Topic: Trouble running FLACCL under linux on Optimus laptop (Read 6913 times) previous topic - next topic
I tried running FLACCL and FlaCuda under linux on a Optimus laptop (NVIDIA GT 555M not connected to any display, plus Intel HD 3000 chip integrated in the Sandy Bridge CPU), but I can't seem to make it work. My understanding is that I need to use Bumblebee in order to make use of my NVIDIA GPU. I've tried the following:
optirun ./CUETools.FLACCL.cmd.exe --opencl-type GPU --opencl-platform 'nvidia' foo.wav
optirun ./CUETools.FLACCL.cmd.exe --opencl-type GPU --opencl-platform 'NVIDIA' foo.wav
optirun ./CUETools.FLACCL.cmd.exe --opencl-type GPU --opencl-platform 'NVIDIA CUDA' foo.wav
I get:
FLACCL#0.3, Copyright (C) 2010 Gregory S. Chudov.
This is free software under the GNU GPLv3+ license; There is NO WARRANTY, to
the extent permitted by law. <http://www.gnu.org/licenses/> for details.
Filename  : foo.wav
File Info : 44100kHz; 2 channel; 16 bit; 00:00:28.3330000
Error     : no opencl platforms found
Same with FlaCuda:
optirun ./CUETools.FlaCuda.exe foo.wav
CUETools.FlaCuda v0.9, Copyright (C) 2009 Gregory S. Chudov.
Filename  : foo.wav
Error     : Exception of type 'GASS.CUDA.CUDAException' was thrown.
I made sure in the latter case to install the linux version of CUDA.NET.dll.
I have libOpenCL.so and libcuda.so installed. Am I missing something?
I'm afraid i don't know much about Bumblebee.
Try omitting --opencl-platform 'NVIDIA CUDA' parameter, so that it will try to use the first available platform. Bumblebee might have a different name for opencl platform.
Or it might be that you don't have an opencl driver installed. Have you tried running opencl samples from nvidia?
Take a look here: http://samiux.blogspot.com/2011/05/howto-n...-on-ubuntu.html
CUETools 2.1.6
I installed the CUDA toolkit and ran the sample CUDA code as instructed on that blog.
optirun ./deviceQuery
[deviceQuery] starting...
./deviceQuery Starting...
 CUDA Device Query (Runtime API) version (CUDART static linking)
Found 1 CUDA Capable device(s)
Device 0: "GeForce GT 555M"
  CUDA Driver Version / Runtime Version   4.10 / 4.10
  CUDA Capability Major/Minor version number: 2.1
  Total amount of global memory: 2048 MBytes (2147155968 bytes)
  ( 3) Multiprocessors x (48) CUDA Cores/MP: 144 CUDA Cores
  GPU Clock Speed:   1.35 GHz
  Memory Clock rate: 900.00 Mhz
  Memory Bus Width:   128-bit
  L2 Cache Size: 262144 bytes
  Max Texture Dimension Size (x,y,z) 1D=(65536), 2D=(65536,65535), 3D=(2048,2048,2048)
  Max Layered Texture Size (dim) x layers 1D=(16384) x 2048, 2D=(16384,16384) x 2048
  Total amount of constant memory:   65536 bytes
  Total amount of shared memory per block:   49152 bytes
  Total number of registers available per block: 32768
  Warp size: 32
  Maximum number of threads per block:   1024
  Maximum sizes of each dimension of a block: 1024 x 1024 x 64
  Maximum sizes of each dimension of a grid: 65535 x 65535 x 65535
  Maximum memory pitch:   2147483647 bytes
  Texture alignment: 512 bytes
  Concurrent copy and execution: Yes with 1 copy engine(s)
  Run time limit on kernels: Yes
  Integrated GPU sharing Host Memory: No
  Support host page-locked memory mapping:   Yes
  Concurrent kernel execution:   Yes
  Alignment requirement for Surfaces: Yes
  Device has ECC support enabled: No
  Device is using TCC driver mode:   No
  Device supports Unified Addressing (UVA):   Yes
  Device PCI Bus ID / PCI location ID:   1 / 0
  Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 4.10, CUDA Runtime Version = 4.10, NumDevs = 1, Device = GeForce GT 555M
[deviceQuery] test results...
PASSED
Press ENTER to exit...
optirun ./nbody
[nbody] starting...
Run "nbody -benchmark [-n=<numBodies>]" to measure perfomance.
    -fullscreen (run n-body simulation in fullscreen mode)
    -fp64       (use double precision floating point values for simulation)
    -numdevices=N (use first N CUDA devices for simulation)
> Windowed mode
> Simulation data stored in video memory
> Single precision floating point simulation
> 1 Devices used for simulation
> Compute 2.1 CUDA device: [GeForce GT 555M]
Then I tried running FlaCuda and FlacCL without --opencl-platform but I got the same result. I'm sure it's something silly, there's no good reason your apps can't run on my setup.
optirun ./oclDeviceQuery
[oclDeviceQuery] starting...
