New iTunes, new CoreAudioToolbox.dll Reply #25 – 2012-09-20 03:32:57 Mix3dmessagez, did you by chance read the first post? I've reconverted ~1400 songs, albums don't necessarily get smaller, some get bigger. For sure it's better, Apple likes to improve its components. Let's move on more technical details/issues. Last Edit: 2012-09-20 03:57:12 by eahm
New iTunes, new CoreAudioToolbox.dll Reply #26 – 2012-09-20 04:18:33 Quote from: eahm on 2012-09-20 03:32:57Mix3dmessagez, did you by chance read the first post? I've reconverted ~1400 songs, albums don't necessarily get smaller, some get bigger. For sure it's better, Apple likes to improve its components. Let's move on more technical details/issues.Yes I have, I was just reporting from my personal findings quicktime itself has been effected by the coreaudio update, and not just the encoder in itunes.
New iTunes, new CoreAudioToolbox.dll Reply #27 – 2012-09-20 07:48:53 So. Can anybody blind listening any differences between older and current CoreAudio or is the bitrate decrease only result of compression optimization?
New iTunes, new CoreAudioToolbox.dll Reply #28 – 2012-09-20 17:25:33 Quote from: Anakunda on 2012-09-20 07:48:53So. Can anybody blind listening any differences between older and current CoreAudio or is the bitrate decrease only result of compression optimization?http://www.hydrogenaudio.org/forums/index....st&p=808650http://www.hydrogenaudio.org/forums/index....st&p=808666
New iTunes, new CoreAudioToolbox.dll Reply #29 – 2012-10-30 03:46:38 I noticed two major differences so far:3ch(C+L+R) AAC encoding is supported on 7.9.8.1. It already works with qaac without modification on qaac side.ExtAudioFileRead() crashes when decoding HE-AACv2 on 7.9.8.1 (this has nothing to do with qaac, though).
New iTunes, new CoreAudioToolbox.dll Reply #30 – 2012-10-30 04:34:35 Thanks for the info.Can Apple (or even qaac) convert to HEv2? Is it possible with a specific command line or it's automatic below certain bitrates? Last Edit: 2012-10-30 05:16:38 by eahm
New iTunes, new CoreAudioToolbox.dll Reply #31 – 2012-10-30 06:08:57 If it is available, you can probably use "afconvert -d aacp" or something in Mac OS X. I don't have Mac or iOS devices, so I'm not familiar with Apple products at all.As for qaac, NO (same as iTunes for Windows).
New iTunes, new CoreAudioToolbox.dll Reply #32 – 2013-02-20 17:04:08 New iTunes 11.0.2.25. CoreAudioToolbox.dll is the same.
New iTunes, new CoreAudioToolbox.dll Reply #33 – 2013-04-20 11:24:59 The file CoreAudioToolbox.dll is different between QuickTime & iTunes, though version is the same? iTunes: File: C:\Program Files (x86)\Common Files\Apple\Apple Application Support\CoreAudioToolbox.dllSize: 4986768 bytesFile Version: 7.9.8.2Modified: Monday, January 28, 2013, 13:08:16MD5: D420904DDF2619DA2A96371B0D4670C9SHA1: 686334C8CC26B0C79FFBE361455EC2E5841BD4C2CRC32: BF71EFDDQuickTime: File: C:\Program Files (x86)\foobar2000\QTfiles\CoreAudioToolbox.dllSize: 4986768 bytesFile Version: 7.9.8.2Modified: Thursday, October 11, 2012, 21:56:10MD5: 8A73BCF073DA081C47C98F16E9805855SHA1: F40BB960AC8124E191E688E46BF07DBDEADA5D02CRC32: E4583F09
New iTunes, new CoreAudioToolbox.dll Reply #34 – 2013-04-20 14:20:38 Quote from: zqae on 2013-04-20 11:24:59The file CoreAudioToolbox.dll is different between QuickTime & iTunes, though version is the same? iTunes: File: C:\Program Files (x86)\Common Files\Apple\Apple Application Support\CoreAudioToolbox.dllSize: 4986768 bytesFile Version: 7.9.8.2Modified: Monday, January 28, 2013, 13:08:16MD5: D420904DDF2619DA2A96371B0D4670C9SHA1: 686334C8CC26B0C79FFBE361455EC2E5841BD4C2CRC32: BF71EFDDQuickTime: File: C:\Program Files (x86)\foobar2000\QTfiles\CoreAudioToolbox.dllSize: 4986768 bytesFile Version: 7.9.8.2Modified: Thursday, October 11, 2012, 21:56:10MD5: 8A73BCF073DA081C47C98F16E9805855SHA1: F40BB960AC8124E191E688E46BF07DBDEADA5D02CRC32: E4583F09This is only different timestam making the diiff
New iTunes, new CoreAudioToolbox.dll Reply #35 – 2013-10-04 17:09:27 iTunes 11.1.1.11 has 7.9.8.3. Nothing changed again.
