Topic: Adding newer Winamp features to OptimFROG plug-in (Read 7702 times) previous topic - next topic
A lot of winamp plug-ins sadly miss newer functions like transcoding decoder, unicode and ReplayGain so
I have been playing around with the OptimFROG input plug-in and added support for unicode and decoding for the transcoder but adding ReplayGain is beyond my abilities.
If someone can help out with adding ReplayGain that would be great
Here is the plug-in and source I have now (you still need OptimFROG.dll (OptimFROG_All_Windows_x86_4910b) in your winamp folder (not the plug-in folder))
http://www.mediafire.com/download.php?r3jl2l761185m72
To compile just override the "Winamp5" folder from the SDK (OptimFROG_SDK_All_1210b) and use "in_ofr.sln".
Thank you for your efforts in this.  Your update also seems to have fixed the issue I was experiencing with the official plugin, where tag information was not being set in the "Media Library".
If you are still developing this, I have experienced a bug where the modified "in_ofr.dll" crashes Winamp when:
- attempting to play/read a nonexistent OptimFROG file, and
- starting a clean installation of Winamp (ie. without "Winamp.ini" present).
