Topic: Need help getting new audio set for pc (2:1) (Read 2234 times) previous topic - next topic
Hello
i'm getting a new 2:1 set for my computer to play music with (and a little bit of gaming). but i'm having trouble finding good hardware.
I asked around and some one told me to get this set:
Xonar DX
Bookshelf Pair: DV62si
Mini Amp: DTA-100a
Sub: Polk Audio PSW 10
problem is i live in holland and only the xonar xd is avaible in holland (without shipment)
basically what i want is a good sound set around €400/€500  i'm pretty happy with getting the jamo-c-601-(zwart) bookshelf speakers but the problem are the sub and amp
i was thinking about getting a Yamaha YST-SW216 or Magnat Monitor Supreme Sub 201A .
i heard the jamo sub 210 is pretty good but i don't like the idea of the sub pointing down (i live on the second floor) but if it is a lot better i would buy it.
i'm also having a problem getting a good amp and't i'm not sure if i even need one.
also is the sonar DX a good card or should i get a newer one?
i hope you an help me and many thanks in advance.
There are many options but a particularly elegant one is the Bowers & Wilkins MM-1.  It alone replaces all the stuff you have listed, takes up little room, and is reputed to have excellent performance.  You should be able to find a dealer in Holland or order online for well within your budget.  A nice advantage of a system like this is how easily you can move it to another PC when you need mobility or when you upgrade your desktop.  I think you can even use it alone with a portable music player if you ever have the need, e.g. "party" mode.
thanks for the reply
but i have to say that i'm not really blown away by the speakers cause they don't seem like they are very powerful.
i listen mainly to dubstep and a strong bass is very important for that. but i don't get the idea this set will give that to me.
but i will go check out one of the retailers in the Netherlands cause they do look good (and i like the idea of streaming the sound to the speakers and let them do the proceeding work).