New iTunes, new CoreAudioToolbox.dll Reply #36 – 2013-10-04 18:47:16 Can a mod please remove the Topic Description so we can keep it general to every iTunes version?Please delete this post as well.Thank you.edit:Topic Title: QTFiles (iTunes, QuickTime, CoreAudioToolbox.dll) changes thread Last Edit: 2013-10-04 19:10:25 by eahm
New iTunes, new CoreAudioToolbox.dll Reply #37 – 2013-10-04 19:04:12 First come up with something compliant with TOS #6, please.
New iTunes, new CoreAudioToolbox.dll Reply #38 – 2013-10-04 19:44:49 Quote from: greynol on 2013-10-04 19:04:12First come up with something compliant with TOS #6, please.Please check the edit. Thanks.
New iTunes, new CoreAudioToolbox.dll Reply #39 – 2013-10-24 05:42:32 New iTunes (11.1.2.31) has CoreAudioToolbox.dll 7.9.8.3. Nothing changed again.
New iTunes, new CoreAudioToolbox.dll Reply #40 – 2013-10-24 14:59:30 Apple AAC encoder was already mature since 2005. I don't think there were any revolutionary changes since then ... and there won't be anymore.
New iTunes, new CoreAudioToolbox.dll Reply #41 – 2013-10-24 16:08:02 Last change was in April 2013, I don't know if much changes regarding quality, ever since 2006 like you said but I keep track of changes anyway, it doesn't cost me anything reporting here. The audio checksum changes every time there is a number change.
New iTunes, new CoreAudioToolbox.dll Reply #42 – 2013-10-24 18:25:39 I appreciate the reporting, since I would test a new version if it appears.
New iTunes, new CoreAudioToolbox.dll Reply #43 – 2013-11-06 17:34:31 New iTunes 11.1.3.8 still 7.9.8.3. Nothing changed again.
New iTunes, new CoreAudioToolbox.dll Reply #44 – 2013-12-28 21:16:59 QuickTime 7.7.4 has CoreAudioToolbox.dll 7.9.8.3.
New iTunes, new CoreAudioToolbox.dll Reply #45 – 2014-01-22 23:56:10 New iTunes 11.1.4 and new CoreAudioToolbox.dll 7.9.8.4but the name of the dll now is "AppleApplicationSupport_CoreAudioToolbox.dll"and I don't know what changes in this version. Last Edit: 2014-01-22 23:57:38 by moob2014
New iTunes, new CoreAudioToolbox.dll Reply #46 – 2014-01-23 00:15:28 Odd, I just downloaded new iTunes. Same version number you mentioned, 11.1.4, but I'm getting a different version of CoreAudioToolboxI'm getting 7.9.8.5 and the name is still CoreAudioToolbox.dll
New iTunes, new CoreAudioToolbox.dll Reply #47 – 2014-01-23 00:38:36 Quote from: lock67ca on 2014-01-23 00:15:28Odd, I just downloaded new iTunes. Same version number you mentioned, 11.1.4, but I'm getting a different version of CoreAudioToolboxI'm getting 7.9.8.5 and the name is still CoreAudioToolbox.dllI have extract with 7-zip and the name is "AppleApplicationSupport_CoreAudioToolbox.dll", but extract with cmd line the name is correct and for me the version is 7.9.8.4as you can see here: Last Edit: 2014-01-23 01:08:44 by moob2014
New iTunes, new CoreAudioToolbox.dll Reply #48 – 2014-01-23 01:06:10 I guess I got the best of both worlds. iTunes 11.1.4, the file is named "AppleApplicationSupport_CoreAudioToolbox.dll", and the file version/product version for me is 7.9.8.5.
New iTunes, new CoreAudioToolbox.dll Reply #49 – 2014-01-23 01:07:50 Quote from: azaqiel on 2014-01-23 01:06:10I guess I got the best of both worlds. iTunes 11.1.4, the file is named "AppleApplicationSupport_CoreAudioToolbox.dll", and the file version/product version for me is 7.9.8.5.qaac show as version 7.9.8.5 but is not, the file version for me is 7.9.8.4 Last Edit: 2014-01-23 01:12:27 by moob2014
