Topic: foobar2000 player v0.666 released (Read 6228 times) previous topic - next topic
http://foobar2000.hydrogenaudio.org/
Changes:
- removed replaygain-scan-while-playing
- fixed some playlist repainting glitches
- due to extreme abuse, preamp DSP is no longer included in compiled form
- moved dithering config to playback page
- added debug info about metadb_handle leaks when shutting down
- workedaround glitch with multiple "open file" dialogs being open through systray
- fixed "add directory" with network drives
- improved diskwriter progress display
- track info display updates are now properly sync'd with output lag, no more track info displayed ahead of actual sound
- improved handling of invalid data in apev2 tags
- improved albumlist speed
- added ABX component
- corrected FLAC seeking glitch
- separate win9x/winnt versions of diskwriter (for proper display of file names)
- CD burning component (uses Nero libraries)
- added reading length from MP3 files with VBRI headers
- fixed database issues with "readonly" mode
- improved performance with really huge playlists (tested with ~800k entries)
- state of "show all formats" in playback settings is no longer saved between instances (read warning message to see why)
- option not to reset DSP between tracks in diskwriter
- fixed issues with directory names ending with dots in masstagger
This is probably an obvious question Peter, but since the CD burning component relies on Nero libraries, does one need a retail version of Nero installed for this to work?
    - M.
He answered this already.
He said that he knew that most of us have Nero installed, legally or not, so using Nero for his writing component seemed a perfectly reasonable choice for him.
He sais that he knew that most uf us have Nero installed, legally or not, so using Nero for his writing component seemed a perfectly reasonable choice for him.
Ahh... I missed his earlier post. Unfortunately, I do not have Nero installed (and I'm not going to install an unlicensed version, either), so this leaves me out in the cold. Unless, of course, the plugin (or another plugin) could be made to work with CDRDAO, CDRTools, or some other freeware burning component.
    - M.
Well, seems Peter won't write it.
In the same post (it's on the foobar forum) he said that he wouldn't/couldn't use the freeware tools such as CDRDAO bacause of some GPL issues.
Why don't you go and procure yourself a version of Nero?
There are many CD writers available.  Why not use one of them.  EAC would work.  It is good; it is free.
Nov schmoz kapop.
1. You don't need to break the GPL to write a plugin that uses CDRDAO, you just have to use Foobar to write the TOC and WAVs and parse some command lines to CDRDAO, and It would not break the GPL (as in BAO), since you could get the user to download CDRDAO separately.
2. Because Nero is not a good (IMHO) burning app!
( I just needed to use that smilie!)
"You have the right to remain silent. Anything you say will be misquoted, then used against you."
I find it kinda silly that you need to download Nero at 15mb(?) to use a 16kb plugin.  I'll stick to BAO as I like the whole 'one tool for one job' concept. It's why I like foobar2000 to start with.
Not the point... I already use EAC, and happen to prefer it. I was simply commenting that it would be nice, if a burning plugin exists for a freeware application, for the plugin to be usable without one also having to purchase a commercial application.
    - M.
Nice version number  In memoriam of the infamous Winamp 2.666 maybe
Ahh the flac seek glitch is fixed, thanks Peter.
