Topic: Album Viewer that cycles images (For default UI)? (Read 4259 times) previous topic - next topic
Is there a component or perhaps WSH script that allows this? To my knowledge the only component that does this is for Columns UI.
Basically all I'd like is to be able to alternate between the main cover and alternate covers of albums.
There is a WSH Script which I use for this purpose (in "Columns UI"), but maybe it works in "Default UI" too. Create a test layout and try it out.
Go to this HA Forum thread and start reading the discussion from here...
Hey sorry to be lazy, but if you still have the script, would you just mind posting it? lol
i have a script which can do this. http://dl.dropbox.com/u/22801321/samples.zip
you'll want to import the script named thumbs.txt (and make sure you check the readme first).
you need to change a few settings to get it working as you want:
right click>image source>change to custom folder
right click>image source>set custom folder. here you can use title formatting so $directory_path(%path%) would display all images in the same folder as the current track.
right click>thumbnails>change to grid
now click an image so it fills the panel
finally right click>cycle> and pick an interval setting.
So Marc... I'm gonna be nitpicky here... Would there be a way to
A. Remove the border and blank space around the image
B. make it so that the script ONLY uses either the names folder.jpg or folder2.jpg when using images?
I realize A. is probably a lot easier to achieve than B, but I'm not sure how to do it on my own.
a) line 188, replace
scale2(gr, g_img[index], 10, 10, ww - 20, wh - 20, false);
with
scale(gr, g_img[index], 0, 0, ww, wh, "max");
b) browse your foobar profile folder (or foobar folder if using portable) and open the file marc2003\common4.js in a text editor.
line 259, replace
arr = read_images();
with
arr = utils.Glob(fb.TitleFormat("$directory_path(%path%)").EvalWithMetadb(g_metadb) + "\\folder*.jpg").toArray();
restart foobar (or reload the script by entering the editor and clicking OK)
this totally breaks the last.fm/custom folder menu options so don't use them.
