Topic: UPnP MediaRenderer output | discussion (Read 166074 times) previous topic - next topic
Re: UPnP MediaRenderer output | discussion
Reply #202
Yet another false positive. A few weeks back their database was in better shape as it was known to be clean. I reported the mistake to two AV companies so the detection will likely get fixed soon.
Reply #203
Virustotal report shows that the Bitdefender false positive issue is fixed.
Reply #204
I'm getting UPnP volume set failure: network timeout all of a sudden. Get, set, query, whatever. All timing out or not connecting.
It was fussy before, with a lot of lag and you could put it past 100... Casting to Dayton Audio WFA-02 if it matters... Turned off firewall, but none of that changed so why would it break?
I was just trying to turned it down in Foobar to turn the amp way up to clean the pot. When I was done I couldn't turn the music back up. Frustrating!
Reply #205
I use Marantz NR 1608 for DMR.
But, it doesn't appear in the devices selection (output).
Environment : Win10(64bit) + foobar2000 v1.3.17 + MediaRenderer output v1.0 beta 18
On the other hand, it appears as a media renderer in "devices and printers" window on windows10.
And Windows Media Player can "Cast to Device" to NR1608 and plays music.
Is there anything I shuld check else?
Reply #206
is it possibile somehow to download previous versions of this component?
Before the last upgrade it was working fine, now the sound is always lagging...
Just to give it a try.
Thank you
Reply #207
I really like this plugin. Works perfectly with Teufel Raumfeld devices (Raumfeld Connector and Teufel One S).
I would really appreciate an enhancement to be able to send the stream simultaneously to different upnp renderers and also to have it on the default sound device of the Computer.
Nice to have would be an option to set the stream delay per device to get all the devices synchronized.
What do you think?
KR
Chris
Reply #208
Hello
I'm very satisfied by the plugin and use it for months now.My media renderer is a Denon DRA 100 and it works perfectly
Is there a way to have the stream title to display dynamic information like %title% or %artist% or both ?
In the panel of parameters, only a static value seems to be valid
Thanks in advance for your help.
Great plugin
Reply #209
I would like to turn off UPnP at the router because of security concerns.
But if I try to disable UPnP in the router administration interface playing to DLNA renderer stars breaking. Looking in foobar's console reveals:
Unrecoverable playback error: UPnP device error: could not connect
How can configure my network to avoid using UPnP? Is it possible?
The DLNA Renderer is dumb, I can't set up anything in it. I can only see its IP and MAC address.
Reply #210
Hello
Is this component dead ?
Very satisfied by the plugin. Would just to have the stream title to display dynamic information like %title% or %artist% or both ?
Thanks in advance for probably coding for a couple of hours.
Best regards
Reply #211
Hi Peter,
Thanks for your hard work on this plugin!
I'm using to play CDs (direct from disc, not rips) to Pioneer N-P01. For the most part, it works perfectly.
When I choose 'pause' in foobar, an error appears about an unsupported operation.
Since I cannot do anything about this, it would be nice to have an option to suppress the error.
A bit more annoying issue: foobar does not remember the paused position, it will start the track again from the beginning.
Reply #212
Hello
Do you have some times after Foobar R1.4 to look at how to have the stream title to display dynamic informations like %title% or %artist% or both ?
Thanks in advance
Best regards
Reply #213
Is it possible to refresh the generated internal UPNP tree list automatically after adding, removing or rearranging items or playlists inside foobar.
At the moment there is no other way to make a refresh without restarting either foobar or the UPNP server itself.
Using reload on the remote client (BubbleUPNP) just seems to re-fetch the cached tree instance from foo-upnp when last the UPNP server was started.
Reply #214
Hi Everyone,
Quick question about the UPNP plugin. Does it work with other active DSPs? So for example, MathAudio Room EQ? Basically I am thinking about replacing my USB DAC with a Cambridge CXN Network Streamer. So I was hoping to be able to stream directly from Foobar to the streamer and still be able to use MathAudio Room EQ.
Thanks for reading.
