Topic: m-TAGS component (foo_tags) (Read 85191 times) previous topic - next topic
Re: m-TAGS component (foo_tags)
Reply #350
I use this component for backup purposes only between two disks.
But i thing there is a problem when m-tags files already exists in folders because it seams that it can't overwrite ( although i have check it to do so ) the old files with the updated tags.
So i have to delete the old files and create new every time i want to make a backup.
Also when i have lyrics in a tag m-tags only writes a dot (.) . Is this normal.
Anyway thanks for this great plugin and i hope in future development.
Reply #351
I want to use this component for backup purposes only between two disks.
sorry i made a mistake in the first line
Reply #352
I had no issues with m-tags this far though today I noticed it was somewhat broken. While it still displays tracks perfectly fine it only shows about a third of all indexed files when I have the filter on artists rather than year, album title or genre. Is there any way to resolve this issue without having to re-add every single !.tags file?
Artist: https://i.imgur.com/6FBMkvT.png
Album title: https://i.imgur.com/G8peV0Q.png
Year: https://i.imgur.com/YCs77pt.png
Reply #353
Never mind. Just had to remove the Artist tab and add it and it was back to normal.
Reply #354
Thanks @luigimercurio, m-TAGS seems to be exactly what I needed to make compilations with individual tagging and cover without the burden of having duplicate files.
But how do I export these virtual albums?
File Operations > Copy to... only copies the !.tags and !.tags.front.bin files. So I use Convert to create the new files with applied tagging. Apart from the occasional "Could not attach image/File in use" bug this works as expected and seems a good choice in case of FLAC to FLAC or FLAC to lossy. But I want to avoid transcoding from lossy origin files, so how would I do that?
