Topic: ape+cue (Read 6166 times) previous topic - next topic
ape+cue
Hi gus,
I hope this is the right section.
Is possible to ripping audio cd by foobar to ape+cuesheet files?
I want to have at the end one file for each song and one cue file.
I can't create cuesheet file.
Thanks in advance
ape+cue
As far as I know, using foobar2000, you only can rip to:
  • separate tracks
  • image and embedded cue sheet
  • image
Why don't you use Exact Audio Copy?
ape+cue
I agree. EAC is the right way. Foobar2000 doesn't perform any pregap, ISRC, MCN... detection.
Perhaps Cuetools (CueRipper, I mean) is another good tool for this purpose, too.
ape+cue
That's right, but eac crash with my windows seven 64 bit when i choose external compression
If you have a solution for this problem i'm very happy because I have always used EAC with ape codec for convert audio cd.
ape+cue
If you tell us what version of EAC you're using and what command line parameters you are using, someone might be able to help you.
ape+cue
I try EAC 1.0 beta3, when i browse external codec in compression option\external compression, eac crash...
all the operation in which EAC must create a folder or work in an existing folder, EAC crash...
I think that depends on something related to the privileges of the user but i can't solve the problem...
Thank
ape+cue
Try running EAC as administrator.
ape+cue
I already tried to run EAC (and all the .exe components) as administrator but does not work...
ape+cue
Do you happen to have Adobe Drive installed? Having it has reportedly caused problems such as the ones you're experiencing.
ape+cue
You're a genius... i unistalled all adobe software but now EAC go fine...this is the important
Thank you very much...
