Topic: Quantization Grid (Read 23216 times) previous topic - next topic
Quantization Grid
Reply #50
Those original 8-bit quantisation steps are still easily visible...
It wasn't my intention to put this in dispute.
You thanked him a bit early
Not really; rather I think the issue is that not everyone is following the claims put forth by the OP (could only be me, but I somehow doubt it).
Thanks for the detour, nonetheless.
Quantization Grid
Reply #51
Then what is your point?
The effect of quantisation is visible beyond the reconstruction filter. That is my point. The "grid" survives, though not perfectly.
btw, I don't think there's any audible relevance to this.
Quantization Grid
Reply #52
The output of a DAC contains all of the intermediate voltages even if the signal is undithered.
Thank you!
You thanked him a bit early.
I'm not sure why anyone thinks a filter at 22kHz is going to change a square-ish low frequency waveform that much. The example I posted was a low amplitude sine wave at 50Hz; at 8-bits it ends up with square-wave-like transitions at ~250Hz due to quantisation. In this example, you can comfortably fit the first 40 harmonics within the transition band. That's more than you need to make a square wave look something like a square wave.
The quantization filter only changes a low frequency wave enough so that the transition isn't perfectly square.  As soon as the wave stops being perfectly square, all of the intermediate voltages are there.
Quantization Grid
Reply #53
I edited my previous response to include your follow-up post.  It should help to present my point, though I think I made it pretty clear earlier by suggesting that people are assuming facts not in evidence about the OPs claims.
Quantization Grid
Reply #54
I think the OP has changed their mind throughout this thread.
They've gone from digital = an evil fixed grid that wrecks audio, to digital = infinite resolution. (I'm paraphrasing!). From one extreme to the other. Neither is correct IMO, but the ideas are too vague to critique properly, and I haven't seen a good answer for amplitude "resolution". I know there's a formula for temporal "resolution" in another thread somewhere.
Quantization Grid
Reply #55
With such a professorial tone, no less.
Thanks for the images.  Hopefully people won't come away from this with the wrong idea this time around.  I fear that they would without them.
Quantization Grid
Reply #57
Aren't those pictures just showing that not enough dither has been applied? Not in the sense of audible necessity, but in the sense of optical waveform hygiene.
Quantization Grid
Reply #58
Isn't this just sort of saying, "there's quantization error/distortion/noise present"?
Quantization Grid
Reply #59
It's always present. Dither simply replaces much of it with a different kind of noise.
Quantization Grid
Reply #60
Understood. The point I'm making is that the "surviving grid" is in fact just the quantization error. Which shouldn't be controversial.
Quantization Grid
Reply #61
The image of the dithered 50Hz wave is pretty much how I remember the digital signal generators looking when set to minimum amplitude back when I used those things.
...or was it the digital oscilloscopes, I can't remember, though I usually used analog scopes.
Quantization Grid
Reply #62
I would say the quantization itself, but maybe this is a distinction without a difference.
Quantization Grid
Reply #63
The "surviving grid" is just correlated quantization error, that has not been decorrelated properly with an amount of noise suited for the input bit depth. It's neither quantization 'itself' nor any other voodoo. 2Bdecided has already explained it all very [a href='index.php?act=findpost&pid=789226']early[/a] in this thread. From there it went down, as if there really was some kind of unavoidable 'grid' residue, different from classical quantization error.
Quantization Grid
Reply #64
Yet the "error" plainly indicates the available discrete levels.
How is this voodoo?
I used scary quotes around the word error since the actual error is an analog signal that is limited between -1/2 and +1/2 when dither is not applied.
Quantization Grid
Reply #65
For a low-ish frequency input signal, ignoring noise etc, most of the instantaneous output voltages will be essentially "on" the quantization steps. You can see this very easily at low amplitudes.
So you look at this instantaneous output voltage and if it is NOT "on" a quantization step - you say "ignore that, it's noise".
And if this instantaneous output voltage is "on" a quantization step - you say "see I told you so".
Kevin Graf :: aka Speedskater
Quantization Grid
Reply #66
Yes, noise (thermal, shot, interference, etc.) that causes the signal to deviate from one of the discrete quantization levels as opposed to quantization error which is the reason that the signal is clamping to one of the discrete quantization levels.
Other than that the operative is "most" and how much is dependent on the highest frequency present in the signal.
Quantization Grid
Reply #67
It's hardly cherry picking.
Here are two graphs showing the distribution of sample values.
This is from the 8-bit without dither data, 8x oversampled (i.e. resampled to 352.8kHz) at 16-bits...
[attachment=6976:distribu...nodither.gif]
This is from the 8-bit with dither data, 8x oversampled (i.e. resampled to 352.8kHz) at 16-bits...
[attachment=6977:distribu...thdither.gif]
In both cases, the dominance of the original 8-bit quantisation steps is clearly visible: those huge peaks match the original 8-bit quantisation steps. The skirts around them are due to the effect of the resampling. In a real system, noise would broaden the skirts and reduce the peaks - though not noticeably for 8-bits! More importantly, an AC-coupled system will see the values drifting around with any DC in the sampled waveform.
EDIT: These distribution graphs are for full 20s 20Hz-1kHz log sweep -40dB signals - the same ones from which the waveform images in this post were taken.
Quantization Grid
Reply #68
Thank you - that's the bit where I explain that it doesn't matter. Worth repeating!
Quantization Grid
Reply #69
At what stage did you add the dither noise  David.
Owen.
Quantization Grid
Reply #70
Steps:
1. Create new project: 44.1kHz 16bit.
2. Generate sine wave, 20s, 20Hz-1kHz, log sweep, 0dB
3. amplitude change: -40dB
4. convert to 8-bit with or without dither <--------------- here. dither shape = TPDF dither amplitude = 1-LSB RMS (2-LSBs peak-to-peak)
5. convert to 16-bit
6. convert to 352800Hz 16-bit
Quantization Grid
Reply #71
The fact that you are sweeping the frequency adds a layer of complexity. We don't quite know what  artifacts may allready be in a sweep synthesised by cooledit.  For simplicity can you do those steps , and the statistical analysis on a static 50Hz sine wave, as in the original cooledit images.
Cheers
Owen
Quantization Grid
Reply #72
What would be the point? We have established that low level signals can be severely distorted by quantization, and that a nominal application of dither removes much, but not all, of that distortion. What more do you want to know?
Edit: typo
Quantization Grid
Reply #73
I can assure you, there are none with the sine wave sweep. (The square wave is atrocious, but I didn't use that).
I'd turned off the default dithering of all functions, so there is truncation quantisation distortion in the 16-bit representation, even though CEP is able to generate 32-bit float and dither to 16-bit normally by default when performing operations.
Just using 50Hz makes little difference...
[attachment=6978:distribu...nodither.gif]
[attachment=6979:distribu...thdither.gif]
Quantization Grid
Reply #74
pdq -look at the 2nd  image in 2bdecided post68  above . On first looking the dither seems to have not removed the distortions at all. I think it needs to be assertained what cool edit is actually doing.
David just seen your last post,  will read it now
