Topic: cpu priority lame.exe win2k (Read 2539 times) previous topic - next topic
Is there a way to adjust the lame priority in the commandline?
I use lameb (http://www.lameb.fsnet.co.uk/ ) for encoding.
Adjusting the cpu priority of lame.exe works only during the encode process of one file.
Lameb restarts lame.exe after each file.
Lame will get the priority of the application that executes it... So if you´re running lameb in "idle" then Lame will also do so when it´s executed... That´s at least how command line applications under Win32 works... But it should be the same for a Window based application...
[deleted]
[deleted]
thnx alot!
I'll give it a try
