Topic: Search boxes for each column/field? (Read 1420 times) previous topic - next topic
One thing I think I'd really like in foobar2000 is a component that's just like the Library Search but with a separate search box above each column header that relates to the the field in the column below it. So whatever I type in the box above the Artist column would search just the artist field. If I then typed a word above the Title column then I'd see just the tracks which matched the artist and track. And the search should match whole words only. So "Eve" wouldn't match "Ever".
I'm well aware that you can do it all with the search syntax, but I like this more simple approach and it would mean other people could use it without getting stuck.
Does such a thing exist?
