Topic: WASAPI 3.0 b3 crash dump (Read 2380 times) previous topic - next topic
Hi Peter, as requested here is the last crash dump I got when trying to output 32bit to the Musiland 02.
EDIT -> mistake in loading wrong plugin version.
Results with Beta 4 and Musiland:
using Event mode -> WORKS!!!!!!! 32bit@any sampling rate, Peter you truly are a star
Using push mode -> nothing happens. I click play, the track is selected but noyhing happens, no sound and the slider doesn't move. Musiland control panels shows no signal incoming. No log or dump files are generated. As Event Mode works fine case can be closed.
deleted
