Topic: How do I seamlessly play all my playlists in sequence?  (Read 2747 times) previous topic - next topic
Hi guys. How do I seamlessly play all my playlists in sequence?
Have a look at foo_stopafteralbum:
Menu | Playback | Control | Next playlist (ON/OFF)
I have a feeling it will play each playlist to the end then go to the one to the right and carry on.
C.
C.
I don't know why but it doesn't work for me. I use 'elplaylist' + 'library tree' in 'panels stack splitter' which includes playlists.
EDIT:
Changed foobar's playback order from 'repeat playlist' to 'default' - that was the culprit. Now everything's just fine. Thank you for suggestion.
Take a closer look!
One of the available actions is "change plalist"