Reply #215
Hello
I have an issue
I change of Internet provider and so the box change and my network passed from 192.168.0.xxx to192.168.1.xxx
The component doesn't work anymore
The trace in console window is here under
Any help will be appreciated
Thanks in advance
Trace
[UPnP] UPnP begin enum devices
[UPnP] UPnP device: Denon DRA-100 :: http://192.168.1.22:8080/description.xml
[UPnP] UPnP end enum devices
Opening track for playback: "D:\Musique\DISCOTHEQUE\The Valley.flac"
[UPnP] Device protocol info:
[UPnP] http-get:*:audio/L16;rate=44100;channels=1:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;rate=48000;channels=1:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;rate=48000;channels=2:DLNA.ORG_PN=LPCM,http-get:*:audio/mpeg:DLNA.ORG_PN=MP3,http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMABASE,http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMAFULL,http-get:*:audio/mp4:DLNA.ORG_PN=AAC_ISO,http-get:*:audio/mp4:DLNA.ORG_PN=AAC_ISO_320,http-get:*:audio/3gpp:DLNA.ORG_PN=AAC_ISO,http-get:*:audio/3gpp:DLNA.ORG_PN=AAC_ISO_320,http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS,http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS_320,http-wavetunes:*:audio/x-ms-wma:*,http-get:*:audio/wav:*,http-get:*:audio/x-wav:*,http-get:*:audio/flac:*,http-get:*:audio/x-flac:*,http-get:*:audio/x-m4a:*,http-get:*:audio/x-mp4:*,http-get:*:audio/aiff:*,http-get:*:audio/x-aiff:*,http-get:*:audio/dsd:*,http-get:*:audio/x-dsd:*
[UPnP] Listening on: 192.168.1.12:56098
[UPnP] Stream address: http://192.168.1.12:56100/1/stream.wav
[UPnP] transport op: Play
[UPnP] transport op OK, took 0:00.050162
[UPnP] Returned time: 0:00:00
[UPnP] Transport state: TRANSITIONING
infinite loop on those 2 last lines
Reply #216
Hi Everyone,
Thanks for reading.
I am able to stream from FB2K to an Outlaw RR 2160 while using several DSP's.
Reply #217
Problem solved. Root cause was some rules in the Window firewall
Apologies for the anoyance
Hello
I have an issue
Thanks in advance
Trace
Reply #218
Thank you
i have similar problem—0.5-1 sec. interruption after 20-30 minutes playback
but with any component versions
Reply #219
Questions to @Peter :
What is the list of OS system services that this plugin relies on?
What settings are mandatory on router to make this plugin work? (ports forwarding, ports triggering, whatever else?)
I never managed to make this work with my Pioneer AV amplituner and BR. But I tend to disable some services if I don't use their functionalities. Wonder what I could set do be disables that it doesn't work...
Reply #220
Thanks for this nice plugin, works well on Windows 10 - foobar 1.4
Tested with DENON AVR-X4000, also seems to support all my other devices.
I agree with some other users that transferring some tags like Artist, Title, Album, to the renderer would be great!  ;)
Does anybody know of UI column applet or something to switch the Output device from the GUI rather than in preferences?
Reply #221
Hello
Thanks to second me on requesting to have tags displayed
For avoiding to go to Preferences, I just defined buttons by using right click on the tool bar and Customize button
Then Main / playback device/ my selected device in the right list
I have two buttons. One to switch to my PC audio card, once to reach to my DLNA renderer Denon DRA 100
Hope this get you the solution you are looking for
Bye
Reply #222
@alpha centauri, thanks so much, found the Toolbar setting and added some buttons for my AVR and Soundcard.  :)
There I also sighted another option (in foobar 1.4) called "Output Switcher", providing a value list with all devices which I added for the occassional switch to other players!
Yvw for backing tags request. Would really be a nice feature.
Reply #223
Tested on Foobar 1.4, Raspberry pi 3 b+ with Archphile and Mamboberry DAC (ES9023).
Cannot do more than 16bits, also when playing flac at 352KHz it downsamples it to 192KHz, but I am not sure if the downsampling is due to the plug-in.
Great plug in, thank you!
Reply #224
What would really be fun and new, is to be able to play music in scync on multiple Upnp players at the same time.
Thanks for the suggestion, maybe I should consider...  ....
Meanwhile, I hope the next version will bring compatibility improvements!
Hi, any developements or workarounds on this idea?
