Re: UPnP MediaRenderer output | discussion Reply #450 – 2020-07-11 15:59:38 I use Foobar Recorder component together with VB-Audio Hi-Fi Cable.Cheers
Re: UPnP MediaRenderer output | discussion Reply #451 – 2020-07-12 12:27:55 I managed this Plugin to work with DLNA to my AV-Receiver. But the info it shows on it's display is just "Foorbar2000 audio stream". Is it possible to change this to song information as they are displayed in foobar?
Re: UPnP MediaRenderer output | discussion Reply #452 – 2020-07-24 16:13:31 Hi to all,I'm trying to stream audio from fb2k on pc to Denon avr-x2600h using foo_out_upnp, but the receiver gives a massage "Unable to play media. Please try again later."Also, what configuration must be for streaming 24bit/192kHz?here are my configs in fb2k:device detailsFriendly name : Denon AVR-X2600HIP address : 192.168.0.143Manufacturer : DenonManufacturer URL : http://www.denon.comModel : Denon AVR-X2600HModel number : Aios 4.025Supported formats:http-get:*:audio/mpeg:*http-get:*:audio/vnd.dlna.adts:*http-get:*:audio/x-ms-wma:*http-get:*:audio/x-ms-wma:*http-get:*:audio/L16;rate=48000;channels=2:*http-get:*:audio/L16;rate=48000;channels=1:*http-get:*:audio/L16;rate=44100;channels=2:*http-get:*:audio/L16;rate=44100;channels=1:*http-get:*:audio/wav:*http-get:*:audio/mp3:*http-get:*:audio/flac:*http-get:*:audio/aac:*http-get:*:audio/m4a:*---------------------------------------------------------------upnp output config:# defaults that apply to every devicestream-title=foobar2000 audio stream# default preferred format, can be overridden per-device; available are: FLAC, WAV, LPCM# default to FLAC where supportedpreferred-format=FLAC# Various devices fail to pause on what they assume to be a live stream, require a stop command# Can be overridden to true for specific devicessupports-pause=true# Default to FLAC not supported even if the device claims otherwise# Many report that they support FLAC yet fail to play an infinite length FLAC streamsupports-FLAC=falsemanufacturer=Denonmodel= Denon AVR-X2600Hsupports-FLAC=truepreferred-format=FLAC Last Edit: 2020-07-24 16:15:28 by xrsxlnx
Re: UPnP MediaRenderer output | discussion Reply #453 – 2020-07-24 16:30:48 Have you tried default upnp output config without any specific configuration for your receiver?
Re: UPnP MediaRenderer output | discussion Reply #454 – 2020-07-24 22:25:03 Yes. first i did all with default settings and after went through the topic trying to configure and make changes people were doing with their devices. No luck so far, and the message is same always regardless any changes. here my components, maybe some are odd in my caseCore (2020-06-29 11:49:42 UTC) foobar2000 core 1.5.5foo_albumlist.dll (2020-06-29 11:49:14 UTC) Album List 4.7foo_cdda.dll (2020-06-29 11:48:58 UTC) CD Audio Decoder 1.5.5foo_converter.dll (2020-06-29 11:49:06 UTC) Converter 1.5.5foo_dsp_eq.dll (2020-06-29 11:49:00 UTC) Equalizer 1.2.2foo_dsp_std.dll (2020-06-29 11:48:56 UTC) Standard DSP Array 1.5.5foo_fileops.dll (2020-06-29 11:48:58 UTC) File Operations 1.5.5foo_freedb2.dll (2020-06-29 11:48:58 UTC) Online Tagger 0.7foo_input_std.dll (2020-06-29 11:49:32 UTC) FFmpeg Decoders 3.4.6-0ac9001 Standard Input Array 1.5.5foo_out_asio.dll (2016-01-03 10:40:20 UTC) ASIO support 2.1.2foo_out_upnp.dll (2020-07-24 13:12:04 UTC) UPnP MediaRenderer Output 1.3.2foo_out_wasapi.dll (2017-06-19 22:32:30 UTC) WASAPI output support 3.3foo_rgscan.dll (2020-06-29 11:49:10 UTC) ReplayGain Scanner 1.5.5foo_ui_columns.dll (2011-02-27 20:22:58 UTC) Columns UI 0.3.8.8foo_ui_std.dll (2020-06-29 11:49:18 UTC) Default User Interface 1.5.5foo_unpack.dll (2020-06-29 11:49:06 UTC) ZIP/GZIP/RAR Reader 1.8foo_upnp.dll (2020-07-24 12:52:14 UTC) UPnP/DLNA Renderer, Server, Control Point 0.99.49 Last Edit: 2020-07-24 22:28:07 by xrsxlnx
