Topic: Problem with mp3 cbr duration (Read 3039 times) previous topic - next topic
This is only for files with no VBR Header.
It seems especially on longer mp3 tracks with a constant bitrate, the duration is displayed too long.
To test this encode a long audio track (20min+) with recent lame.exe with  -b and -t parameters.
I've experienced another issue - duration is displayed less than it really is. Accordingly, file is played only partially (example). The issue is still present in beta.
Magically yours
Raistlin
1.1.12b2 - no changes relating my issue. Still plays just 19 minutes of 41 minutes mp3 file  . I'm forced to use Winamp to play it...
Magically yours
Raistlin
Have you tried either verify integrity [foo_verifier] or rebuild stream from the context menu?
The example you posted was encoded with LAME 3.91, -m j -V 4 -q 2 -lowpass 15.5 -b 128
-V 4 means VBR, at LAME's quality level 4. So the -b 128 is merely constraining the minimum bitrate, not forcing CBR.
Correction: Actually the -b 128 seems to override the -V4; the file has all 128 kbps frames, so it is CBR.
I see what you mean about the duration... actual duration is 41:34 but fb2k is reporting 19:53 for me, unless I add a VBR info header.
Example was posted by me, not by topic starter. It may have nothing to do with the problem he/she reported. But it surely concerns recognition of an mp3 file's length, so I wrote here instead of starting new topic.
Magically yours
Raistlin
No, I didn't. The fact is that this mp3 file is from torrent tracker. I don't want to change it 'cause I want to stay seeding. Anyway, Winamp recognizes its length correctly, so I believe foobar can do the same.
Magically yours
Raistlin
GCRaistlin, the header in yours has a LAME tag with a bad MusicLength value (19100315, nowhere near the size of the file). I wouldn't say it's a problem with foobar2000; it's just using what it's given.
Most operating systems offer the possibility to copy files. You will gain no sympathy or more helpful advice from me to fix your broken pirated downloads.
Kohlrabi
Maybe I was looking lazy - I didn't want to 'cause I'm really not. Let me explain. It surely is easy to copy the file and fix its header, now actually I did it, and thanks to tpijag for the advice. But it isn't a common solution for the issue. I agree that the file has broken header, but how an user should know about it? I knew that the file's duration is longer than foobar shows just from comments on the tracker page.
IMHO it would be better if foobar made some additional checks to recognize such bad situations.
Magically yours
Raistlin
