Topic: WAV to FLAC error with greek filenames (Read 6423 times) previous topic - next topic
Hi all,
i'm new in flac ripping. I installed EAC and configured it. When i tried to rip a CD to flac, at the end of every track, it told me : Warning "The external compressor returned an error".
In the end, all the tracks had been made to .wav files but they hadn't been converted into flac files.
I tried converting the wav files to flac files without EAC, by using the FLAC Front End alone, and it made an error : Run-time error '53': File not found.
When i give as input a wav file with latin caracters there is no problem at all.
So i'm quite sure the problem comes with wav files containing greek caracters in their name.
Does anybody have a solution or any idea about that ?
Thank you
Try an alternative app which uses Unicode character set. I own in my collection music with japanese titles (which suffers from the same issue), so that I have made a tests, and Foobar2000 converter handles finely music files with japanese titles.
This is the downfall of EAC's reliance on command-line apps instead of DLLs for external encoding. flac.exe is being invoked through a command shell, which is like a DOS prompt, so the characters are converted to what's valid there. This will only be 8-bit characters, whatever your system's ANSI set is (Windows-1252 for most folks). So probably things like é and ä will work but Greek is not an option unless you're using a Greek version of Windows.
Thanks guys,
so it seems i won't be able to use EAC..It's a pitty as i read it's "the best".
I'll try Foobar2000 then.
Does any of you know if dbPowerAmp will work ? (with greek filenames)
I've read dbPowerAmp does a great job (though i'll have to pay 35$ or something...  ). Do you have any preference between these two, as FLAC ripping is concerned?
Thanks to both of you and to anyone else
dBpoweramp is fully Unicode compatible, and I have performed a test, converting a music file with dummy greek title, and can handle finely.
You don't have to pay for using dBpoweramp, as long as you run just the basic functions, as detailed here:
http://www.dbpoweramp.com/db-versions.htm
Thanks pablogm123, i've just ripped the greek cd with Foobar2000 and it worked great. !
Do you think there is a quality difference in flac ripping between Foobar2000 and dBpoweramp ?
Thank you
To rip CDs in good/excellent condition there is absolutely no difference, because any decent drive can rip in a go any CD in good shape without reporting any C2 error . However, dBpoweramp will outperform other programs when you own a drive with good C2 support and you want to rip somewhat damaged CDs, because take into account C2 pointers in re-reads (and can do hundreds of re-rips), so that dBpoweramp can rescue more accurate data from damaged CDs. And don't forget that programs
Anyway, a rip verified by Accuraterip is always a very good thing. If verified by Accuraterip, doesn't matter if was extracted by EAC, dBpoweramp, Foobar 2000, at 8x speed, at 32x speed...
Thanks pablo
An alternative carrying the zero price tag, could be CUETools/CUERipper. It has UTF support, at least on the functionality I have been using – I have however not done much ripping with it (I use dBpoweramp reference).
Edit: Too late. Anyway, yes, try it.
thanks guys i'll have a look on CUETools/CUERipper, but before i'll check if my CD drive is C2 capable.
Does Foobar2000 manage C2 ?
thanks Porcus
