Topic: [v1.1.13] Slow radio stream load on start. (Read 1320 times) previous topic - next topic
When I want to use radio stream then start for plaing takes about 10 - 15 seconds. I tested different addresses and there is always the same. I do not have any issue with network speed and f2k is present in firewall. Strange because for example winamp or  xmplay for same stream starts playing immediately ( 1- 2 seconds).
Issue appears only just after start of f2k, during using foo switching between streams is smooth.
I see similar issue for v1.1.13, http://www.hydrogenaudio.org/forums/index....showtopic=95669
Does anyone know the solution for this isse?
