Topic: Foobar ver1.1.13 can't dock facets pane. (Read 2967 times) previous topic - next topic
Recently installed a new SSD and Foobar ver 1.1.13.
Now trying to recreate my old layout - but - using Columns UI And Facets I cant get the Facets window to Dock or lock into my UI.
It just sits there and floats - extremely discouraging since this is my main search tool and it will disappear on close.
I've been through the forums checking on everything FACETS related but can find precious little.
Is it possible I can't use Columns and Facets together? And if so how do i remove Facets?
It also seems that all my vertical splitters show up only as horizontal WTF?
Any help will be greatly appreciated.
Facets only integrates with the Default UI. You'll need to use Columns UI's own Filters panels instead.
Thanks But where Do I get Colemans UI - Its not a campstove is it??
OOPS Sorry I didnt notice COLUMNS UI
Anyway do I need to remove FACETS First and if so How It's not showing up in Components.
Removing it is not necessary, though there is no reason for Facets to not show in preferences>components
