Topic: Can I make foobar output two way at same time? (Read 1980 times) previous topic - next topic
Normally we can choose one output in foobar,
but I want to make two outputs(analog and digital on my onkyo-90pci soundcard) at the same time, of course same track.
I don't need seperate control of two outputs.
So, two amps accept each output and drive each pair of speaker..(of course one of them has own dac inside)
Is there component or method make this possible?
I'm sorry for my hard to understanding English...
thank you for reading!
No replies, so for what it's worth, this is what happens on my system.
When I've got two separate sound devices (eg my PCI card and also a USB device) then I can only set the output to either one or the other. Not sure if there is a work around, but that's how it is by default.
In the case of just one sound card with both analog and spdif out however,  as soon as I enable spdif-out for the card then any sounds sent to that card automatically output on both the analog and the spdif. I've only really tested this on my current realtek onboard system, but I thought that they all worked this way.
Oh, I see!
Thank you for reply , It's very helpful.
