Topic: "How I can remove vocals ?" - answers here : (Read 7523 times) previous topic - next topic
Because many of you ask about this , i try to help you :
YoGenVocalRemover1.07
http://www.yogen.com/vocalremover/
VogoneVocalEliminationWorkstationv2.014
http://www.mtu.com/basics/vocal-eliminator.htm
AnalogX Vocal Remover (DX) v1.00
http://www.analogx.com/contents/dow...io/vremover.htm
AnalogX Vocal Remover (Winamp) v1.03
Very useful can be and :
AnwidaSoft GEQ31V VST v1.1
http://www.anwida.com/geq31v.asp
TC.Works.Native.Bundle.v3.0.VST (Graphic EQ and Parametric EQ)
http://www.tcworks.de/home/content/...come/render_top
Unfortunately , in many cases , removing vocals , you 'll remove and some frequences from orkestration , but must to try ,with patience , the results are different in each case !
I hope this 'll be useful to you !
Doru Malaia
composer
http://www.freewebs.com/dorumalaia
compozi@yahoo.com
The third, fourth, and sixth links are broken.
It seems VogoneVocalEliminationWorkstationv2.014 is the only software that using some kind of vocal removal algorithm. The others just do substraction process and some broken links.
