Topic: Foobar hangs with AAC (Read 2632 times) previous topic - next topic
I have an audio stream which offers AAC quality.  In setting up a shortcut for the desktop in Win XP, Foobar latest version hangs:  minutes counter rolls but no audio is heard and the graphic display on the default viewer freezes.
I find this odd because Fb2k normally plays everything.
Setting up the same type of shortcut in Winamp is working.
what does the console says?
What stream? Where? Which version of foobar2000? Which other components are installed? Could you consult the rules of the subforum Support, to which I’m going to move this, and get back to us?
moving is fine.  I noticed tech support handles this but I'm equipped to speak of tech jargon so put it in here.
Please indicate when moved.
the log file from console:
Watching: C:\Documents and Settings\lon.LON4MSI\My Documents\My Music
Startup time : 0:00.111631
Opening track for playback: "http://audio-mp3.ibiblio.org:8000/wcpe.aac"
ends
This url was picked up successfully by Winamp.
I did it immediately after I posted, which I thought would be expected as there’d have been no point in delaying. In future, you can view the location of the current thread right below the top menu:
Hydrogenaudio Forums > Hosted Forums > foobar2000 > Support - (fb2k) > Foobar hangs with AAC
I have found you.  Will continue to watch the thread.
