Topic: Current mp3gain alternatives for reducing clipping? (Read 19621 times) previous topic - next topic
MP3s directly encoded from loudness war era CD audio often do clip (go above 0dB). Some hardware will have extra bits to handle this (by doing their actual decoding at -6dB or other techniques), but most decoders will decode this as a max-value clip.
If you want to manually reduce the output level of an MP3 without re-encoding, you can use mp3directcut.
Use the option edit->normalize, stop analysis and manually set the gain of the whole file to -12dB and press OK. Then run normalize again. If the level change after analysis is less than +12dB then apply it and save, because the decoded output of the original MP3 was clipped. If you want headroom for equalizers and post-processors that may exceed hardware clipping limits, you can reduce the post-analysis normalization level by -3dB or more.
