Topic: New iTunes, new CoreAudioToolbox.dll (Read 115684 times) previous topic - next topic
Reply #100
^^^ Even if it's true that there haven't been improvements to the encoder's compression efficiency for some time, isn't is still desirable to deploy updates? Maybe they're fixing security flaws, or maybe they improve the runtime of some routines?
Reply #101
For those of us who only extract the necessary CAT DLLs to make qaac run and don't use QuickTime or iTunes, the updates are totally useless as far as I can see.
Reply #102
iTunes 12.2.0.145, CoreAudioToolbox.dll 7.9.9.6
Reply #103
iTunes 12.2.1.16, CoreAudioToolbox.dll 7.9.9.6
Reply #104
iTunes 12.2.2.25, CoreAudioToolbox.dll 7.9.9.6
Reply #105
iTunes 12.3.0.44, CoreAudioToolbox.dll 7.10.5.0
Haven't tested yet.
Can a mod please rename the thread "New iTunes/QuickTime, CoreAudioToolbox.dll"?
Reply #106
Any word on changes/updates to the encoder, or is it still the same?
Reply #107
I'd be curious as well. We went from 7.9.x.x to 7.10.x.x which suggests a minor feature update (the conventional numbering scheme is major.minor.bugfix.development_build)
Reply #108
Well, something changes but don't know much more than that.
D:\Downloads\makeportable 79>qaac.exe -V63 --no-optimize "01. Atom Heart Mother.wav"
qaac 2.55, CoreAudioToolbox 7.9.9.6
01. Atom Heart Mother.m4a
AAC-LC Encoder, TVBR q63, Quality 96
[100.0%] 23:45.160/23:45.160 (52.5x), ETA 0:00.000
62849556/62849556 samples processed in 0:27.170
Overall bitrate: 134.309kbps
D:\Downloads\makeportable 710>qaac.exe -V63 --no-optimize "01. Atom Heart Mother.wav"
qaac 2.55, CoreAudioToolbox 7.10.5.0
AAC-LC Encoder, TVBR q64, Quality 96
[100.0%] 23:45.160/23:45.160 (59.0x), ETA 0:00.000
62849556/62849556 samples processed in 0:24.140
Overall bitrate: 134.311kbps
I switched to FhG long ago (Total encoding time: 0:15.328, 92.97x realtime).
Reply #109
iTunes 12.3.1.23, CoreAudioToolbox.dll 7.10.5.0
Reply #110
iTunes 12.3.2.35, CoreAudioToolbox.dll 7.10.5.0
Re: New iTunes, new CoreAudioToolbox.dll
Reply #111
iTunes 12.3.3.17, CoreAudioToolbox 7.10.5.0
Reply #112
iTunes 12.4.0.119, CoreAudioToolbox.dll 7.10.5.0
Reply #113
iTunes 12.4.1.6, CoreAudioToolbox.dll 7.10.5.0
Reply #114
iTunes 12.4.2.4, CoreAudioToolbox.dll 7.10.6.0
nu774, makeportable is only able to extract QTFiles not QTFiles64 now. Thanks.
Reply #115
Just tried iTunes6464Setup.exe of 12.4.2.4.
makeportable works for both 32bit and 64bit here.
Reply #116
CoreAudioToolbox.dll 7.10.6.0, no changes in output data
Reply #117
Confirmed, sorry iTunes was downloaded from CodecPack.co thinking it was the official direct link but I guess Apple uses more links, this one was named only iTunes64setup.exe (one 64 not two) and makeportable didn't extract QTFiles64 even if the iTunes setup file is the same. Thanks for double checking.
Reply #118
When I run ver 2.59 qaac64 --check I get an error on the CoreAudioToolbox.dll that makeportable extracted from iTunes6464setup.exe 12.4.2.4... can anyone else confirm this behavior?
">qaac64 --check
ERROR: 193: CoreAudioToolbox.dll"
Reply #119
Sorry... never mind, it's just an issue of which Microsoft C Runtime Library was already on one machine but not on another.   :-[ Duh!
Reply #120
Only get CoreAudioToolbox.dll 7.10.5.0 here. Tested multiple download places for the latest iTunes and it's the same on all of them..... ???
Reply #121
If you want to get the correct version number for CoreAudioToolbox.dll then you have to use the "qaac --check" command.
Window only gives you the localized version number.
Reply #123
iTunes 12.4.3.1, CoreAudioToolbox.dll 7.10.6.0
Reply #124
iTunes 12.5.1.21, CoreAudioToolbox.dll 7.10.7.0