Re: UPnP MediaRenderer output | discussion Reply #455 – 2020-09-12 00:54:52 Hello,I am using SONY SRS-ZR7 wireless speaker.I can use WMP to cast to that device, but cannot use this component to output.The setting of component is in default.FB2K 1.6 and component 1.3.2QuoteOpening track for playback: "D:\Music\[200805] 5thアルバム「STRAY SHEEP」/米津玄師 (Hi-Res)\002-Flamingo.flac"[UPnP] Opening device:[UPnP] manufacturer=Sony Corporation[UPnP] model=SRS-ZR7[UPnP] name=SRS-ZR7 349B02[UPnP] Stream format: 24-bit 48000Hz 2ch[UPnP] Device protocol info:[UPnP] http-get:*:audio/L16:DLNA.ORG_PN=LPCM;DLNA.ORG_FLAGS=9d300000000000000000000000000000,http-get:*:audio/mpeg:DLNA.ORG_PN=MP3;DLNA.ORG_FLAGS=9d300000000000000000000000000000,http-get:*:audio/mpeg:DLNA.ORG_PN=MP3X;DLNA.ORG_FLAGS=9d300000000000000000000000000000,http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMABASE;DLNA.ORG_FLAGS=9d300000000000000000000000000000,http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMAFULL;DLNA.ORG_FLAGS=9d300000000000000000000000000000,http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS;DLNA.ORG_FLAGS=9d300000000000000000000000000000,http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS_192;DLNA.ORG_FLAGS=9d300000000000000000000000000000,http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS_320;DLNA.ORG_FLAGS=9d300000000000000000000000000000,http-get:*:audio/mp4:DLNA.ORG_PN=AAC_ISO;DLNA.ORG_FLAGS=9d300000000000000000000000000000,http-get:*:audio/3gpp:DLNA.ORG_PN=AAC_ISO;DLNA.ORG_FLAGS=9d300000000000000000000000000000,http-get:*:audio/mp4:DLNA.ORG_PN=AAC_ISO_192;DLNA.ORG_FLAGS=9d300000000000000000000000000000,http-get:*:audio/3gpp:DLNA.ORG_PN=AAC_ISO_192;DLNA.ORG_FLAGS=9d300000000000000000000000000000,http-get:*:audio/mp4:DLNA.ORG_PN=AAC_ISO_320;DLNA.ORG_FLAGS=9d300000000000000000000000000000,http-get:*:audio/3gpp:DLNA.ORG_PN=AAC_ISO_320;DLNA.ORG_FLAGS=9d300000000000000000000000000000,http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=HEAAC_L2_ADTS;DLNA.ORG_FLAGS=9d300000000000000000000000000000,http-get:*:audio/mp4:DLNA.ORG_PN=HEAAC_L2_ISO;DLNA.ORG_FLAGS=9d300000000000000000000000000000,http-get:*:audio/3gpp:DLNA.ORG_PN=HEAAC_L2_ISO;DLNA.ORG_FLAGS=9d300000000000000000000000000000,http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=HEAAC_L2_ADTS_320;DLNA.ORG_FLAGS=9d300000000000000000000000000000,http-get:*:audio/mp4:DLNA.ORG_PN=HEAAC_L2_ISO_320;DLNA.ORG_FLAGS=9d300000000000000000000000000000,http-get:*:audio/3gpp:DLNA.ORG_PN=HEAAC_L2_ISO_320;DLNA.ORG_FLAGS=9d300000000000000000000000000000,http-get:*:audio/mp4:DLNA.ORG_PN=HEAAC_L2_ISO_128;DLNA.ORG_FLAGS=9d300000000000000000000000000000,http-get:*:audio/3gpp:DLNA.ORG_PN=HEAAC_L2_ISO_128;DLNA.ORG_FLAGS=9d300000000000000000000000000000,http-get:*:audio/mpeg:*,http-get:*:audio/L16:*,http-get:*:audio/wav:*,http-get:*:audio/x-wav:*,http-get:*:audio/x-ms-wma:*,http-get:*:audio/mp4:*,http-get:*:audio/3gpp:*,http-get:*:audio/vnd.dlna.adts:*,http-get:*:audio/flac:*,http-get:*:audio/x-flac:*,http-get:*:audio/aiff:*,http-get:*:audio/x-aiff:*,http-get:*:audio/aif:*,http-get:*:audio/x-aif:*,http-get:*:audio/m4a:*,http-get:*:audio/x-m4a:*,http-get:*:audio/x-alac:*,http-get:*:audio/x-monkeys-audio:*,http-get:*:audio/ape:*,http-get:*:audio/x-ape:*,http-get:*:audio/dsd:*,http-get:*:audio/x-dsd:*[UPnP] Listening on: 192.168.1.76[UPnP] Stream address: http://192.168.1.76:61261/4/stream.wav[UPnP] Returned time: 0:00:00[UPnP] Transport state: NO_MEDIA_PRESENT[UPnP] Returned time: 0:00:00[UPnP] Transport state: NO_MEDIA_PRESENT[UPnP] SetAVTransportURI failure: Action SetAVTransportURI failed[UPnP] == LAST REPLY XML ==[UPnP] <?xml version="1.0"?><s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>716</errorCode><errorDescription>Action SetAVTransportURI failed</errorDescription></UPnPError></detail></s:Fault></s:Body></s:Envelope>[UPnP] == XML END ==Unrecoverable playback error: Action SetAVTransportURI failed[UPnP] Detached transport op failure: Action Stop failed[UPnP] == LAST REPLY XML ==[UPnP] <?xml version="1.0"?><s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>701</errorCode><errorDescription>Action Stop failed</errorDescription></UPnPError></detail></s:Fault></s:Body></s:Envelope>[UPnP] == XML END ==
