Topic: Recommended program for FLAC tagging ? (Read 16240 times) previous topic - next topic
Hello,
a)What programs are recommended to tag existing FLAC files ?
b)And whether it's recommended or not, is WinAmp ok to tag files ? (I mean no compatibility problems or anything.)
Thank you.
What kind of program do you want? GUI- or commandline-based?
If the former, I believe many users here would recommend MP3tag. Other programs that support Vorbis Comment tags include foobar2000.
If the latter, there is an offical tool: metaflac
A GUI, at least for now.
Thank you.
What's a little bit disappointing about MP3tag is that it doesn't seem to support multiline 'comments' field.
Any comments about this ? Should I avoid multiline comments ?
Maybe we mean different things, but I have lots of comment fields with multiple lines, and MP3Tag works with them quite happily. Press control-enter at the end of the line to create a new line.
It only shows up properly (on my installation) when I view it under extended tags (right click - extended tags - double click on "comment"), but it definitely works, and when I view the comment in Foobar it appears on multiple lines.
I've been using MP3Tag for years - and yes, I have read through most of the documentation  - and *still* I'm learning new things about it - thanks!
I use kid3 for a gui.. for command line it's metaflac
