Topic: TAudioConverter (Read 332741 times) previous topic - next topic
TAudioConverter
Reply #375
Much of my music library is AAC, but some is in MP3 format. For certain devices I use I need to be able to transcode my entire library into MP3 format. I can do this by moving all AAC files into TAudioConverter (somewhat tedious), but it would be nice to be able to add my entire library into the converter, have it convert everything *except* the files already in the destination formation. Those I want moved to the destination, not transcoded. Is that possible?
Thanks,
  - Henrik
TAudioConverter
Reply #376
A feature request: if the file already exists at the destination, skip it. That way we can run TAudioConverter and only transcode the "new" files that have been added to the library.
  - Henrik
TAudioConverter
Reply #377
@henrikk added to-do list.
TAudioConverter
Reply #378
I second this one, or even give the option to overwrite.
  - Henrik
TAudioConverter
Reply #379
Replaygain would be nice, but only if it doesn't take away from the already perfect product you have here
NH
TAudioConverter
Reply #380
Update:
-Added: Using pipes with encoders that support it
-Added: New skin "DarkMetro"
-Added: Option to skip a file if it's output exists (thx to henrikk)
-Fixed: FFMpeg AAC encoding bitrate was always 128kbps problem (thx to norc426)
-Fixed: It took too long to save logs
-Fixed: A possible error which caused source files to be deleted
-Fixed: Ctrl+A combination caused strange behaviour (thx to o-l-a-v)
-Fixed: Some codec settings obscured other controls
-Removed: SoX
-Removed: Some audio filters
-Updated: OpusEnc to 0.1.6 using libopus 1.1.x [2013-04-23]
-Updated: AltiVec/SSE optimized lame (thx to Brazil2)
-Updated: madExcept to 4.0.7
TAudioConverter
Reply #381
Drag and drop not working on TAC 8.5
After close and re-open the program, it worked fine, sorry.
TAudioConverter
Reply #382
Some users reported that they get "a,bc is not a float" error. I fixed it. If you have that error too, you can try TAudioConverter.exes below:
For installed version: https://dl.dropboxusercontent.com/u/9617171...dioConverter.7z
For portable version: https://dl.dropboxusercontent.com/u/9617171...ter_portable.7z
If you cannot download these files now, please try them later. My upload speed seems to be very low.
TAudioConverter
Reply #383
[21.05.2013 11:13:40]  Started deleting temp files...
[21.05.2013 11:13:40]  Temp Folder: C:\temp
[21.05.2013 11:13:40] Cannot find to delete: C:\temp\.
[21.05.2013 11:13:40] Cannot find to delete: C:\temp\..
[21.05.2013 11:13:40] Cannot find to delete: C:\temp\foo_temp
[21.05.2013 11:13:40]  Deleted 0 file(s).
[21.05.2013 11:13:40] Finished deleting temp files.
[21.05.2013 11:13:59]  Started deleting temp files...
[21.05.2013 11:13:59]  Temp Folder: C:\temp
[21.05.2013 11:13:59] Cannot find to delete: C:\temp\.
[21.05.2013 11:13:59] Cannot find to delete: C:\temp\..
[21.05.2013 11:13:59] Cannot find to delete: C:\temp\foo_temp
[21.05.2013 11:13:59]  Deleted 0 file(s).
[21.05.2013 11:13:59] Finished deleting temp files.
[21.05.2013 11:13:59] Number of commands per process are as follows:
[21.05.2013 11:13:59] Encoder1: 1
[21.05.2013 11:13:59] ----Encoding Summary----
[21.05.2013 11:13:59]         -Number of processes: 4
[21.05.2013 11:13:59]         -Copy tags: True
[21.05.2013 11:13:59]         -Use custom tags: False
[21.05.2013 11:13:59]         -Enable artwork: False
[21.05.2013 11:13:59]         -Copy artwork to output: True
[21.05.2013 11:13:59]         -Copy external artwork: False
[21.05.2013 11:13:59]         -Download lyric: False
[21.05.2013 11:13:59]         -Add encoder suffix: True
[21.05.2013 11:13:59]     +Audio
[21.05.2013 11:13:59]         -Copying audio
[21.05.2013 11:13:59] Temp: C:\temp
[21.05.2013 11:13:59] Output: C:\
[21.05.2013 11:14:00] Cannot find output file C:\\\8511babbd4.240.m4a
What does it mean?? Can't encode/extract anything...