Re: UPnP MediaRenderer output | discussion Reply #456 – 2020-09-13 03:06:39 Quote from: Stevie123 on 2020-07-12 12:27:55I managed this Plugin to work with DLNA to my AV-Receiver. But the info it shows on it's display is just "Foorbar2000 audio stream". Is it possible to change this to song information as they are displayed in foobar?Did you ever find out anymore on this? The functionality of this app allowing you to select DLNA devices from the actual outputs in foobar is much better than the other DLNA plug-in, but i really want to have at least, ARTIST - SONG..
Re: UPnP MediaRenderer output | discussion Reply #457 – 2020-09-23 04:34:37 This component has solved alot of issues for me being able to play music from my laptop over my Yamaha receivers. For the most part, it works really well and correctly discovers my receivers in my home ethernet network. The only thing I would like to see if more development. I messaged the author and asked if he didn't want to develop it anymore, if he would release the source code so one of you clever programmers could keep it going. Unfortunately I never got a reply. I would love to see the tag information show up on the device playing the music as an example. I tried playing around with the INI/CFG file but was never able to make any progress. I know it is a long shot. (I did try the other UPnP component also).
Re: UPnP MediaRenderer output | discussion Reply #458 – 2020-10-16 19:58:53 Hi,I have installed this plugin in hope that I will be able to play music directly from my laptop.Unfortunately I cant hear anything on my Denon AVR-X2400H. When I try to play anything on Foobar it stops.My configuration :# defaults that apply to every devicestream-title=foobar2000 audio stream# default preferred format, can be overridden per-device; available are: FLAC, WAV, LPCM# default to FLAC where supportedpreferred-format=FLAC# Various devices fail to pause on what they assume to be a live stream, require a stop command# Can be overridden to true for specific devicessupports-pause=true# Default to FLAC not supported even if the device claims otherwise# Many report that they support FLAC yet fail to play an infinite length FLAC streamsupports-FLAC=falsemanufacturer=Denonmodel= Denon AVR-X2400Hsupports-FLAC=truepreferred-format=FLACDevice info:Friendly name : Denon AVR-X2400HIP address : 192.168.1.251Manufacturer : DenonManufacturer URL : http://www.denon.comModel : Denon AVR-X2400HModel number : Aios 4.025Supported formats:http-get:*:audio/mpeg:*http-get:*:audio/vnd.dlna.adts:*http-get:*:audio/x-ms-wma:*http-get:*:audio/x-ms-wma:*http-get:*:audio/L16;rate=48000;channels=2:*http-get:*:audio/L16;rate=48000;channels=1:*http-get:*:audio/L16;rate=44100;channels=2:*http-get:*:audio/L16;rate=44100;channels=1:*http-get:*:audio/wav:*http-get:*:audio/mp3:*http-get:*:audio/flac:*http-get:*:audio/aac:*http-get:*:audio/m4a:*I've tried all formats and it doesn't work on anything. Just doesn't want to play. I can only control volume via Foobar.I have tried "Stream What You Hear" program and it doesn't play a sound also.Both programs Foobar and Stream What You Hear detects my AVR but give no sound.I have also tried windows media player and option "render to device" works fine and I can hear sound but cant change volume and it always stops after one song.What is wrong ?
