 X
    Track quality 99.9 %
    Test CRC 51E40C54
    Copy CRC 51E40C54
    Accurately ripped (confidence 3)  [2375B3C8]  (AR v1)
    Copy OK
Track  8
    Filename C:\Rips\Various Artists\Classical Hits\08 O mio babbino caro.wav
    Pre-gap length  0:00:03.57
    Peak level 100.0 %
    Extraction speed 6.0 X
    Test CRC 0B17DDDD
    Copy CRC 0B17DDDD
    Accurately ripped (confidence 3)  [D3C02F6C]  (AR v1)
    Copy OK
Track  9
    Filename C:\Rips\Various Artists\Classical Hits\09 Jesu, Joy of Man's Desiring.wav
    Pre-gap length  0:00:04.40
    Peak level 40.5 %
    Extraction speed 4.7 X
    Test CRC 527D23AC
    Copy CRC 527D23AC
    Accurately ripped (confidence 3)  [17F43F3A]  (AR v1)
    Copy OK
Track 10
    Filename C:\Rips\Various Artists\Classical Hits\10 'O sole mio.wav
    Peak level 75.4 %
    Extraction speed 6.3 X
    Test CRC EB1D6643
    Copy CRC EB1D6643
    Accurately ripped (confidence 3)  [9058872D]  (AR v1)
    Copy OK
Track 11
    Filename C:\Rips\Various Artists\Classical Hits\11 Maria (From West Side Story Suite).wav
    Pre-gap length  0:00:03.60
    Peak level 98.8 %
    Extraction speed 6.8 X
    Test CRC FC41AE48
    Copy CRC FC41AE48
    Accurately ripped (confidence 3)  [ECD84766]  (AR v1)
    Copy OK
Track 12
    Filename C:\Rips\Various Artists\Classical Hits\12 The Second Waltz.wav
    Pre-gap length  0:00:01.43
    Peak level 77.6 %
    Extraction speed 7.0 X
    Test CRC 62F688A4
    Copy CRC 62F688A4
    Accurately ripped (confidence 3)  [0F44A409]  (AR v1)
    Copy OK
Track 13
    Filename C:\Rips\Various Artists\Classical Hits\13 Now We Are Free (From Gladiator).wav
    Pre-gap length  0:00:03.20
    Peak level 56.2 %
    Extraction speed 7.5 X
    Test CRC 15D2A292
    Copy CRC 15D2A292
    Accurately ripped (confidence 3)  [313E1FD6]  (AR v1)
    Copy OK
Track 14
    Filename C:\Rips\Various Artists\Classical Hits\14 The Eternal Vow (From Crouching Tiger, Hidden Dragon).wav
    Peak level 60.7 %
    Extraction speed 7.3 X
    Test CRC C834BA62
    Copy CRC C834BA62
    Accurately ripped (confidence 3)  [2A72ECE7]  (AR v1)
    Copy OK
Track 15
    Filename C:\Rips\Various Artists\Classical Hits\15 O Fortuna (From Carmina Burana).wav
    Pre-gap length  0:00:03.43
    Peak level 100.0 %
    Test CRC BD23F3A6
    Copy CRC BD23F3A6
    Accurately ripped (confidence 3)  [DAD32CF3]  (AR v1)
    Copy OK
Track 16
    Filename C:\Rips\Various Artists\Classical Hits\16 Main Title (From Braveheart).wav
    Pre-gap length  0:00:03.48
    Peak level 37.7 %
    Extraction speed 5.8 X
    Test CRC 66533F98
    Copy CRC 66533F98
    Accurately ripped (confidence 2)  [1AEC0F01]  (AR v1)
    Copy OK
Track 17
    Filename C:\Rips\Various Artists\Classical Hits\17 The Prince of Denmark's March.wav
    Pre-gap length  0:00:04.42
    Peak level 76.6 %
    Extraction speed 7.7 X
    Test CRC 0CD3AE2D
    Copy CRC 0CD3AE2D
    Accurately ripped (confidence 2)  [7C7997B6]  (AR v1)
    Copy OK
Track 18
    Filename C:\Rips\Various Artists\Classical Hits\18 Spring (From The Four Seasons).wav
    Pre-gap length  0:00:04.00
    Peak level 69.7 %
    Extraction speed 7.9 X
    Test CRC 3FCF24C4
    Copy CRC 3FCF24C4
    Accurately ripped (confidence 3)  [1F2346B2]  (AR v1)
    Copy OK
Track 19
    Filename C:\Rips\Various Artists\Classical Hits\19 Appalachia Waltz.wav
    Pre-gap length  0:00:03.35
    Peak level 33.6 %
    Extraction speed 8.6 X
    Test CRC D0721770
    Copy CRC D0721770
    Accurately ripped (confidence 3)  [F35C6534]  (AR v1)
    Copy OK
Track 20
    Filename C:\Rips\Various Artists\Classical Hits\20 Nessun dorma!.wav
    Pre-gap length  0:00:03.50
    Peak level 89.1 %
    Extraction speed 9.5 X
    Test CRC 112AFA6B
    Copy CRC 112AFA6B
    Cannot be verified as accurate (confidence 9)  [22D0D879], AccurateRip returned [D69A8FDD]  (AR v2)
    Copy OK
19 track(s) accurately ripped
 1 track(s) could not be verified as accurate
Some tracks could not be verified as accurate
No errors occurred
End of status report
==== Log checksum 8D1E082C5CB6F285850E54EAD286D73C5FA967DF1579EB79FCE62A017F279BDB ====
There can be many reasons.
One possible reason: This is last track and your drive can "overread". Most of drives can't overread. So maybe your rip is even more "accurate" than results in database.
Agreed Rollin, thanks.  It's just interesting that AR tried to compare it to a different rip using AR v2 instead of AR v1...
From a few days ago, posts #9 and #10.
So you think the rip is bad then?
On the contrary, I think your rip is probably good and the hashes in the database for your specific pressing may be from errant rips that are consistent by virtue of a bug (read more below).  Still, rip the tracks as lossless and let CUETools have a look at them.  It may reduce the amount of blind speculation.
AR ignores the last five frames of the last track, so this shouldn't be an issue.
That said, there are situations where EAC will repeat the last 1176 samples of non-null data (where the last non-null sample is the 1176th sample of the set, regardless of whether it falls on a frame boundary) when a drive that is configured as not being able to overread and those repeated samples may fall before the final five frames of the track, affecting the AR hash.  Note this may explain some (most?) of Spoon's findings which he is attributing as being "more difficult to rip".  These instances have to do with a bug in EAC; they have nothing to do with the disc being "difficult to rip".  To my knowledge there is no mechanism in AR to catch this problem.
Perhaps before checking a lossless version against CUETools, I'd rip the last track again with overreading disabled and see what AR says.  If it says the tracks are accurate then I'd say keep the ones done with the setting enabled.  Personally I'd also compare lossless versions of each to see the differences for myself and to verify my suspicion about the submissions in the AR database being consistent errors due to defective software, but that's just me.
