I'm making a C++ program that recordes audio from microphone and encodes it to MPEG4 MAIN AAC file . I made a function for encoding to AAC using libfaac and i got weird output file.I don't know what i'm doing wrong .Could you tell me what's wrong in my function.This is my RAW PCM 16-bit file File and this is output file File
Here's my code.
static void encodeAac( const char *infilename,const char *filename)
faacEncHandle codec;
faacEncConfigurationPtr conf;
SAMPLE* samples;
uint8_t* outbuf;
unsigned long* one;
unsigned long* two;
int outsize;
one=new unsigned long;
two = new unsigned long;
codec=faacEncOpen(SAMPLE_RATE,NUM_CHANNELS,one,two);
if(!codec){
error("Something went wrong");
return;
conf=faacEncGetCurrentConfiguration(codec);
conf->mpegVersion=MPEG4;
conf->aacObjectType=MAIN;
faacEncSetConfiguration(codec,conf);
FILE *f = fopen(filename, "wb");
FILE *fin=fopen(infilename,"rb");
if (!fin) {
error("could not open temporary file");
if (!f) {
error("could not open output file");
samples = new SAMPLE[*one];
outbuf = new uint8_t[*two];
while(fread(samples,sizeof(SAMPLE),*one,fin)){
outsize=faacEncEncode(codec,(int*)samples,*one,outbuf,*two);
fwrite(outbuf,sizeof(uint8_t),outsize,f);
while(outsize != 0){
outsize=faacEncEncode(codec,NULL,NULL,outbuf,*two);
fclose(f);
fclose(fin);
delete outbuf;
delete samples;
faacEncClose(codec);