🇺🇦 Glory to Ukraine!
TAudioConverter
Reply #384
@Steve Forte Rio can you post log "Encoder1"? Also info about file causing the problem.
TAudioConverter
Reply #385
I've figured out why it happens. There's a problem with handling cyrillic symbols in the input/output path (
Can't init outfile 'D:\яряър\\source.mp3'
av_interleaved_write_frame(): Invalid argument
TAudioConverter
Reply #386
Prior to converting, when I look at a file with MP3Tag I see the Album Artist field "ALBUMARTIST" tag. after conversion field gone. Am I missing something or don't have correct settings?
NH
TAudioConverter
Reply #387
NH
MediaInfo can't read that tag, nor "total tracks", "disc" or "total discs" either.
TAudioConverter
Reply #388
I have another feature request, it would be nice to see Helix included. Recent tests show that it has potential, sometimes it performs even better than LAME.
TAudioConverter
Reply #390
@Brazil2 I removed it because most of the encoders now use stdin/stdout directly from FFMpeg (FFMpeg>Encoder). I didn't have time to include SoX into that chain (FFMpeg>SoX>Encoder). But I will give it a try when I have time.
TAudioConverter
Reply #391
One user has reported a bug. If you check "Enable" under "Filters/Effects" window and do not change filters' values from their defaults ("Samplingrate>orginal", "ChangeVolume>Unchecked", etc), encoding fails. You can uncheck "Enable" if you don't use any of the filters. Using at least one filter (apart from channel) prevents that error.
TAudioConverter
Reply #392
Update:
-Added: "Volume" filter is now percentage based
-Fixed: "x,yy is not a float" error when TAC started
-Fixed: Encoding failed if effects were actived but not changed from defaults (thx to Glenn Gomes)
-Updated: FFmpeg to latest static build from ffmpeg.zeranoe.com/builds/
TAudioConverter
Reply #393
When will you introduce support of cyrillic symbols???
TAudioConverter
Reply #394
NH
could you post a sample with those tags please ?
I'll patch mediainfo to have this...
TAudioConverter
Reply #395
Ozok: Seems like TAC can't handle norwegian signs "Æ", "Ø" or "Å" in file names of directory.
Error is "No such file or directory"
TAudioConverter
Reply #396
@o-l-a-v @Steve Forte Rio I'm trying to find out if this caused by TAC or one of the backends.
Edit: I think ffmpeg fails at that point. I'll try to use an other build.
Edit2: It's more likely that TAC passes commands wrong. Temp. bat file's encoding is ANSI. I'll try to find a solution.
Edit3: It's most definitely caused by latest changes in TAC. Older versions (I tried 0.8.4) without piping works without a problem.
TAudioConverter
Reply #397
I made a build that uses old temp. wav file logic instead of stdin/stdout. It should work with non-ansi chars. It will need SoX to be placed under tools folder in a folder named sox, just like old releases. That means SoX filters are back. As usual overwrite old exe.
For installer version: https://dl.dropboxusercontent.com/u/9617171...dioConverter.7z
SoX: https://dl.dropboxusercontent.com/u/9617171/sox.7z
Please report any bug you may find.
Edit: Exe's above cannot encode to AIFF. I'll fix this.
TAudioConverter
Reply #398
This version fixed the non-ansi characters in file name issue for me.  Thank you. I was not able to use 0.8.6 until this was fixed.
Thank, BTW, for adding the "skip file if it already exists" option I requested.
  - Henrik
TAudioConverter
Reply #399
When encoding using lame, I select algorithm quality 2. The log files say you TA calls "lame" with the "-q 2" setting. When I examine the resulting mp3 file using mediainfo it reports "-q 0" as the setting that was used. I am not saying mediainfo is right, but has anyone else noticed this?
  - Henrik