./oclDeviceQuery Starting...
OpenCL SW Info:
 CL_PLATFORM_NAME: NVIDIA CUDA
 CL_PLATFORM_VERSION: OpenCL 1.1 CUDA 4.1.1
 OpenCL SDK Revision: 7027912
OpenCL Device Info:
 1 devices found supporting OpenCL:
 Device GeForce GT 555M
  CL_DEVICE_NAME: GeForce GT 555M
  CL_DEVICE_VENDOR: NVIDIA Corporation
  CL_DRIVER_VERSION: 290.10
  CL_DEVICE_VERSION: OpenCL 1.1 CUDA
  CL_DEVICE_OPENCL_C_VERSION: OpenCL C 1.1
  CL_DEVICE_TYPE: CL_DEVICE_TYPE_GPU
  CL_DEVICE_MAX_COMPUTE_UNITS: 3
  CL_DEVICE_MAX_WORK_ITEM_DIMENSIONS: 3
  CL_DEVICE_MAX_WORK_ITEM_SIZES: 1024 / 1024 / 64
  CL_DEVICE_MAX_WORK_GROUP_SIZE: 1024
  CL_DEVICE_MAX_CLOCK_FREQUENCY: 1350 MHz
  CL_DEVICE_ADDRESS_BITS: 32
  CL_DEVICE_MAX_MEM_ALLOC_SIZE: 511 MByte
  CL_DEVICE_GLOBAL_MEM_SIZE: 2047 MByte
  CL_DEVICE_ERROR_CORRECTION_SUPPORT: no
  CL_DEVICE_LOCAL_MEM_TYPE: local
  CL_DEVICE_LOCAL_MEM_SIZE: 48 KByte
  CL_DEVICE_MAX_CONSTANT_BUFFER_SIZE: 64 KByte
  CL_DEVICE_QUEUE_PROPERTIES: CL_QUEUE_OUT_OF_ORDER_EXEC_MODE_ENABLE
  CL_DEVICE_QUEUE_PROPERTIES: CL_QUEUE_PROFILING_ENABLE
  CL_DEVICE_IMAGE_SUPPORT: 1
  CL_DEVICE_MAX_READ_IMAGE_ARGS: 128
  CL_DEVICE_MAX_WRITE_IMAGE_ARGS: 8
  CL_DEVICE_SINGLE_FP_CONFIG: denorms INF-quietNaNs round-to-nearest round-to-zero round-to-inf fma
  CL_DEVICE_IMAGE <dim> 2D_MAX_WIDTH 32768
2D_MAX_HEIGHT 32768
3D_MAX_WIDTH 2048
3D_MAX_HEIGHT 2048
3D_MAX_DEPTH 2048
  CL_DEVICE_EXTENSIONS: cl_khr_byte_addressable_store
cl_khr_icd
cl_khr_gl_sharing
cl_nv_compiler_options
cl_nv_device_attribute_query
cl_nv_pragma_unroll
cl_khr_global_int32_base_atomics
cl_khr_global_int32_extended_atomics
cl_khr_local_int32_base_atomics
cl_khr_local_int32_extended_atomics
cl_khr_fp64
  CL_DEVICE_COMPUTE_CAPABILITY_NV: 2.1
  NUMBER OF MULTIPROCESSORS: 3
  NUMBER OF CUDA CORES: 144
  CL_DEVICE_REGISTERS_PER_BLOCK_NV: 32768
  CL_DEVICE_WARP_SIZE_NV: 32
  CL_DEVICE_GPU_OVERLAP_NV: CL_TRUE
  CL_DEVICE_KERNEL_EXEC_TIMEOUT_NV: CL_TRUE
  CL_DEVICE_INTEGRATED_MEMORY_NV: CL_FALSE
  CL_DEVICE_PREFERRED_VECTOR_WIDTH_<t> CHAR 1, SHORT 1, INT 1, LONG 1, FLOAT 1, DOUBLE 1
  2D Image Formats Supported (71)
  #    Channel Order  Channel Type
  1    CL_R            CL_FLOAT
  2    CL_R            CL_HALF_FLOAT
  3    CL_R            CL_UNORM_INT8
  4    CL_R            CL_UNORM_INT16
  5    CL_R            CL_SNORM_INT16
  6    CL_R            CL_SIGNED_INT8
  7    CL_R            CL_SIGNED_INT16
  8    CL_R            CL_SIGNED_INT32
  9    CL_R            CL_UNSIGNED_INT8
  10    CL_R            CL_UNSIGNED_INT16
  11    CL_R            CL_UNSIGNED_INT32
  12    CL_A            CL_FLOAT
  13    CL_A            CL_HALF_FLOAT
  14    CL_A            CL_UNORM_INT8
  15    CL_A            CL_UNORM_INT16
  16    CL_A            CL_SNORM_INT16
  17    CL_A            CL_SIGNED_INT8
  18    CL_A            CL_SIGNED_INT16
  19    CL_A            CL_SIGNED_INT32
