Topic: foo_input_sacd: which PCM sample-rate should I use to convert to FLAC? (Read 4354 times) previous topic - next topic
I downloaded the SACD plugin from http://sourceforge.net/projects/sacddecoder/ and was wondering if I should leave the PCM Samplerate option at 44.1kHz for converting to FLAC files, or if I should change it to SACD's native sample rate?
SACD native samplerate is 2822400 Hz, btw. There's no such frequency in the PCM Samplerate option.
That's because the frequency doesn't correspond to PCM but DSD. Best option for conversion is 88.2 khz.
