Topic: CDDA Freedb plugin (Read 34598 times) previous topic - next topic
CDDA Freedb plugin
Reply #50
I have to apologize about the wait on updates to the plugin.  I've been very busy with school and work in the last few weeks.  Don't worry, this doesn't mean the end to the plugin, just a short delay.  I should be able to get to it soon.  With a slowing of the releases to fb2k lately, it makes this more of a reality.
Also, I plan on releasing the source eventually but first I need to finish things and clean it up a bit.  I'll probably get that on the web in a month or so.
CDDA Freedb plugin
Reply #51
Chillout, dont hurry, plug will be better  if it will be done in quiet and order
CDDA Freedb plugin
Reply #52
I think this plugin is broken in RC14....it loads the track info fine, but when the next track starts playing it goes back to the generic CD track #.
CDDA Freedb plugin
Reply #53
I see the same problem here with the latest foobar RC14.
CDDA Freedb plugin
Reply #54
like slothdog and error404 i've same situation with flatbinary's cddb plugin in RC14. it loads data ok but when i click on specific track it displays "cd track x". any solution yet?
CDDA Freedb plugin
Reply #55
I don't think it is plugin's fault.
Try to load cdda track, manually edit info, play track -> all info disappears...
CDDA Freedb plugin
Reply #56
Yeah, sorry about that, I haven't installed the new version of fb2k yet.  I'll look at it tonight and try to figure out what's going on.
CDDA Freedb plugin
Reply #57
Seems to be fixed in RC15....
CDDA Freedb plugin
Reply #58
Great news indeed, working here as well
CDDA Freedb plugin
Reply #59
If field is empty "key=" is written. can't it just be left out?
would it be possible to "tag" files with "normal routines" (masstagger, file info).
CDDA Freedb plugin
Reply #60
yep! it's functional again in RC15
CDDA Freedb plugin
Reply #61
I got some problems with this plugin... When I am playing a MP3 playlist, and I pop in an audio disc (I set it to autorun), it'll sorta crash, and foobar will just start to keep sucking memory in...
When I kill foobar, and restart, it'll work like a charm.
I'm using it with foobar 0.8.1 (but it sorta happened in the previous builds as well)....
CDDA Freedb plugin
Reply #62
Any plan to get this to work with .8 or .81? I really like this plugin better than foo_freedb, but I can't get it to work at the moment. There is no "Play Audio CD" anywhere.
CDDA Freedb plugin
Reply #63
Hi.
Can I submit info to FreeDB using Foobar?
CDDA Freedb plugin
Reply #64
[a href="index.php?act=findpost&pid=229033"][{POST_SNAPBACK}][/a]
AFAIK no.
CDDA Freedb plugin
Reply #65
AFAIK no.
Hallo is this information still up-to-date, I would like to submit data to freedb, but I don't want to use another application...
best regards
nlights
