Topic: Feature request: predefined variables! (Read 1710 times) previous topic - next topic
HI!!
I wanted to suggest this feature. May create a new pane in preferences dialog with list of predefined variables. This certainly would significantly simplify most of file operations and converter filename templates. I give an example: everywhere in file name formatting strings I use same expression for track number.
$ifgreater(%tracknumber%,0,$num(%tracknumber%,$ifgreater($trim(%totaltracks%),0,$max($len($num($trim(%totaltracks%),0)),2),2)),$upper($trim(%tracknumber%)))
Defining a global variable such as tn containing this pattern would be also very powerful if I decide in future to change this tracknumber formula to something yet more obfuscated, to just change the global variable instead of editing all presets individually. I suppose this feature isnot too complicated to implement so I hope Peter or some other developer will make it come truth
seconded. this would complicate things a little bit on the support end, but increase individuality/flexibility alot on the user end.
foo_exvar?
My English is very good!
...in comparison with my Korean language...
foo_dynfil allows exactly what you request.
I already thought this is what I wanted but it doesnot seem to work as I expect.
Defined in it a new variable tracknumber with expression from post #1.
Found this working in converter presets. Using this in any file operation preset %_tracknumber% behaves as undefined. Is this a bug or feature? I meen the predefined variables could be used everywhere when foobar metadata are excepted..
....Moreover dynfill doesnot generate empty pseudotags, for example %_foo% defined as $if3(%tag1%,%tag2%,%tag3%) produces zero width defined tag while expanded $if3(%tag1%,%tag2%,%tag3%) produces undefined tag where none of tag1, tag2 and tag3 is present. I'd need then _foo behaves also as not present at all so that [ - %_foo%] including the hyphen is skipped whenever none of tag1, tag2 and tag3 is present.
*BUMP*
foo_dynfill is not working at all for File Ops and Converter (except preview in converter), otherwise all virtual fields are handled as not present.
There's no need for timed updating or special handling, just to expand all global variables at the time of preocessing.
P.S. I hope some of developer still notices this and implements.
If it works in one part of foobar2000 but not in another then that sounds like it isn't the fault of foo_dynfil.
I don't know the foobar API system but tho it might not handle situations where title formatting is used for any other purpose than displaying. Then any other solution is needed for file names formatting.
