Topic: linux audio player (Read 6070 times) previous topic - next topic
linux audio player
i'm looking for a good audio player that runs under linux.  specifically it needs to support gapless playback.  i've tried xmms but it doesn't appear to do gapless...
thanks...
Dan
linux audio player
use the crossfade plugin for xmms, works very well
This is your life and it's ending one minute at a time!
linux audio player
ah, thanks!  emerging xmms-crossfade now.  i should have looked a bit harder...
Dan
linux audio player
does xmms support replaygain?  i've done a bit of poking around but i can't seem to find anything that says 'xmms supports replaygain'.  i'm using vorbisgain to replaygain my files.
Dan
linux audio player
The Vorbis-Plugin currently doesn't show options for replaygained files, so I assume it's not supported.
[span style='font-size:8pt;line-height:100%']EDIT[/span] At least plugins for Musepack, FLAC and MP3 support replaygained files.
linux audio player
The Vorbis plugin in 1.2.7 doesn't support ReplayGain, but the CVS version does.
What I do is just compile libvorbis.so from XMMS's CVS and overwrite 1.2.7's copy that lives in /usr/lib/xmms/Input (at least in Debian).
I don't use pure CVS XMMS because it's still got some bug that causes IPC to lock the player up.  That is to say, if I've got an xmms already running, and I run "xmms somefile", the player will lock up.