Re: UPnP MediaRenderer output | discussion Reply #459 – 2020-12-16 18:57:40 HiIs there any way for the title and artist name to be displayed on the network player?Displaying a Song - Artists in UPnPstream-title = ?Originally it displays only what is entered with = xxxxxUsed Denon DNP-F109
Re: UPnP MediaRenderer output | discussion Reply #460 – 2020-12-18 18:17:13 Hello everyone! First post here. I cannot figure out what I am doing wrong but none of my devices ate showing under the "Device" tab under "Output" in the "Playback" section of the preferences. In BubbleUPnp I see my Denon, Plex, Foobar, and DirectTV as Servers, all enabled. I see Foobar, Denon (x4400h), Sheild and JBL Link in Renders also in the BubbleUPnP Server. I have the Foobar plugin installed. I see the UPnp Section under tools. So I do not understand why nothing is showing under devices.I would really appreciate any help I can get as I have been dying to leave apple and airplay2 for years. Thanks in advance!
Re: UPnP MediaRenderer output | discussion Reply #461 – 2020-12-20 20:23:48 Hello, I have an issue with my AV receiver Onkyo TX-RZ840. I can't see my receiver in the list of found devices on the "UPnP MediaRender Output page", although I can see it in the list of media renders in the windows. The receiver shows in the list for a while after the unplugging from the electrical socket and plugging back again, but then it dissapears. Streaming to my receiver worked well, but now (after the receiver's firmware update), it stoped working. I checked the forum and found, that several users had the same issue with other receiver's brands (Denon, Marantz) and you fixed the issue by an update of your compomnent. Thanks in advance for help. Last Edit: 2020-12-20 20:53:21 by s.lopik
Re: UPnP MediaRenderer output | discussion Reply #462 – 2020-12-30 07:11:47 Hello,I have got DCH-M225 DLNA wifi player. It is not working with this output plugin. I tried various settings and always says Unrecoverable playback error: Device does not appear to support this audio stream formatLog is lower.Any help possible?foo_upnp: created 1147 path registry entries in 0.015sfoo_upnp: loaded Media Library tree in 0.156sfoo_upnp: created 1147 path registry entries in 0.016sfoo_upnp: loaded Media Library tree in 0.172sOpening track for playback: "C:\Hugues Aufray\04 - Le rossignol anglais.flac"[UPnP] Opening device:[UPnP] manufacturer=D-Link Corporation[UPnP] model=DLNA Media Renderer[UPnP] name=Kuchyn[UPnP] Stream format: 16-bit 44100Hz 2ch[UPnP] Device protocol info:[UPnP] http-get:*:audio/mpeg:DLNA.ORG_PN=MP3, http-get:*:audio/mp4:*, http-get:*:audio/m4a:*, http-get:*:audio/flac:*, http-get:*:audio/x-flac:*, http-get:*:audio/aac:*, http-get:*:audio/x-aac:*, http-get:*:audio/wav:*, http-get:*:audio/x-wav:*Unrecoverable playback error: Device does not appear to support this audio stream format
Re: UPnP MediaRenderer output | discussion Reply #463 – 2021-01-04 08:25:01 So finally my issue I reported on 20.12.2020 was caused by my router. I solved my issue by stopping the UPnP service on my router and restarting again and it works like before.