  20    CL_A            CL_UNSIGNED_INT8
  21    CL_A            CL_UNSIGNED_INT16
  22    CL_A            CL_UNSIGNED_INT32
  23    CL_RG          CL_FLOAT
  24    CL_RG          CL_HALF_FLOAT
  25    CL_RG          CL_UNORM_INT8
  26    CL_RG          CL_UNORM_INT16
  27    CL_RG          CL_SNORM_INT16
  28    CL_RG          CL_SIGNED_INT8
  29    CL_RG          CL_SIGNED_INT16
  30    CL_RG          CL_SIGNED_INT32
  31    CL_RG          CL_UNSIGNED_INT8
  32    CL_RG          CL_UNSIGNED_INT16
  33    CL_RG          CL_UNSIGNED_INT32
  34    CL_RA          CL_FLOAT
  35    CL_RA          CL_HALF_FLOAT
  36    CL_RA          CL_UNORM_INT8
  37    CL_RA          CL_UNORM_INT16
  38    CL_RA          CL_SNORM_INT16
  39    CL_RA          CL_SIGNED_INT8
  40    CL_RA          CL_SIGNED_INT16
  41    CL_RA          CL_SIGNED_INT32
  42    CL_RA          CL_UNSIGNED_INT8
  43    CL_RA          CL_UNSIGNED_INT16
  44    CL_RA          CL_UNSIGNED_INT32
  45    CL_RGBA        CL_FLOAT
  46    CL_RGBA        CL_HALF_FLOAT
  47    CL_RGBA        CL_UNORM_INT8
  48    CL_RGBA        CL_UNORM_INT16
  49    CL_RGBA        CL_SNORM_INT16
  50    CL_RGBA        CL_SIGNED_INT8
  51    CL_RGBA        CL_SIGNED_INT16
  52    CL_RGBA        CL_SIGNED_INT32
  53    CL_RGBA        CL_UNSIGNED_INT8
  54    CL_RGBA        CL_UNSIGNED_INT16
  55    CL_RGBA        CL_UNSIGNED_INT32
  56    CL_BGRA        CL_UNORM_INT8
  57    CL_BGRA        CL_SIGNED_INT8
  58    CL_BGRA        CL_UNSIGNED_INT8
  59    CL_ARGB        CL_UNORM_INT8
  60    CL_ARGB        CL_SIGNED_INT8
  61    CL_ARGB        CL_UNSIGNED_INT8
  62    CL_INTENSITY    CL_FLOAT
  63    CL_INTENSITY    CL_HALF_FLOAT
  64    CL_INTENSITY    CL_UNORM_INT8
  65    CL_INTENSITY    CL_UNORM_INT16
  66    CL_INTENSITY    CL_SNORM_INT16
  67    CL_LUMINANCE    CL_FLOAT
  68    CL_LUMINANCE    CL_HALF_FLOAT
  69    CL_LUMINANCE    CL_UNORM_INT8
  70    CL_LUMINANCE    CL_UNORM_INT16
  71    CL_LUMINANCE    CL_SNORM_INT16
  3D Image Formats Supported (71)
  1    CL_R            CL_FLOAT
  12    CL_A            CL_FLOAT
  23    CL_RG          CL_FLOAT
  34    CL_RA          CL_FLOAT
  45    CL_RGBA        CL_FLOAT
oclDeviceQuery, Platform Name = NVIDIA CUDA, Platform Version = OpenCL 1.1 CUDA 4.1.1, SDK Revision = 7027912, NumDevs = 1, Device = GeForce GT 555M
System Info:
 Local Time/Date =  10:44:05, 02/08/2012
 CPU Name: Intel® Core™ i7-2670QM CPU @ 2.20GHz
 # of CPU processors: 8
 Linux version 3.2.4-1-ARCH (tobias@T-POWA-LX) (gcc version 4.6.2 20120120 (prerelease) (GCC) ) #1 SMP PREEMPT Sat Feb 4 10:53:01 CET 2012
[oclDeviceQuery] test results...
PASSED
FLACCL doesn't detect my Intel OpenCL driver either, while NVIDIA's openCL programs detect it.
./oclDeviceQuery
OpenCL SW Info:
WARNING: NVIDIA OpenCL platform not found - defaulting to first platform!
