Topic: Request: Converter - do not tag converted files (Read 1225 times) previous topic - next topic
The Converter component automatically copies all tags from source files to output files (if the output format/extension is known by Foobar). I would appreciate to be able to disable this behaviour and simply use encoders' tagging capabilities (with tags supplied through command line). Right now, I work around this by using an unknown file extension for output files and renaming them afterwards.
An ability to select which tags to apply would be even neater, but that would be too much hassle to implement, I guess. The ability to disable Foobar's tagging, however, seems like a matter of one checkbox to me.
Thank you in advance.
