Topic: BBC Radio 3 320kbps stream (Read 23654 times) previous topic - next topic
At the moment the BBC seem to be struggling to provide enough bandwidth to the UK. Recently the SD iPlayer streams were cut from 800kbps to 480kbps (HD is still good). I guess usage from other countries is a low priority for them. Hopefully they will upgrade their servers soon, but in the meantime all I can suggest is using a UK VPN (I use Golden Frog's to access US-only content - it's not the cheapest VPN but it's always been reliable and fast).
Regards,
NiPP0
There is also a SoX resampler for foobar. It's the best one I have found (although for low bitrate 32kHz radio streams the standard PPHS re-sampler would be fine).
What happens outside the UK if you connect through the flash-based web pages...
http://www.bbc.co.uk/iplayer/radio/bbc_rad...hree/listenlive
128kbps AAC inside the UK by default, 48kbps AAC if you select the low bandwidth version (hidden down near the bottom of the page)
http://www.bbc.co.uk/radio3/hd-sound/
320kbps AAC inside the UK
on first link, there is a 32 kbps AAC stream without possibility of choice,
second link - "HD" - stream doesn't work outside the UK