 CL_PLATFORM_NAME: Intel® OpenCL
 CL_PLATFORM_VERSION: OpenCL 1.1 LINUX
OpenCL Device Info:
 Device      Intel® Core™ i7-2670QM CPU @ 2.20GHz
  CL_DEVICE_NAME:       Intel® Core™ i7-2670QM CPU @ 2.20GHz
  CL_DEVICE_VENDOR: Intel® Corporation
  CL_DRIVER_VERSION: 1.1
  CL_DEVICE_VERSION: OpenCL 1.1 (Build 15293.6649)
  CL_DEVICE_TYPE: CL_DEVICE_TYPE_CPU
  CL_DEVICE_MAX_COMPUTE_UNITS: 8
  CL_DEVICE_MAX_WORK_ITEM_SIZES: 1024 / 1024 / 1024
  CL_DEVICE_MAX_CLOCK_FREQUENCY: 2200 MHz
  CL_DEVICE_ADDRESS_BITS: 64
  CL_DEVICE_MAX_MEM_ALLOC_SIZE: 1975 MByte
  CL_DEVICE_GLOBAL_MEM_SIZE: 7900 MByte
  CL_DEVICE_LOCAL_MEM_TYPE: global
  CL_DEVICE_LOCAL_MEM_SIZE: 32 KByte
  CL_DEVICE_MAX_CONSTANT_BUFFER_SIZE: 128 KByte
  CL_DEVICE_MAX_WRITE_IMAGE_ARGS: 128
  CL_DEVICE_IMAGE <dim> 2D_MAX_WIDTH 8192
2D_MAX_HEIGHT 8192
3D_MAX_WIDTH 2048
3D_MAX_HEIGHT 2048
3D_MAX_DEPTH 2048
  CL_DEVICE_EXTENSIONS: cl_khr_fp64
cl_intel_printf
cl_ext_device_fission
  CL_DEVICE_PREFERRED_VECTOR_WIDTH_<t> CHAR 16, SHORT 8, INT 4, LONG 2, FLOAT 4, DOUBLE 2
  2D Image Formats Supported (13)
  1    CL_RGBA        CL_UNORM_INT8
  2    CL_RGBA        CL_UNORM_INT16
  3    CL_RGBA        CL_SIGNED_INT8
  4    CL_RGBA        CL_SIGNED_INT16
  5    CL_RGBA        CL_SIGNED_INT32
  6    CL_RGBA        CL_UNSIGNED_INT8
  7    CL_RGBA        CL_UNSIGNED_INT16
  8    CL_RGBA        CL_UNSIGNED_INT32
  9    CL_RGBA        CL_HALF_FLOAT
  10    CL_RGBA        CL_FLOAT
  11    CL_BGRA        CL_UNORM_INT8
  12    CL_INTENSITY    CL_FLOAT
  13    CL_LUMINANCE    CL_FLOAT
  3D Image Formats Supported (13)
  10    CL_RGBA        CL_FLOAT
oclDeviceQuery, Platform Name = Intel® OpenCL, Platform Version = OpenCL 1.1 LINUX, SDK Revision = 7027912, NumDevs = 1, Device =      Intel® Core™ i7-2670QM CPU @ 2.20GHz
System Info:
 Local Time/Date =  14:07:10, 02/11/2012
 Linux version 3.2.5-1-ARCH (tobias@T-POWA-LX) (gcc version 4.6.2 20120120 (prerelease) (GCC) ) #1 SMP PREEMPT Tue Feb 7 08:34:36 CET 2012
PASSED
need compile wine with opencl support
if use archlinux (i look you first post, the link is archwiki, i suposed uses this distro, like me xd) install libcl, opencl-headers, and lib32-nvidia-utils. and build wine from the GIT
result:
sl1pkn07@sL1pKn07 flaccl04 $ wine CUETools.FLACCL.cmd.exe --opencl-type CPU  test.wav
FLACCL#0.4, Copyright (C) 2010 Grigory Chudov.
Filename  : test.wav
File Info : 44100kHz; 2 channel; 16 bit; 00:04:08.0930000
Error     : CreateDefaultContext: No OpenCL devices found that matched filter criteria.
sl1pkn07@sL1pKn07 flaccl04 $ wine CUETools.FLACCL.cmd.exe --opencl-type GPU  test.wav
Filename  : test.wav
Results   : 157.74x; 26892210 bytes in 00:00:01.5727500 seconds;
sl1pkn07@sL1pKn07 flaccl04 $ wine CUETools.FLACCL.cmd.exe --opencl-type GPU --opencl-platform 'NVIDIA CUDA' test.wav
Filename  : test.wav
Results   : 159.96x; 26892210 bytes in 00:00:01.5509400 seconds;
greetings
